How do you carry your chainsaw ?
/ How do you carry your chainsaw ? #81
Thanks and yes it is. And you are right - between that and the hand grip on the fender there is plenty to grab both mounting and dismounting.gg
I agree, that hand grip looks great. On our M59, the canopy upright serves the same function, I sure need something to grab hold of when getting on & off.
Here's a picture of a chainsaw mount. It's just basically made out of scraps of wood. I laid the saw on a 2 foot length of 1" pine board and then started adding pieces of wood until I had a holster built that fit decently. It rattled, so I added that piece of black rubber you see in the photo. I then clamped the holster to the loader upright, drilled 4 holes, threaded them in the loader upright, and and bolted the holster on. The loader upright is a hollow member of heavy steel, and more than stout enough to mount things.
rScotty
/ How do you carry your chainsaw ? #82
rScotty
Hey rScotty,
I like your grab handle there too, but it would be too low for mine and Gordo's tractors.
You both made a nice holder, AND took nice pictures, but I have to ask- what were you using the saw bar to trap in the open tube of the loader mount- it's there when the saw is in the holder, but absent when you took the picture sans-saw?
If'n you don't mind me asking, that is...?
/ How do you carry your chainsaw ? #83
When I've carried mine, I just put it between my feet on the transmission hump area. I only use electrics now.
Ralph
/ How do you carry your chainsaw ? #84
Hey rScotty,
Good Catch, PA,
That open tube of the loader mount doesn't go all the way through. Kubota only made it about a foot deep. But that is just right for a stuff sack holding a chain saw tool roll and a couple of plastic bottles carrying a quart of chainsaw fuel and some bar oil. When I take the saw off I pull that stuff sack out and keep it with the saw.
luck,
rScotty
/ How do you carry your chainsaw ? #85
Good Catch, PA,
luck,
rScotty
Hi again rScotty,
I only thought of it maybe being sundries for chainsaw use after I posted, but the saw makes a good plug for the tube, and hauling those there looks right convenient in that scenario.
Good idear!
Stay well!
PA.
/ How do you carry your chainsaw ? #86
Hi again rScotty,
Good idear! PA.
It is clever, isn't it? I wish I could tell you how I planned that all out and built it specifically so that the chainsaw bar would just perfectly close off that storage space exactly when it needed to do so.
But the truth is that I built that chainsaw holster out of scrap without measurements or planning. It wasn't until the holster was all done, mounted, & I put the saw into it did I notice that the saw bar became the door for a perfect little tool box.
My philosophy has always been, "Good Luck beats good planning"
good luck,
rScotty
/ How do you carry your chainsaw ? #88
Just finished this... and no... I don't plan to carry all of that stuff every day
However that will occur from time to time on specific chores. Just have to be aware of your surroundings but I rarely travel in woods with the tractor. Mostly my clearing and cleaning is slightly overgrown pastures, food plots and fence rows and those are all more open areas. Just need to have it all with me at times so I staged it all up to see what all I could get on there and to plan for what all I can carry. Sometimes the pole saw might be a trimmer. Sometimes that spot might be a shovel or a rake. Etc.
The basket is Tractor Mikes Tractor Caddy. Of the couple of these sorts I looked at his was the largest widest one and the price was about the same. The long tool holder and chain saw holder are Northern Tool sourced "Bannon" brand attachments designed for their expanded mesh trailers. A few modifications and they work for this caddy pretty well too.
/ How do you carry your chainsaw ? #89
A few more supporting photos that support the above post that is now too old to edit.
/ How do you carry your chainsaw ? #90
Just a couple pictures of my holder I made out of a plastic cutting board. I got the idea off from TBN a few months back. Works great safe and out of the way. A cutting board, a few cuts. a little drilling and a few bolts. She works pretty good. RyanIMG_1791.JPG25962.jpeg.jpgIMG_1450.JPG
/ How do you carry your chainsaw ? #91
Added some 1” bars to hold some rail for extra weight on my box blade... holds chain and my saw!
Use the 2” receiver to hook the chains to.
Box blade is ballast, tree hauler... all in one!
/ How do you carry your chainsaw ? #92
My limbing saws a Echo CS 400 fits in the loader bracket on the left side. The right side is where my other limbing saw a Polan 2150 saw rides.
My J red 2159 rides on the ROPs bar bracket I made out of scrap wood on the left side. I have one on the right side where one of thre Hiuskys ride, either a 162SE My favorite saw with the Echo a close second, a huisky 55, or a 455 rancher.
Any one know where I can get 4.5 inch pipe plugs?
Want to carry logging chains in the loader frame tubes.
:D Al
/ How do you carry your chainsaw ? #94
This may change but I made this to hold it on the winch.
/ How do you carry your chainsaw ? #95
Just returned from the woods. All saws I used present and accounted for.
:D Al
/ How do you carry your chainsaw ? #96
My Woodland Mills chipper and stump grinder both came with chainsaw mounts on them.
/ How do you carry your chainsaw ? #97
/ How do you carry your chainsaw ? #98
Built a carry all with a trailer hitch for my splitter. I don't like to waste time dragging a tree out of the woods. This way I can cut it, split it, stack it, then drive to the wood shed. It's surprising how much wood can be put in this carry all and the bucket.
/ How do you carry your chainsaw ? #99
Jackieboy,
What winch do you have? I have a little 2816 hst, and would like a winch. How does it work for you. Did you check out uniforest, their near you. Also, I'd love to walk across the anirondacks. An old trapper lived in Remsen used to come up this way, eventually becoming good friends with the parents. We spread some of his ashes up in the mountains here. So I've always heard of the anirondacks and the old trappers. In a straight line, how far across would it be to where there are no roads etc? I think the only thing would stop me would be the tick situation. I hear you have lots of deer ticks and lyme. Is that true?
/ How do you carry your chainsaw ? #100
Gordon gould, How do you like the farmi and I was wondering if those ice changes snag sticks and brush and drag it up around the fenders? I would like a set also if I pull more wood out but was wondering if they would bring up brush around and break up the back of the fenders.
2016 Ram 2500 6.4L HEMI (A62679)
2016 Ram 2500 6.4L...
TITAN 84RAKEV2 - 84" HYD LOG GRAPPLE (A64277)
TITAN 84RAKEV2 -...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
3Pt Bale Carrier (A66408)
3Pt Bale Carrier...
John Deere Metal Sign (A65583)
John Deere Metal...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
