Buying Advice Evaluating options for a compact
/ Evaluating options for a compact #41
I can answer that one. I've had both types of transmission - in fact I have both types now (again).
HST is much nicer than a shuttle for hilly country, icy slopes, as well as much better for using the loader. That's because with the HST, when you take your foot off the treadle all tractor driving force stops. Any momentum that the tractor has simply disappears.So reducing the treadle acts like it puts on the brakes as you reduce the drive. Completely off and no drive at all, and it doesn't even want to roll. My Kubota HST also automatically adjusts the throttle to compensate for any motion of the treadle. The throttle can be adjusted separately, but you don't have to.
With a shuttle-shift, the throttle is separate. But more importantly, with a shuttle you are always in gear unless you deliberately shift into neutral. So as you slow down it doesn't want to stop. You are still in gear even if you reduce the throttle. So to come to a complete stop or just inch forward with a shuttle you need to either shift into neutral, tap or stand on the brakes, or shuttle into reverse and go backwards.
Now for use on long straight sections like a huge lawn or a farm field the shuttle is nicer because you can just set the throttle, select a gear, relax, and just continue on without any foot or hand control needed.
rScotty
Yeah that's a great way to explain it. The HST is completely intuitive to me, even without big-tractor experience, and the only option in our tight woody areas. (BTW, I'd totally be comparing Kubota's too if we had a dealer within 2 hours....)
Everyone around here has pretty much our terrain; even the "farmers" have big hills. So there is no big-scale farming here, like what you said, no long flat fields. Just a few happy black angus grazing on lush green hills, and folks raising alpacas and arugula and other weird, small-scale, specialty type stuff. Probably why the shuttles weren't as popular?
/ Evaluating options for a compact #42
I know everyone has their opinion but IMO a B2650 might be perfect for you. After considering just how much tractor I needed I moved up from a 21hp to my B2650 and it works just fine. I love the ergonomics, controls, low rpm power, comfort, it runs a 5' rotary cutter, 6' mid mount mower, pulls a 72" rear blade, and the FEL can (just) lift the 60" "light duty" bucket when completely full of gravel. I like that it's relatively light for when I'm on my lawn and trails yet with the ballast box and FEL on it's heavy enough to drag tree trunks and such anywhere I need to.
Most of my 150 acres is wooded so I have maybe 4 acres I cut with a zero turn, but the B2650 takes care of everything else which includes bush hogging 8 acres every Fall, moving felled trees and cleaning up limbs and debris with the grapple, maintaining the 900' gravel driveway, and digging up rocks and invasive brush.
My final thinking (and I went back and forth) was to not buy a larger class tractor plus spend big $ (and devote storage space) on a back hoe, instead just pay someone with a big machine to do those tasks if ever needed.
Whatever you buy I would strongly recommend you get a third function hydraulic and the SS Quick Connect FEL at the get go because you mentioned a grapple for the future.
I like the fact that it sounds like it's enough tractor for you, but I think I'm pretty set now on getting something bigger. There were a few posts about the 25hp maybe not being enough when working on hills, with FEL and BH on it. The consensus is that I want more weight too. I've dropped the idea of mowing with the tractor entirely. At first it sounded like a good idea, one machine to handle everything, but for the cost of the mid mount mowers on these machines, I could just get a new riding mower or maybe a bigger zero turn than what I have currently, that has a bit more power for the hilly parts of the yard.
As far as a backhoe goes, I'm pretty sure I have enough tasks lined up for it, that it would pay for itself in the first couple years, compared to renting. The 3rd function is a must, like you said for a future grapple, and likely a future snow blade at well.
I was hoping to get to more dealers, and maybe have a purchase lined up this week, while I'm off....but as luck would have it, another unexpected project came up, so it looks like the rest of my week is shot. I do need to make a decision by the end of the month though, because if I choose to go with Mahindra, they have some really good incentives right now, dealer said the 1500 tractors were 5200 off msrp, and another 800 off if you purchase 3 implements (which includes FEL, BH, rotary cutter). He said that's one of the best incentives they've had in a long time.
/ Evaluating options for a compact #44
You might want to do some research on the B3350 regarding issues with regeneration. Many folks have had issues and some dealers wouldn't even sell them. Some claim Kubota has fixed the issues. I have no first hand knowledge if it is fixed or not and just want you to investigate before considering purchasing. Look in the Kubota forums.
A Grand L tractor sounds more appropriate for your intended use.
X2 moship.
I would definitely not consider buying a B3350 used, or even new off the lot. From reading various forums : some have no problems, some have had the regen issues fixed, and some have had there machines at the dealer for months with no end in sight.
For the OP;
I had an L3410 for years and it served me well. Now in my mid 50’s, I went with an L4060 cab for the comfort while snow plowing. The L4060 cab comes in at about 4000 lbs bare, 6500-7000 lbs with filled rears, loader, and plow. Weight is king for snow removal.
Have fun shopping!
/ Evaluating options for a compact #45
One of the Kubuota dealers I talked to discouraged me from the 3350. I'm glad I got a larger tractor than that. It seemed huge compared to my B7100 at first but now it's normal. And it'll really lift stuff. I wouldn't mind a Grand L with the high/low splitter trans but that was a significant amount more than the Branson I got.
BTW the Mahindra rotary is a rebadged US made Kodiak. I have one, I like it.
/ Evaluating options for a compact #46
Sounds like you know what you want. And I agree with the FEL, 3rd function, HST, and higher wt&HP.
Too bad there's not a Kubota dealer close enough....not because they are good or better tractors, but because they are the only mfg who makes a compact dedicated Tractor/Loader/Backhoe with the 3pt as an accessory. As you are not going to mow with your tractor, the TLB offers a lot of advantages over a dedicated 3pt machine with the Backhoe as an accessory. They are higher priced than 3pt tractors though.
Congratulations on considering getting a backhoe. We use ours more than any other implement, even though it is usually as a crane, a counterweight, or for picking up something and placing it carefully more than for digging in the ground! As for the cost, it is negiligible compared with the price of the property. And the fun of working on the property is why we bought land in the first place.
If I can offer another suggestion, I have one backhoe with a thumb and one without a thumb but with a cab. The one with the thumb gets used far more often. A backhoe with a thumb does things no other machine can. It lifts and places rocks - which I will admit is huge for me because we have so many rocks here. But a thumb lifts tree trunks for the chainsaw, and generally can put and place oddly shaped things that I once lifted by hand. Consider a thumb, and perhaps check that your backhoe choice has the option of a thumb in the future.
It is time to have a look at Mahindra models online tonight. I just don't know their offerings. That's a gap in my tractor knowledge that needs filling.
rScotty
/ Evaluating options for a compact #47
..., but because they are the only mfg who makes a compact dedicated Tractor/Loader/Backhoe with the 3pt as an accessory. As you are not going to mow with your tractor, the TLB offers a lot of advantages over a dedicated 3pt machine with the Backhoe as an accessory. They are higher priced than 3pt tractors though.
Can you elaborate on the difference between a 'dedicated TLB' and a tractor w/ a back hoe 'accessory'? Maybe an example? Thx!
/ Evaluating options for a compact #48
/ Evaluating options for a compact #49
Sure, glad to...
OK, first of all, I've always been a tractor guy, but got into TLBs almost by mistake when my wife said it was time for a new tractor. I was floored when she said that, but didn't dare argue - and so off we went on a new tractor hunt. After several "ecstatic"? weekends looking at tractors & not seeing what we wanted, it finally dawned on me that I wasn't raising crops anymore. In fact the work we were doing on our land had more in common with landscaping.
So we started thinking about landscaping and that led to TLBs. Both tractors and TLBs of roughly the same size often share a common engine and transmission. But there are lots of differences.
Comparing tractors with TLBs, the tractor was originally designed to be a pulling machine. It evolved to optimize pulling implements, which is why the 3pt hitch was so important, and why all tractors have them.
Eventually tractors became better & better at pulling. Concentrating on pulling ability dictated things like how the tractors weight is distributed, the transmission type, the size of the rear & front tires, tread type, the control layout, and even the way the frame is stressed.
The evolved tractor is so versatile today that it can even hold a backhoe and work a front end loader as optional implements on each end - Even though it isn't really designed for either. It was designed to pull implements with its 3pt hitch.
The TLB (Tractor/Loader/Backhoe) was originally designed around a loader at the front and a backhoe behind. It evolved as a pushing machine because that is the best use of the front end loader. And it had to be stout to withstand backhoe forces. A TLB typically has a much stronger frame and more stability because the TLB's weight distribution, transmission, drive train, tires, controls, and frame are designed to support pushing, lifting, and carrying things with the frame mounted front end loader on one end, and then by reversing the seat the operator can still operate some tractor controls along with the frame mounted backhoe. Both the FEL and the BH can be somewhat larger than a similar tractor because of heavy TLB frame.
Then by un-hooking the backhoe the the TLB can quickly mount a 3pt hitch and become a pulling machine - much like a compact tractor can drop its 3pt hitch and mount a backhoe and subframe for digging. It's about the same effort to swap either way.
So a tractor can drop its 3pt and mount a backhoe with a subframe. And a TLB can drop its backhoe and mount a 3pt hitch. Each one does what it is designed to do very will - and each is versatile to do a decent amount of what it wasn't originally designed to do.
Some TLB downsides: Kubota is the only company currently making a compact TLB, and the overall heavier, more stable construction of the TLB that makes work as it does also makes it more expensive than a similar sized tractor. An upside is that Kubota makes very good and reliable TLBs - the B26, (L39), L47, and M62.
Hope this helps, and maybe even spurs some debate,
rScotty
Went to another Mahindra dealer today, just to have a look at their inventory, since I heard they had the new 1600 series tractors. They had 3 of the 1626's, 2 with backhoes on them. Looks VERY similar to the previous 1526, with the 2 most noticeable differences being the seat, and the loader joystick location. There may have been other differences as well, but those are the main things I noticed. That seat makes a huge difference in comfort.
I'm more interested in the 1533 or 1538...which they didn't have, and the guy I talked to was a little confused about how the new 1600 series is replacing them. He said from what he's seen so far, it might only be a 25 and 40hp version, said he's seen no 1633 or 1638.
I had him print me out a quick quote on the 1526 and 1538. They were busy, so the quote is just for tractor, FEL, and BH. Cash price without tax, was just under 24k for the 1526, and just shy of 28k for the 1538. That's already discounted from MSRP, but I assume there's still some room to haggle a little bit, especially when adding additional implements, filled tires, 3rd function, etc.
Still haven't been to Kioti or Yanmar, but the more I look at these Mahindras, the more I think I like them. How much more room do you guys think there is to haggle, when I'm ready to make the purchase?
/ Evaluating options for a compact #52
I just ordered a Land Pride RCR2660 Rotary Cutter, weight 1,002 pounds. Delivery promised May 18/Friday.
I spent about five weeks contemplating heavier R/Cs and pressure washing and selling the Land Pride RCF2060 Rotary Cutter I had.
Before I formally ordered the RCR2660, the price increased $300 due to steel price increases to Land Pride.
Beware waiting toooooo long.
Old models needing a home may be deeply discounted.
New models perhaps half the discount on old models. (??)
The NE seems to have the highest regional tractor prices in the US, partly influenced by freight from mainly Georgia ports of entry. Spring is when tractor and mower demand is highest. Lowest net tractor prices are often when snow is on the ground.
No one can give you a very useful reply in your environment.
/ Evaluating options for a compact #53
...I'm more interested in the 1533 or 1538...which they didn't have, and the guy I talked to was a little confused about how the new 1600 series is replacing them. He said from what he's seen so far, it might only be a 25 and 40hp version, said he's seen no 1633 or 1638.
There's the 1626, as you saw, and an upcoming 1640, which will be larger (similar to the current 1533/1538). The new 1635 will be a 35hp, but on the smaller frame of the 1626 (I'm guessing otherwise identical except for HP). Source - 2017 Mahindra Dealer Meeting: Part 2
I liked the Mahindras as well, and was really interested in the 1635, but came across the Kiotis while waiting and will now be taking delivery of a CK3510se next week.
Cool. I think that 1635 might be what I want then. Shame the guy today wasn't aware of it. Let me know how you like the Kioti, I haven't been there yet, but there and Yanmar are still on my list to look at.
/ Evaluating options for a compact #55
You've read the Mahindra horror story threads right?
Just make sure your eyes are wide open to false ecomomies.
I read through a couple threads where people had issues, nothing that sounded like a horror story to me though...perhaps I didn't read the ones you're talking about.
/ Evaluating options for a compact #57
No doubt everyone has a "favorite". After looking at a handful of tractors, I ended up creating a spreadsheet where I could list all the specs that were important to me.
I have 20 over hilly acres in TN. Ultimately, I believe a heavier tractor will give you more traction and for hills and snow traction is what you want.
I ended up with a Branson 3725H. There are always compromises and there isn't the side and deep dealer network for Bransons as exist for other brands but they were, to me, superior in enough other aspects that it made my decision easy. You might want to add them to your list.
+1. It was an easy decision for me to go with Branson as well for my bigger tractor.
/ Evaluating options for a compact #58
Unfortunately, there's no Branson dealers anywhere even remotely close. I've read good things about their tractors, but I've also read that service and parts can be severely lacking. That combined with the distance to any dealer, would make me very hesitant.
Yes, I totally understand that. Having a good dealer nearby is important no matter what you buy. I get my parts from Big Red's with no issues at all. I do my own service so it's less of an issue.
/ Evaluating options for a compact #59
I'm definitely trying to get the right machine here, so I don't have to sell anything in the future. I'll spend some time this week looking at the other brands and see where I end up. Maybe I'll go back to one of the Kubota shops too, and look at the L again. I don't want to get something too light or underpowered. The B2650 really felt right to me when I was sitting on it....but it's impossible to compare driving around a flat empty field vs what it would be like on my property.
Don't just look.
Test drive them as well.
Operate the FEL, the 3PH levers, pto controls etc.
In essence sit n the cockpit and get familiar with the layout and see if it's a good fit for you.
Should not necessarily but sole decision maker but should be a consideration since you will spend many hours of future seat time.
Just like autos, they all do not fit nor feel the same.
Enjoy the hunt it's part of the fun, then delivery, then cranking her up.....well you know ...heh....trying to look serious so wife doesn't tell yah having fun with your new toy???? .... heh....
.. then you giver her a serious hurumph and tell her it's a tool....as you drive off with that big grin..
/ Evaluating options for a compact #60
I don't know if someone suggested that you can check out the Massey Ferguson line of tractors I have a GC1705 and I have had no problems with it and my dealer got me a good deal which was about 3,000 less than the orange and green tractors just a suggestion but good happy hunting and get the one that fits you and will do what you need it to do.
2015 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2015 Autocar...
2015 CATERPILLAR D6T LGP HIGH TRACK CRAWLER DOZER (A65056)
2015 CATERPILLAR...
2014 Ford F-350 Altec Service Truck (A66736)
2014 Ford F-350...
ALLMAND MAXI-LITE II V LIGHT PLANT (A68842)
ALLMAND MAXI-LITE...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
2022 LEVEL BEST GB100 108" HYD GRADER BLADE (A65053)
2022 LEVEL BEST...
