48 loader on a jd3020 gas model
   / 48 loader on a jd3020 gas model #1
dvaidm
Harding mn
3020 john deere and 50 john deere
I have a John Deere 3020 gas model. It has a loader 48 on it. Today the loader controls or something went haywire cuz I use the bucket control to tip it forward and it wouldn't tip back and I raise the loader and the loader would not go down let me rephrase that the loader did go down when I had it in the down position but it took a long time for it to go down any recommendations it has fluid hydraulic fluid.?
   / 48 loader on a jd3020 gas model #2
What type valve control FEL(scv or ind)? Are any quick disconnect hyd fittings involved with FEL? If so disconnect/reconnect each set to be sure they're seating properly.
   / 48 loader on a jd3020 gas model #3
Agree with Tx Jim.
Have you removed and reconnected any hoses, replaced a couple of hoses? A hose or two in the wrong valve ports can cause what you are experiencing.
Add anything hydraulic like a grapple?
Post some photos of the valve and hoses and then the overall tractor.
Dave m7040
Agree with Tx Jim.
Dave m7040
No I haven't removed any of the hoses
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A51219)
2020 KENWORTH T680...
