Confession Time . . .
/ Confession Time . . . #1
Robbmatt
Nothing Yet
I知 a city slicker who has been lurking around here for awhile to get an education on what I need to buy for my new 8 acre farm in East Texas. I appreciate the insight you guys offer.
Here痴 my question . . .
I have a Branson dealer and an LS dealer within 10 miles of my farm. I am looked at both offerings and need to choose between two packages - the LS XG3025H, Ag-Meier Brave 5 brush cutter, 6 Armstrong Box Blade or the Branson 2400h, 4 ft. mower, 4 ft. Box blade, and 82x20 trailer. The LS deal comes in at $18,647 and the Branson deal comes in at $17,295. I知 wanting to stay under $20k.
I致e also looked at at Kubota L2510 but its on the high end of my price range.
I知 planning on having a few pigs, chickens, and a decent size garden. The property is fairly flat and in good shape with a long gravel driveway.
I know both of these are Korean tractors. I liked the LS but feel like I might get more bang for the buck with Branson.
Any thoughts from those of you with more experience?
Matt
P.S. I致e also looked at a Kubota L2510 but its on the high end of my price range. The financing options were attractive!
/ Confession Time . . . #2
:welcome:
To TBN Matt.
You came to the right place as we love to spend other people's money.
Be sure to test drive all tractors before buying one to make sure it feels right for you. The more models that you test drive will give you more of a feeling of what you really want.
/ Confession Time . . . #3
To be fair, my experience is mostly with Branson, however I've compared both when I was shopping for my tractor.
It seems that you are looking at two tractors of different sizes. I would say that the LS is more comparable to a 15 series Branson at least size wise.
The Branson has a really solid and robust construction. The castings are really thick and strong. It is also fitted with the Cummins A series engine. The tractor might not have loads of electronic features, but sometimes, simple is better, right?
Now the main I reason I went with Branson is that the dealer gave more money for the two tractors I've traded in and make me a good price on the Branson. If it was the case of the LS dealer, I would have probably went with LS. Same for any other brand.
I have a F36R, same as the 3515R in the US, and I've really enjoying it very much. It has 65 hours now. No power issues at all, really stable even though it sits higher than the competition and I've done some hard work with it.
That said, lets wait for someone to reply with LS experience.
I agree with mddorange opinion. It's better to test-drive both and see what suits you better.
/ Confession Time . . . #4
:welcome:to TBN.
Indeed take your time doing your home work also check out service department.
/ Confession Time . . . #5
I would drive as many as you can, even brands you don't think you're interested in. Can give you a better reference when it comes to making a choice.
Looks like both tractors have SSQA compatible FELs. The LS has a 3 range hydro compared to the Branson 2 range. It looks like the LS is heavier, and has better FEL and 3 pt lift stats. On the surface, I'd say the LS will be more versatile of the 2, and this is from a Branson owner (larger model though).
I think you should consider more attachments also, like a tiller for that garden, maybe a forklift attachment for the FEL, or possibly a landscape rake for cleanup and grooming the driveway. Also consider a couple of rear remotes and a 3rd function for the FEL. In case you want to add a grapple later for brush work, or run a blade with top/tilt functions. It's cheaper to add those up front then to have them added later. The tractor provides the power, but it's the attachments that do the work.
But make sure you "interview" your dealers too. You're not just buying the tractor, you're buying a dealer. You want one with a good reputation, that will be there when/if you need them. Good service after the sale is hard to put a $ on, but it's priceless.
/ Confession Time . . . #6
<snip>
I致e also looked at at Kubota L2510 but its on the high end of my price range.<snip>
So -
LS w/ 5' cutter, 6' box blade vs Branson w/ 4' implements vs Kubota w/ what?
If the LS can pull those in your conditions I'd say LS but what does Kubota offer?
The Kubota is essentially a "detuned" larger tractor to meet EPA regs.
LS is often viewed as a high end but "second tier" manufacturer, Branson is getting almost third tier.
What is your time span?
Are you 95 and this will be your "last tractor" or 25 and this is just a start?
Do you envision getting more acreage?
/ Confession Time . . . #7
In that size class the Kubotas don't cost much more than the others but the resale on them is a lot better. Nobody plans to get rid of their new tractor, but people sometimes realize they bought something too small or large or have a change in life plans (hit by a bus). In central Texas, small Kubotas really don't depreciate much from what you pay for them.
/ Confession Time . . . #8
Absolutely drive the tractors, don’t rely on paper specs and prices. One of them will jump out at you as a better fit.
/ Confession Time . . . #9
Often the package deal implements are the very cheapest ones. Cheap implements break more often. Do you really need a trailer? Unless you will be hauling to a remote location to do work it's cheaper to rent a trailer if you need to take the tractor to the dealer. Or have them pick it up. 10 miles is not far so the dealer's fee should be reasonable. If you do your own routine maintenance chances are good you'll never need to take the tractor to the dealer. Tractor maintenance is no harder than changing the oil on a car or truck (except you don't have to jack up the tractor to get under it).
There's a significant difference between 4' and 5' implements. If you have a large area to mow you'll appreciate the 5'. A 6' box blade may be a little large for that tractor if you want to use it to move dirt rather than level it.
Even though I have a Branson and like it a lot, I agree that Kubotas have better resale value. Around here to many people tractor = kubota. There's a lot of Branson dealers in Texas compared to here so more people may be familiar with them. I bought the Branson anyhow because it had a lot more features than the comparable Kubota, cost a lot less and is well made. And I liked the dealer. The Branson may lose a few $thousand in resale value compared to a Kubota, not 50%. All compact tractors have good resale because there's a lot of people who want them.
/ Confession Time . . . #10
Often the package deal implements are the very cheapest ones. Cheap implements break more often. Do you really need a trailer? Unless you will be hauling to a remote location to do work it's cheaper to rent a trailer if you need to take the tractor to the dealer. <snip>
But check around first and see what it takes to rent a trailer for your size tractor. Not only cash outlay but time and availability.
In Virginia I can rent a trailer for my B7610 easily. For my M4700 not so. In Mississippi for me to rent ANY trailer it's a 2 hour roundtrip drive.
And a trailer can be used for other things. I've probably put 15K miles on my trailer I bought in 2009 w/ my B7610. Moving tractors has only taken up about 4K of that. I've just now finished unloading from my last trip from Virginia to Mississippi. Lot's of tractor associated stuff inside but no tractor,
If you do get a trailer write PINTLE on the coupler. That way if someone wants to borrow it you can say it's a pintle coupler :)
Thanks for the info, guys!
We do have Kubota dealers all over the place. The closest one for me is about 17 miles away. The tractor they recommended was the Kubota L2501 HST, with FEL, Land Pride RCR12 5’ mower, and Land Pride BB05 Box Scraper. The cost for that setup would be $20,570.
This is my first tractor so I feel a bit overwhelmed by all the options. I’m 42 and plan on living on this property for a long time. Would you guys recommend looking at a used tractor? I’ve been a little hesitant because I don’t know much about tractors and am afraid I might not know what to look for when evaluating a used tractor.
/ Confession Time . . . #12
We do have Kubota dealers all over the place. The closest one for me is about 17 miles away. The tractor they recommended was the Kubota L2501 HST, with FEL, Land Pride RCR12 5 mower, and Land Pride BB05 Box Scraper. The cost for that setup would be $20,570.
This is my first tractor so I feel a bit overwhelmed by all the options. I知 42 and plan on living on this property for a long time. Would you guys recommend looking at a used tractor? I致e been a little hesitant because I don稚 know much about tractors and am afraid I might not know what to look for when evaluating a used tractor.
If you've wrenching skills I'd always suggest used if you have time.
It took me about 4 months to find my B7610 and maybe a year to find my M4700. My required repairs so far (/edit since 2009) have been hydraulics (hoses and a fixed cylinder) and tires. Probably $800 on tires and maybe $200 on hydraulics.
You didn't mention a trailer in the Kubota setup.
I just googled Kubota L2501 and this popped up:
Kubota L2510 Tractor Packages
KUBOTA L2501 TRACTOR PACKAGES
$18,849 CASH OR $19,349 FINANCED AT 0% FOR 84 MONTHS WITH 20% DOWN AND APPROVED CREDIT; SOME RESTRICTIONS MAY APPLY.*
Our Kubota L2501 Tractor Packages are perfect for several applications. There is a little bit of everything you need in this packages including the L2501 tractor with front end loader, front grill guard, 5 foot box blade, 5 foot cutter, and 18 foot trailer to pull it all down the road.
25hp Electronic Fuel Injected, Clean Burn Kubota Diesel
Bevel Gear 4WD Front Axle
"Wet" Multi-Disc Hydraulic Brakes
Power Steering
8X8 Synchro-Shuttle Transmission w/ Synchronized Forward/Reverse Shuttle
Optional 3 Speed Hydrostatic Transmission (+$1265)
Kubota LA525FL Front Loader w/ 60" Pin-On Bucket
Front Grille Guard
60" Land Pride Box Blade w/ Reversible Cutting Edge
60" Land Pride Rotary Cutter w/ Shear Bolt Driveline Protection
18’ Big Ram Trailer w/ Dual 3500lbs Axles, Trailer Brake, New Tires, Ramps, and Tie Down Straps
So your dealer may be a little high.
/ Confession Time . . . #13
G'day Mate and welcome to TBN from Downunder.
I've read both of your postings and noticed one glaring omission: What are you going to be using the tractor for? What is the 'biggest', regular job that you need the tractor to perform?
Enjoy the site.
/ Confession Time . . . #14
Matt, welcome. I'm sure you'll get great help here.
I started similar to you about seven years ago, bought some land and chose to get a tractor, without much experience. I went used/refurbished (older Yanmar). Can't speak for the newer tractors, but older tractors (mine is 38 years old) are really simple machines. There just isn't that much too them, and they're built tough. Stuff doesn't break easily, and if it does break, the repairs are often within the "handy" skill set. Maintenance is very straightforward. Help resources on this forum are excellent.
I'm going to upgrade to a larger machine, and I'll choose the best value that meets my future needs, whether new or used. Don't regret for a moment having previously bought used. That tractor has done great work for me over seven years. If you can find a decent used tractor with the right features to match your needs/planned uses, and it's used, and has been reasonably cared for, it's very much worth considering. Set aside some of your purchase savings for potential repairs, and get to work.
If you like the idea of dealer support and a warranty, and can afford it, that works, too.
/ Confession Time . . . #15
Don't be fooled by the resale ratings people say about Kubota and Deere as I honestly don't see it when the numbers are applied as a percentage of the cost when new. At least around here.
That is at least when compared to LS Kioti Massey I do however see a difference with Mahindra and the couple branson tractors but haven't seen any local sales of TYM so cant even guess at them.
I would lean heavily toward the LS when comparing the tractors mentioned but would definitely operate/test run all and not make a decision till I knew for sure which I would be most comfortable on.
/ Confession Time . . . #16
/ Confession Time . . . #17
I'm not in favor of any... but this is wise advice. The resale on Kubota's might really be worth the up front variance. You never know what might happen or what changes you might make. Also, Kubota's are so well thought of in most in most instances, that should you need information, parts, etc, there is likely some quick help available. Obviously, get your money's worth... but don't discount the depreciation too much.
This is coming from a JD owner.
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2014 JOHN DEERE 50G EXCAVATOR (A65056)
2014 JOHN DEERE...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
