Time for Chainsaw Chaps
/ Time for Chainsaw Chaps #111
I have one of those goofy Stihl helmets with visor and ear protection. I don't saw all day so it works well. Can't disagree that the noise protection is not sufficient. I also wear safety glasses under the mask. Can't understand how sawdust gets in my eyes with the face shield down but it does.
/ Time for Chainsaw Chaps #113
I haven’t run a chainsaw in years.
My last one made me decide I would never run one again without a working chain brake and proper maintenance, the chain would keep spinning on the old craftsman.
And full safety gear.
I got lucky years ago, never had any one get hurt, but we had a close call or two. Normally when we knew better but did it anyway.
Years ago I was helping clear some property.
I was called a safety geek when I told them I would not run the chain saw without proper PPE.
I even left one day when they started running the saw, late in the day when we were all hot and tired.
I didn’t want to even be around if someone got hurt, told them it was a bad idea. No one got hurt that day, but I still stand by my decision.
Funny thing was the guy that owned the properties got his money from an industrial accident settlement. I tried to explain to him if someone got hurt on his job he would lose it all, no jury would be sympathetic to him at all, figuring he of all people should know better.
I now try and wear hearing protection when doing anything loud and normally muff and stuff (plugs under muffs) for shooting anything larger than 22’s.
With electronic muffs I can still hear good, even with the plugs in.
/ Time for Chainsaw Chaps #114
I'm with you... I try to be OCD about my chaps....
"one day..." my wife wanted a slice of a cedar log cut so she could play around with it and maybe make it into a hot-pad or stepping stone or something....
Really? How easy is that?
Drove backhoe to already fallen log. Looked at it, had to make two cuts. One to cut root-ball off. Second to cut about 4" thick slice and I'm done.
Log (tree) is held in the air by my backhoe bucket....tree is around hip height so no bending over... I figured it wasn't worth the time to go to the house & back just to put my chaps on. Heck, I don't even recall if I had my hearing protection on for such a short "zip zip" and done.....
Famous last words...
As I was finishing the second and last cut, don't you know that the chain jumped the bar. The catcher caught it so it wasn't rotating anymore however, my leg was close enough that the chain "slapped" me right across the knee.
Been a long time....it might have scratched me but no broken skin and no cuts.
I just shook my head & counted my lucky stars. But for the chaps, everything else was almost ideal in its setup and it still bit me.
/ Time for Chainsaw Chaps #115
I'm always upset when it takes me so long to "dress' for using the chain saw. First steel toe shoes, then chaps with suspenders to hold them up then long sleeve cowskin leather weldding jacket, then face mask, then goggles, then helmet with face sheild and ear protection. Finally heavy duty work gloves.
But now looking at that I will never complain EVER AGAIN.
/ Time for Chainsaw Chaps #116
Seperate helmet and ear muff style hearing protectors don't work well together in my experience. The vast majority of my work on my property has been in brush where I don't need a helmet but lately I've been doing some work in the forest where a helmet's a good idea. I tried using the hearing protectors with the 'bail' between the two ear muffs behind my head but when my head sweats the muffs slip around. Ear plugs don't provide enough hearing protection.
I got a Husqvarna helmet with ear muffs last week and man is it nice. So much more comfortable, and very quiet with the muffs down.
I also got a set of the Forester apron style chaps because they have a pocket for tools. They're thinner than the 20 year old Stihl ones I've been using, and a little cooler in the heat.
Best helmet on the planet.I have the mesh and the clear plastic face shield. I've worn dozens of hemet brands and this is the Cadillac of helmets.
TreeStuff - Pfanner Protos Helmet
/ Time for Chainsaw Chaps #117
Don't worry, as long as you breath in and out that will happen. Solution: don't breath in, just out! :)
Another reason to always wear chaps, full wrap being best choice:
The piston ring speed on the average chainsaw travels 2,500 surface feet per minute. A chain slides across the surface of the sawbar rail at around 5000 feet per minute. The chain is moving at 55 to 60 m.p.h. or a mile per minute ( 88 feet per second ).
/ Time for Chainsaw Chaps #120
I went with a group from my church over to the panhandle of Florida a couple of times to help with the hurricane mess. I was on a chainsaw crew and it was mandated that I wear a set of chaps, a hardhat with face and ear protection. I always wear gloves so I don't remember if they were required. We romped around in the Florida heat for a week sawing every tree we could find that was on a house, or nearby. The heat of the safety gear wasn't as bad as I expected. My earmuffs were sufficient to keep the saw noise at bay.
I will continue to wear them at all times now, no exceptions.
David from jax
2014 FORD F-150 (A60736)
2014 FORD F-150...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
(INOP) MASSEY FERGUSON 543 TRACTOR (A59823)
(INOP) MASSEY...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
