Another MX6 Brush Hog Failure
/ Another MX6 Brush Hog Failure #141
/ Another MX6 Brush Hog Failure #143
Right at the snap ring--predictably failing for the better part of a decade now, with ZERO support, but they still manage to sell them. Comer is still making the same box with the bolt pattern shifted--so as not to be a direct replacement for Deere's. The company strategy seems to have shifted to entrapment from brand loyalty--what with the proprietary software and made only to fit part vendor requirements.
I picked up a Comer LF227J. The lower casting is the same mold, the upper box and gearworks are significantly heavier--rated for 150 hp vs 90, still 1.69 ratio, but required a lot of work to do. Being told by the dealer my best option was buying a new unit instead of the new gearbox and stumpjumper (2.5k vs 1.5K plus shop time)... I bought a MIG welder, gearbox and driveline instead... now the **** thing looks like a cat on a roller skate, and no more green attachments will ever go to this former customer. If these were Pintos--someone would have been in court--possibly jailed by now... Thank you for reminding me how little regard this massive company has for its smallest customers.
/ Another MX6 Brush Hog Failure #144
Thanks for heads up. I looked up the part on JD Parts and see there appears to be two different versions of the Bevel Gear. I believe mine is the Spanish version. If I can replace the broken part and get another 14 years out of it I will be better off repairing.
JD is probably twice the price of what I paid for my gear shaft. There should be a tag on your gearbox stating where it is made. From what I recall my top gear slid over the sahft on the China made box. I think the made in Spain box was one piece. I'd have to look at the parts again to be sure.
/ Another MX6 Brush Hog Failure #145
Well stated for sure with their proprietary parts. Craftsman did the same thing for many years on their lawnmowers and other parts.
/ Another MX6 Brush Hog Failure #146
My gear box is a DE19104. If I understand correctly I will still have to dig into the gear box to see if is a DE19106 13 Tooth or DE19304 15 Tooth. Once know for sure, should be able to replace just the Bevel Gear and possibly the related bearing, shim, snap ring, seal and cap hat if none of it is salvageable. Sound about right?
/ Another MX6 Brush Hog Failure #147
No intent to add salt to the wound. I honestly thought mine would be immune from this issue due to having run it 14 years without issue. Now that it has hit VERY close to home I certainly feel your frustration.
/ Another MX6 Brush Hog Failure #148
Was able to get gear box off of cutter and take a look in box. Counted 13 teeth on lower gear so that would clear up which gear is needed. Never attempted a project like this and pending cost may be better to replace. Any videos or guides on how these pieces come apart? Looks like there is still a piece to separate on the stump jumper. IMG_7417.JPG
/ Another MX6 Brush Hog Failure #149
My last Howse cutter blew the front seal several years ago. Before I caught it the gear sheared off going into the output shaft. The cutter had some age on it but had the square gear boxes which was newer than the older round units. How's had changed the output shaft just enough to not work. That done me in on them.
I just purchased a Titan 1810 that uses common gearboxes. The cutter is well designed and 1/3 the cost of Deere, Woods, or Bush Hog. The 10 foot Bush Hog cutters have a transfer shaft shock coupler that is proprietary to Bush Hog. Over 1K to replace. The Titan uses a more common disc arrangement.
I feel for folks who have these MX cutters. Very distrubing that Deere knows of the issue and is ambilvelent to the situation.
/ Another MX6 Brush Hog Failure #150
Found the parts and got them ordered this morning. Will update as the repair progresses.
/ Another MX6 Brush Hog Failure #151
Picked up cutter this morning. Got to mow with it this afternoon for couple hours. So far so good. The gentleman helping work on it was a little concerned with the fit and tolerances on the gears, but seems to be running ok.
Wound up finding output shaft gear and input gear for around $500 on eBay, had to order shim kit from JD for around $100 as gears were binding without them and paid gentleman helping $200 for his efforts. $800 an back working. If had it to do over, probably would purchase a new gearbox and just replace old one. Repair guy does a lot of work replacing decking and gearboxes on cutters and brought up good point could have had a new box with new gears, bearings, seals, etc... for what I spent on the gears. If this set runs another 14 years I will be satisfied and will just replace the gear box.
/ Another MX6 Brush Hog Failure #152
A John Deere gearbox will cost you more than double of what you spent. Plus you will need a new stump jumper. They sure got this deal rigged but good.
/ Another MX6 Brush Hog Failure #153
Might would have painted a new gearbox green to match.....but would not have been a JD gear box. Repair guy is somewhat of a machinist too. He didn’t think would be any problem making stump jumper work back.
/ Another MX6 Brush Hog Failure #154
Might would have painted a new gearbox green to match.....but would not have been a JD gear box. Repair guy is somewhat of a machinist too. He didn稚 think would be any problem making stump jumper work back.
I would consider the same if I break another shaft on my MX6. There has got to be a better and cheaper way of fixing these without using John Deere gearboxes. I think JD needs to come clean on these failures.
/ Another MX6 Brush Hog Failure #155
Put about 3-4 hours in this afternoon mowing Bahia field. Hearing some noise when first engaging PTO. Engage slowly around 1000 RPM and then increase RPM. Heard same noise when in thick grass. First thoughts slip clutch needed adjusting. Sound was similar to it slipping. Made sure to slip it before starting. Tightened up on clutch bolts and it did improve, but didn’t go away. Not sure if is actually clutches slipping or the new gears making a racket. Other than the noise, no complaints so far.
/ Another MX6 Brush Hog Failure #156
Use a paint marker to make a line across the slip clutch discs and later see if they are still in one line.
/ Another MX6 Brush Hog Failure #157
Tightened up on the clutch bolts, marked the discs and heard the noise for just a second. Checked and could see where clutch had slipped. Apparently I had backed off or the guy working on the mower had backed off the bolts quite a bit. In the past I had it set and just backed off a round or two to slip the clutch and then tightened the same number of rounds back and moved on. Puts me a little more at ease that the noise was only the clutch. No signs of seals leaking and seems like cuts like it always has. Glad to have this behind me.
/ Another MX6 Brush Hog Failure #158
So you guys really haven't found a box that will just mount back up on the JDMX6 cutter? I have the same issue, cutter has less than 100 hours easily. I priced JD and that's not going to happen and I found the same gearboxes at the Green Part Store for the exact gear box for 891.00 and a new version of that gear box for 891.00. My issue is I dont want to put this kind of money in something that I don't even know if the casting problem was fixed. I did find the shaft kit on ebay and that vendor told me he had sold over 1000 of these kits to fix the MX models. JD has not responded to me at all on this matter but you would think they would want to at least admit there is a problem. I will most likely buy a USED bush hog that looks like it want last because those usually last forever.
/ Another MX6 Brush Hog Failure #159
View attachment 611822View attachment 611823View attachment 611824View attachment 611821
If you have welding capability, or a shop nearby, one can mount almost any gear box on any mower, just drill and plasma (or torch) cut hole for new box on a 3/16 or 1/4 sheet of steel and weld that to the old deck. Stronger than new with minimal fabrication.
/ Another MX6 Brush Hog Failure #160
Yes, BUT lookout for mounting depth and assumption of shaft length down to the stump jumper. Doing as bumperm says you'll end up having to replace both the gearbox and the stump jumper unless very selective. The mounting bolt pattern distance down to the stump jumper must match and of course the gearbox output shaft and stump jumper have to mate well. (duh,... obviously.) In fact I supplied a used gearbox to a friend who mounted it on his old bushhog and tried exactly what you describe. The blade carrier would not clear the body of the bush hog. Had to start over.
BY THE WAY This being a very OLD thread, I just studied what I had said on it several years back & others comments. See post #129. This does NOT help/fix your dilemma and expense. I do think I have a better idea now of the reason for the widely reported MX6 problems. I am amazed that I see no other post in all that long sordid history that mentions this. (I could have missed it during review...)
I think that the MX6 problem was due to the design combined with users not rechecking tightness of the bolt holding on the stump jumper. The design is that one center bolt holds the whole thing on -- WITH NO KEEPER AND NO COTTER KEY AND NO CROWN NUT. That bolt is supposed to be torqued as i recall to 450ft-lbs. How many users will check that once in a while ? ALMOST NONE. Unless the user gets out his larger high rating air wrench he has no way to get 450 ft-lbs on that bolt. Those without such an air wrench will probably not find a long enough cheater bar. End result: The stump jumper and blades are going to fly off at some point (!) I used mine back in the 2001-2011 period and had around 300-400hrs on it. The stump jumper never flew off until I had used it for several years. Came off several times before I wised up, read the torque specs, and finally used a long enough cheater bar ! (And that is enough to break most 1/2" socket sets ...go find your 3/4". )
Bottom line: I am convinced that the bad rap on the MX6 was because:
-- the unsecured bolt that holds on the stump jumper came loose (eventually, just a matter of time) on a large number of machines
-- in some cases (like mine) I was lucky enough that it never broke the shaft
-- in many cases (reported on this thread and others) when the stump jumper came loose and went flying the weight of it hit the side of the hog body or something else and hit the output shaft with a huge shock of sideways force -- enough to crack or even break off the shaft.
That's how I think so many of them got broken. Pee poor design without any cotter key or way to prevent loosening of the center bolt. Unrealistic dependency on users to periodically check tightness, especially to a torque figure they cannot achieve with their socket set. That's my theory.
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2020 Cushman 1200X Gas Utility Cart (A66734)
2020 Cushman 1200X...
2013 C&M TRAILER T/A 20 UTILITY TRAILER (A67714)
2013 C&M TRAILER...
2009 ALLMAND  MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2020 Chevrolet...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
