Buying Advice Evaluating options for a compact
/ Evaluating options for a compact #1
NYCheese
Near Binghamton NY
Kioti CK3510se hst TLB
First post on here, but I've been reading a ton on the forums, reading reviews, etc. I'm shopping for a new compact to handle a variety of tasks on the property I recently purchased. It's 37.5 acres of upstate NY hillside. Most of it is wooded, and I do plan on harvesting firewood. My primary needs are:
Gravel driveway maintenance and snow removal.
Clearing overgrowth and lots of goldenrod/ragweed (rotary cutter)
Firewood harvesting and hauling (I have a small wagon for hauling cut wood back to the house)
Installing better drainage in multiple areas of the property
Building/grading trails through the forest to aid in timber harvesting.
Implements needed:
FEL
rotary cutter
box blade
backhoe (this could be purchased in a year or two, if it breaks my budget currently)
front snow blade (same as backhoe...I can use the FEL for snow in the interim)
grapple (again, this can wait, but would be very nice to have at some point)
One other implement I've been considering is either a mid mount mower, or a rear finish mower. I currently have a small JD zero turn, but it struggles on some of the slopes here. I don't know if I want to be mowing with a larger tractor, but my current mower just isn't heavy or powerful enough.
All that said, I've looked at a few machines, all under 26hp, to avoid the added costs of the new emissions regs. My current frontrunner is the Kubota B2650hst. I also looked at the L2501, but the B felt like a much nicer machine, even though it is a bit smaller and lighter. I'm waiting on quotes from 2 area dealers, but both of them told me in person, right around the 30k mark, for the B2650, with FEL, backhoe, 5' rotary cutter, 5' box blade. One of them was also going to include a mid mount mower in the quote. No grapple or snow blade will be in either quote for the time being.
I really liked this machine. It was comfortable, not too loud or too much vibration, I think it's the right size for what I'm looking to do. But...I want to be smart about this and comparison shop. Having a little trouble online finding what models from other brands would be the most direct comparisons. I'm thinking about looking at Mahindra max26xl, Kioti ck2510 or 2610, Yanmar 424, but having not seen them in person yet, I don't know if I'm even looking at the right models to compare to the B2650. Anyone have any opinions or suggestions on what else I should be looking at? I have most brands available within a couple hour drive (LS and TYM are the furthest away, but still do-able). I might very well wind up buying the Kubota, (I really liked it), but if I could get something comparable at a better price point, it might leave more room to buy all of the implements on the list.
/ Evaluating options for a compact #2
The Kubota L2501 4WD is what I think you really want. Why? Slopes and backhoe.
The wider stance of the L2501 is a real asset on slopes along with 4WD. Kubota also has a 0% interest 84-month offer right now which is really attractive if you aren't an all cash buyer.
You will want a backhoe that can lift and reach farther so, that's an easy one for an L over a B/BX (or similar). I say this after running a 35HP Kioti with Backhoe and wishing I could lift heavier wood from a bad location or dig harder, deeper and/or farther.
The same goes for an 'L' sized loader. With a skid steer set of pallet forks, it is a real winner for chores in general. Plus, moving dirt (or snow) with a bigger bucket and higher lift capacity lets you finish faster.
Larger tires are also a factor many overlook. On unprepared ground, the L tire size will easily roll over ruts, washouts, branches, etc. without tossing you around nearly as much as a smaller tire size tractor.
In the end, total prices are very similar for all your options assuming similar specs. The larger tractor could be an issue around buildings and around trees that a smaller tractor might navigate more easily though so, it really depends on your intended use and landscape as to which is really best.
Finally, don't get suckered into lusting after something sitting on the dealers lot with a few bells and whistles that aren't really needed for your use. You are looking for a "tool" to get a job done not, a "show piece" to brag about in front of your favorite watering hole. ;)
/ Evaluating options for a compact #3
:welcome:
To the TBN forum Mr. Cheese. You have come to the right place as we love to spend other people's money.
When I went into the dealer to purchase, I was looking at a "B" just like you. After my dealer heard how I would be using it, he said I would be back in a year to get a bigger tractor so I followed his advice and went with an '"L." Not only am I glad I did, but now I wish it had been an even bigger L. The more stability and weight on the hills is a must. The better lift for FEL working with trees is a must also. Yes, I have a 5' medium duty rotary cutter, and a 5' box blade also.
No matter what you get, it must have filled tires.
Keep us informed as you go along.
The L2501 is actually what I had in mind when I went to the first dealer to look. The L is like 800lbs heavier, which I see as a plus, especially in the winter. The single biggest turnoff for me on the L was the seat. I wasn't really concerned with the controls not being quite as nice as the B, but I drove both machines in a big yard behind the dealer, and the L was a MUCH rougher ride, and just not comfortable. The L they had me drive was just a bare tractor though, the B had a FEL and box blade on it, so I don't know how much that could've changed the ride comfort. But since that's 2 of you suggesting the L, maybe I should go back and have another look.
If looking at the L, I assume the models I mentioned from other brands wouldn't really compare? Can you guys suggest what else to look at there? I'm off all this week, and wanted to start test driving tomorrow. Kubota and Mahindra are right here in town, Kioti and Yanmar about 30mins away.
/ Evaluating options for a compact #5
NYCheese
I recently purchased 37.5 acres of upstate NY hillside. Most of it is wooded.
It would be helpful to know total acres NOT wooded that you will operate tractor over.
Consider adding rear wheel spacers if you decide on a light tractor.
Heavier tractors have designed in adjustable rear wheel widths.
My instinctive reaction to seeing a property size of 37.5 HILLY acres is a 4,000 pound bare weight tractor.
VIDEO: Kubota Grand L Series VS. Kubota MX Series - YouTube
How long is the driveway? How much snow, how often? Worst snow in last five years?
Will this be your residence, so you have to get out to work? Or a weekend/retirement property?
And a Ratchet Rake bucket attachment.
VIDEO: ratchet rake brush clearing - YouTube
Photo #1, #2
Most, however, would use FEL bucket, sometimes with forks.
Other Photos.
Installing better drainage in multiple areas of the property.
Agricultural tile? Or simply ripping compacted soil? Other?
Chainsaws, Ratchet Rake, Rotary Cutter, Box Blade.
Implements needed:
FEL
rotary cutter
box blade
$7,000 You have not expressed a task necessitating a $7,000 Backhoe. If you operate it ten hours per year, it is quite expensive.
L2501 is not available with mid-PTO.
Twenty-five horsepower is the demarcation point, not twenty-six horsepower.
Are you considering an open station tractor or a cab tractor? Cabs weigh 500 to 600 pounds.
The B2650 and B3350 are deluxe models, like Kubota "Grand Ls".
B2650 has twenty-six horsepower, complete Tier IV emission controls.
VIDEO (2): Kubota B5-Series tractors, B265 & B335. Review and functions | Messick's - YouTube
How to clear snow using your loader - Kubota B265 Cab Compact Tractor - YouTube
L2501 is a sparely equipped "Standard L".
I really liked this machine. It was comfortable, not too loud or too much vibration, I think it's the right size.
Shop by bare tractor weight. B2650 open station is 1,786 pounds; with cab 2,293 pounds.
With a Backhoe and Cab a B2650 will not have enough power for hills, at least not for me. Nor will L2501 with FEL and Backhoe have sufficient power for hills unless you are very patient. Few are patient after week #2 of operating.
Consider B3350 with 33-horsepower; open station 1,896 pounds; with cab 2,447 pounds.
I'm thinking about shopping Mahindra max26xl, Kioti ck2510 or 2610, Yanmar 424, but having not seen them in person yet, I don't know if I'm even looking at the right models to compare to the B2650. Anyone have any opinions or suggestions on what else I should be looking at? I have most brands available within a couple hour drive (LS and TYM are the furthest away, but still do-able). I might very well wind up buying the Kubota, (I really liked it), but if I could get something comparable at a better price point, it might leave more room to buy all of the implements on the list.
Shop by bare tractor weight. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models.
Shop Yanmar YT235.
BUY ENOUGH TRACTOR​
Selling a used tractor is easy. Selling light implements in order to buy heavier, wider, implements for a heavier tractor you eat more depreciation on the implements than on the tractor. Passing time with multiple implement browsers is a pain. ((Ask me how I know.))
NYCheese
I'd guess less than 10 acres that isn't wooded, but most of that is overgrown with different vegetation. Nothing very big at least, maybe some 1" sapling scattered around, nothing a rotary cutter can't handle.
driveway is approx 150ft, with a parking area big enough for 3-4 vehicles, all gravel. Snow varies a lot up here, I think the yearly avg is 80-100 inches. Last year we got a big one that was 32 inches in a day, but the last time we had anything like that was 30+ years ago.
Photo #1
Haven't planned this out yet really, so not sure exactly what it'll be. I know for certain that I need to dig a couple ditches, maybe a french drain type solution, to keep some of the spring runoff out of the yard, and further away from the house. Will probably involve putting a culvert under the driveway as well.
Good to know, but this isn't really a driving factor in my decision making. I do need something other than my JD mower, but I don't want to tear up my yard mowing with a big tractor. Just something I thought I'd look into a little bit.
I was under the impression the B2650 did not have the new emissions stuff. One of the dealers actually pointed out the difference on the hood between the 2650 and 3350 (the 3350 has a raised hood scoop to make room for the extra components). I haven't ruled out a cab completely, but I'm thinking since I'll be spending lots of time in the forest, the cab would just get in the way. It'd be nice in the winter though.
The B2650 and B3350 are deluxe models, like Kubota "Grand Ls". L2501 is a sparely equipped "Standard L".
With a Backhoe and Cab a B2650 will have BARELY enough power for hills. Nor will L2501 with FEL and Backhoe have sufficient power for hills unless you are very patient. Few are patient after week #2.
Consider B3350 open station 1,896 pounds; with cab 2,447 pounds.
Yeah, I don't like the sounds of that! One of the dealers was telling me that once you pass the 26hp mark (he said 26hp, not 25, I don't know), that there's a significant price jump due to the new emissions equipment, and that 26hp would suit my needs well. Perhaps he was just trying to sell a specific machine, but the 2nd dealer didn't really tell me anything different, so I don't know.
Shop Yanmar YT235.
BUY ENOUGH TRACTOR​
I'm definitely trying to get the right machine here, so I don't have to sell anything in the future. I'll spend some time this week looking at the other brands and see where I end up. Maybe I'll go back to one of the Kubota shops too, and look at the L again. I don't want to get something too light or underpowered. The B2650 really felt right to me when I was sitting on it....but it's impossible to compare driving around a flat empty field vs what it would be like on my property.
/ Evaluating options for a compact #7
The "regulars" posting here know more than 99.44% of tractor salesmen you will meet at a dealer.
"It would be helpful to know total acres NOT wooded that you will operate tractor over.
I'd guess less than 10 acres that isn't wooded, but most of that is overgrown with different vegetation. Nothing very big at least, maybe some 1" sapling scattered around, nothing a rotary cutter can't handle."
Consider the B3350 in lieu of B2650. B3350 may do for ten acres. You may want to dismount Backhoe when anticipating hill work.
Also consider my model, L3560/HST/PLUS, 3,494 bare tractor open station, 4-WD, 37-horsepower.
Backhoe BH77 for B2650/B3350 weighs 850 pounds. BH77 weight will give you traction but there is only so much 26-horsepower can accomplish going up hills.
B2650 bare tractor, open station 1,786 + BH77/850 pounds + LA534A/820 pounds = 3,456 pounds.
There is only so much 26-horsepower can do.
Shop your weight range within tractor brands. Budget will eliminate some choices. Collect a dealer brochure for each tractor model in your weight range. I spreadsheet tractor and implement specs, often a revealing exercise. I have a column for cost per pound.
OPEN STATION or CAB? We need to know.
Sorry, thought I answered that, kinda got lost in the formatting with the quote though. Probably ROPS. Cab sounds nice for the winter, but a large part of my use is going to be in the forest, and I think a cab would just get in the way, and break windows.
I will look at the 3350 if I go back to Kubota. Unfortunately the local dealer didn't have that one, but the other dealer is only 40mins away.
/ Evaluating options for a compact #9
You might want to do some research on the B3350 regarding issues with regeneration. Many folks have had issues and some dealers wouldn't even sell them. Some claim Kubota has fixed the issues. I have no first hand knowledge if it is fixed or not and just want you to investigate before considering purchasing. Look in the Kubota forums.
A Grand L tractor sounds more appropriate for your intended use.
/ Evaluating options for a compact #10
Woods and grapple and hills to me means you need a tractor with some weight, 3000+ lbs bare tractor would be good. Cutting and moving trees requires a good amount of loader lift ability and enough weight to counterbalance it.
I'd be less concerned with tier 4 emissions and more concerned with getting a machine that's going to serve you well long term. A $30K budget can get you a lot of tractor.
/ Evaluating options for a compact #11
The only difference is horsepower via addition of a turbocharger and the hood scoop. Do not bother.
Seems like everyone here is saying the same thing. I'm going to the Mahindra and Yanmar dealers tomorrow, to see what they have to say. Both Kubota dealers made it seem like the B2650 would suit me well, even though I was a little concerned that it's 800lbs lighter than the L2501, which is still less than what is being recommended here. I really dont' want to purchase something that is going to struggle with what I need it to do. I'll post again tomorrow, after I see what the other dealers try to put me in.
/ Evaluating options for a compact #13
Only now is it understood that of your 37.5 acres only 10 acres is potentially open land. The 27.5 acre balance is woodland.
/ Evaluating options for a compact #14
37 ACRES IS A HUGE AMOUNT OF LAND. I think the TBN advice you are getting to look to the next size larger is correct. It also allows you to step up to medium size implements - and you will get a lot more use from those medium size implements than the smaller size. That is a larger step up than you know right now.
I think that 26 hp is fine for most of your jobs. But the difference is that a larger machine will make 26 hp at half throttle. Out in the field isn't it a whole lot nicer to listen to a larger tractor snorting and working at half throttle than a smaller tractor wailing away at full chat?
Can you rent something for a weekend?
Here's an important point not often mentioned: Most machines give you a choice of tires: Ag, Industrial, or Turf. Turf have the best ride, and Ags the best traction but worst ride. Industrial tread is the compromise that most commercial operators choose. Industrial tread is also noticibly more stable on a hillsides or with weight in the loader bucket. It costs little to choose a different tire type when buying a tractor, but because each different tire type requires a different rim it is hugely expensive to change later.
I have finally come around to preferring HST to all other transmission types, but do want it to have at least 3 ranges. If you are comfortable with a standard gear-driven manual transmission you can save enough to buy that backhoe and maybe even put a thumb on it. For me that would be a no brainer. Most of the time you are NOT changing gears when operating a tractor. You pick a gear and stay in that gear for awhile. What you are doing is working the clutch quite a bit with your left foot. With HST you are working the HST pedal quite a bit with your right foot. It's about the same.... On neither do you change throttle setting all that often.
For your first tractor, IMHO you will learn more and be more comfortable in amongst trees and hillsides if you have an open station rather than a cab. On medium size and larger tractors the seats can be changed. There are threads on that. A suspended and damped seat with better padding is in the 6 to 700 dollar range. A pneumatically "air ride" type is about twice that. Some of the younger members won't understand why I find the seat options so important, but older TBNers will.....
Good luck on the search,
rScotty
Just to be clear, your advice is something 3000+ bare tractor weight, or 4000+ with attachments?
Also, you said in one of your posts to have a look at the B3350, but then in another you said don't bother.....little confused, but I'll put it on the backburner for now anyway, and hit other dealers first. Thank you for taking the time to share your advice.
/ Evaluating options for a compact #16
I have 20 steep brushy/wooded acres here in coastal California. My first tractor was a Kubota B7100HST. I could mow with a small (42") rotary cutter, pull up small brush and move dirt a little at a time. It was ok until I got serious about maintaining the land and clearing some of the brush that's grown in the last 60 years. The initial driver was getting a larger PTO chipper- for that I needed more power and a larger tractor to carry the chipper. I initially was looking at the Kubota B 3350. But after reading here and discussing my needs here I realized that a bigger tractor would be able to do more. Instead of a Kubota L3301 I ended up with a Branson 3725. It's been really awesome. There's a lot of jobs that I can do with the 3725 that the old B7100 could not even attempt. My only regret is not getting a 4225 as when I am chipping large diameter wood I could use more power. The 3725 is fine for everything else. I got a grapple and that is so useful for moving logs and pulling brush. The first time I pulled a huge poison oak out of a tree I wanted to keep I was really sold on the grapple.
I'd strongly recommend an HST (or whatever Yanmar's variable transmission is called). And a tractor larger than 25hp. If you want to use a grapple or a forestry winch or move a lot of dirt you'll want a larger heavier tractor. The emissions equipment is not that bad and it does make the exhaust that you're breathing cleaner. It's mostly the smallest tractors over 25hp that have problems (like the 3350). The larger engines have an easier time getting the DPF up to temp.
/ Evaluating options for a compact #17
Other than the hood scoop there is no external difference between the B2650 and B3350. If you liked one, you will like the other.
Addition of a turbocharger gives B3350 seven more horsepower over the B2650.
I recommend 4,000 pounds bare tractor for 37.5 acres of usable land. You only have ten acres that is really suitable for intensive tractor use, but hilly.
Did you view the first VIDEO in Post #5?
If you do not believe B3350 is enough tractor for ten acres, consider a Kubota L3560, one of the Kubota "Grand L" models. Again, view first VIDEO in Post #5.
/ Evaluating options for a compact #18
The new Yanmar YT series are beautiful machines. Though some find the YT235 a little too small and the YT347/359 a little too big. Yanmar makes Yanmar, but you might have to do some digging to find out who makes the smaller Mahindra's.
I recommend 4,000 pounds bare tractor for 37.5 acres of usable land. You only have ten acres that is really suitable for intensive tractor use.
I added those videos to my watch later list, but won't get to them til after dinner. I was looking through the Kubota book that I brought home, but it's hard to tell a whole lot from a book. I'm assuming the "GrandL" is a nicer finish than the L? More comfort similar to the B? If I call the Kubota shops to see if they have them on the lot....would looking at an L3301 or L3901, and comparing them to the L3560 make sense? I haven't looked at pricing online for any of these bigger machines yet, but I think I'll be better off in the longrun getting the tractor right, even if it means delaying some of the implements, ie: backhoe, until sometime in the future.
/ Evaluating options for a compact #20
Our land is a little over an hour south of the OP, and we have a similar ~35 acres on a hillside, of which I need to maintain about 5-7 acres. I shopped many of the same models the OP was looking at, initially looking at the Mahindra Max26XL, then the 1500s, and was on my way to check out the Kubota L3350 (and to talk to the dealer about the known regen issues) when I accidentally went into a Kioti dealer. I would suggest the OP at least give them a look. There was a dealer in Afton that gave me a very reasonable quote via email, though I ended up with a CK3510se from a closer dealer that's being delivered next week (the Akron dealer may also be the local Yanmar dealer). If you consider the CKs, skip the 2510 (smaller frame) and go to the CK2610 as a minimum (same engine as the 2510 and still rated at 24.5hp, so no regen, but many claim punches above it's weight class and is on the larger CK frame that's around 2800#). With the loader and filled rear tires, it should be >4000#. I had concerns about the DPF as well, but in the end, I wanted a little more HP to run a wood chipper and other as-yet-unknown implements down the road, so I bit the bullet on the DPF. As an FYI - You can get the 35 and 40hp CK models in an 'SE' model, which has a independent PTO and most options from the base CK models as standard.
Depending on how thick the brush is that you want to cut, you may also want to consider a flail mower like the WoodMax FM-62. As long as you don't need to cut anything more than an inch or so thick, it should do the trick while being more maneuverable in the wooded areas, and can also double as a finish mower, especially if you get an extra set of blades (the Y for grass and the heavier duck-foot blades for thicker brush). So, you only buy 1 mower instead of a brush hog and a finish mower, and don't need the mid-pto for a belly mower, saving another $1k or so. I plan on getting one eventually, but for now I plan on maintaining a few short wooded trails and a little brush with the FEL that will I probably put a Piranha tooth bar on and a root rake grapple from EA (I have a nice Simplicity mower for the lawn areas).
BTW, @OP - do me a favor. Stop into Oneonta and have a slice of cold cheese pizza for me. ;) Thanks!
-Lee
KANDI KRUISER GOLF CART (A67714)
KANDI KRUISER GOLF...
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
2021 Bobcat T66 Compact Track Loader Skid Steer (A66734)
2021 Bobcat T66...
AREA WITH MISC PARTS/ITEMS (A68842)
AREA WITH MISC...
Unused 2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
2022 Suzuki King Quad 500AXI 4X4 ATV (A66738)
2022 Suzuki King...
