PEX Piping Newby
/ PEX Piping Newby #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
I just bought a house and wanted to change out a sink only to find no water supply line shut off valves were installed under the sink.
I therefore need to turn off the water to the entire house and install some shut off valves.
The plumber used 1/2" PEX tubing, and I have never worked with PEX.
Is PEX easy to work with? What kind of tools are needed? Any tips or advice?
Thanks,
Yooper Dave
/ PEX Piping Newby #2
Pex is very user friendly, however it does require a hefty investment in specialized tools for crimping the fittings. Most big box stores sell the tools but beware there is a wide range of tool quality and best is better.
B. John.
/ PEX Piping Newby #3
Pex is very easy to do. I re-did most my copper and converted to PEX. I bought a crimping tool to $40 a Lowes. It is a ratchet type tool, you keep tightening until a light on the tool comes on, then release. I did over 50 connections, and had 0 leaks. Copper on the other hand, I once added a bathroom to the basement, and soldered 15 or so connections. Had to redo 50% of them!
There are 2 types of pex connectors, smooth rings and crimp rings. Smooth looks really nice, but you need a separate tool for each piping size. The crimp rings all use the same tool regardless of the size of the tubing. I went that route so I only had to buy 1 crimping tool.
/ PEX Piping Newby #4
Odd that there are no shutoffs installed under the sink!
Yeah, PEX is easy to work with and I've never had leaks in making many hundreds of connections. I have the ring tool -- was about $100 for the tool with dies for various size tubes when I bought it about 15 years ago. It uses copper rings. There is also a side-crimper tool that works with stainless steel rings. I don't have one of those, but it would come in handy in some situations where I can't fit the ring crimper, so I may get a side-crimper at some point.
/ PEX Piping Newby #5
Our house has copper so no experience with pex yet. The houses I've seen with pex were newer and had hot and cold manifolds in the basement with dedicated lines run to each faucet with individual shutoffs. Do you happen to have a manifold somewhere?
/ PEX Piping Newby #6
With exposed PEX under the sink, and no future plans for doing PEX plumbing, I would just use a couple of push-fit valves.
Bruce
/ PEX Piping Newby #7
That's a good point -- you can buy shark-bite fittings that just push on, no tools needed. I am told they are very reliable.
/ PEX Piping Newby #8
Bruce
Third vote for that. Your not enclosing it in a wall so push-fit is an excellent choice.
You do need a tool to cut the PEX unless you are going to gnaw it off :)
/ PEX Piping Newby #9
Old habits die hard. I am still a dedicated copper installer. Older houses all have copper so I am reluctant to mix it up on remods. Conversly on soldering; I have made thousands of copper joints in my life and have had very few leaks. most being in places where it's hard to get around the joint. I let the heat do the work of sweating all around. Then I was a profesional pipefitter for a good part of my life.
Ron
/ PEX Piping Newby #10
Ron
Ever work with propress? Expensive initianl investment...but great for fixing existing copper. No worries anbout a little corrosion or water messing with you when trying to sweat a fitting, and no dangers of flame in tight spaces
/ PEX Piping Newby #11
Same here with the crimp fittings. I wouldn't go back to copper.
Only caveat is to not use brass fittings when on well water due to the acidity of the water leaching the zinc out of the fitting. Which I didn't find out about until I had done mine......................Mike
/ PEX Piping Newby
Thanks to all for such good & quick advice. I feel inspired with sharktooth products. I watched their video and am going shopping as soon as the store opens.
Regards,
Yooper Dave
/ PEX Piping Newby #13
Super easy, did the entire house, less than $1000 all in. Apollo makes nice tools, 1 crimp ring tool for 4 sizes.
My go to is supply house.com and essential hardware.com.
/ PEX Piping Newby #14
Home Depot sells the crimper for the stainless rings for $29.99, and it will work with both 1/2" & 3/4" stainless rings.
Tool model# PTOOLC H.D. Internet # 303711230
Very easy to use.
H.D. also does sell the copper ring crimp tool for $59.92
/ PEX Piping Newby #15
Anyone use/experience Wirsbro/Uponer expansion type pex(a) system?
/ PEX Piping Newby #16
The issue with pex......complicated
Pex is just a generic term IMO. People say "use pex"....but there are so many different types of fittings/crimp styles. Makes it confusing unless you are in the trade.
YouTube is full of good videos comparing the different crimp styles
/ PEX Piping Newby #18
Seven local hardware stores I regularly visit have crimp PEX fittings. Only one has expansion fittings.
Bruce
/ PEX Piping Newby #19
I have crap CPVC in my crawl space and had 3 breaks over a 2 year period which made my life miserable. We have chert water (as the locals call it) and it is city water, which will rot copper out in a few years so everyone went to CPVC. I replaced portions of CPVC with PEX as needed but only had brass fittings so am concerned about brass rotting out. Now I see there are PEX plastic fittings that work and are 1/5 the price so I will go with those shortly.
I bought a tool with 4 sets of dies a few years ago but working in close quarters in a crawl space with a tool with arms that that need to be extended so the gripper can fit over the copper ring is something to be desired.
I am following this thread for info on hand crimpers that are easy to use in tight quarters. I asked HD or Lowes employees for such a thing and just get blank stares. Not there fault because unless someone actually used one, you just don't know.
S, if anyone knows of a crimper that will work in very close quarters like under sinks etc. using cinch rings, speak up. I really need to find out.
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
832736 (A61166)
832736 (A61166)
2020 MACK PINNACLE DAYCAB (A60736)
2020 MACK PINNACLE...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60352)
2019 Ford F-550...
2017 Ford F-550 Signalier ATR 45ft Bucket Truck (A61568)
2017 Ford F-550...
