How do you carry your chainsaw ?
/ How do you carry your chainsaw ? #61
Made a scabbard for the saw screwed a couple brackets on the back of it to hang on the piece I welded together and bolted on the tractor where there was already accommodation on the loader post.
/ How do you carry your chainsaw ? #62
How do i carry my chainsaw?
With confidence.
/ How do you carry your chainsaw ? #64
Built this the other day. Got the idea from Billrug a couple posts back. Thanks
/ How do you carry your chainsaw ? #66
Nice job Amvcane even improved it I still haven't got my park brake remodeled but I will thank you for the idea.
/ How do you carry your chainsaw ? #69
Gordon I like the idea of being able to pull the saw out to use much easier than mine where I have to lift it out. That's how I did it on my last tractor.
/ How do you carry your chainsaw ? #70
If anyone else is interested when I used my saw long hrs. everyday my hands would get cramped so I slid the foam made for bicycle handles over mine and it certainly has helped.
/ How do you carry your chainsaw ? #71
Gordon,
That looks very functional. How is the box attached to the large plywood base? Also the large plywood looks attached to 2 plywood "feet" that sit on the tractor sheet metal.
How are those attachments made, and do you have any rust at the metal to plywood interface?
/ How do you carry your chainsaw ? #72
"Functional" is a good way to describe it.
I put a cross support between the rops. Couple pieces of light angle with a PresureTreated wood spacer.
Then I have a plywood shelf that just lays in there. The rops locks it in place in a dado cut on the bottom of the plywood. There is no rust on the fenders because I use it every day but the paint is wearing off a little. You could glue a piece of indoor/outdoor carpet on the plywood to slow down the ware.
Then the box just sits on top also locked in place between the rops with a couple wood cleats on the side of the box. There are no fasteners so I can take it all off except the cross support w/o any tools.
gg
/ How do you carry your chainsaw ? #73
/ How do you carry your chainsaw ? #74
I was inspired by seeing all of these ideas. I ended up using composite decking board for mine, attaching it to a Mahindra ML-130 loader on a 5035 tractor. I used a dado blade to hollow out the inside of the sheath to 1/2" total DSC_0069.jpgDSC_0070.jpgDSC_0071.jpgDSC_0072.jpgDSC_0073.jpgDSC_0074.jpgDSC_0075.jpgDSC_0076.jpg
/ How do you carry your chainsaw ? #75
Nice sheath using composite decking was a heck of a good idea for durability !!!
/ How do you carry your chainsaw ? #76
I finally got around to painting my carry all and took some pictures. I've been using it all summer and it works well. Surprisingly strong - I stood on it as a test. One downside is it obstructs the rear view some.
View attachment 291812View attachment 291813View attachment 291814
I know this user doesn't seem to be active anymore, but this looks like a really good setup. I was just about to order a Kolpin chainsaw mount, but I think I am going to skip it for something much more versatile like this item.
I love the ideas I can get from this forum!
/ How do you carry your chainsaw ? #77
I make cheap wooden carriers for my chainsaws. They are quick and easy to make.
/ How do you carry your chainsaw ? #78
It is nice to have a thread with all these good saw carrying ideas in one place. Something for everybody.
Here are the two saws on my M5640. One on the loader post - pretty common. The other in back with a tool box.
gg
/ How do you carry your chainsaw ? #79
gg
Hey Gordo,
Those look too nice to beat up in the woods!
I like the welded on mounts on your FEL tower, but don't have enough skill to do it myself yet- AND on our little tractor, there wouldn't be room for my @rse between the saw and the fender anyway- as it it is, I have to be real slow and careful not to catch the PTO or speed range levers with said posterior projection, or overhanging coattails, especially when dismounting.
I have to ask though- is that crossover hand grip across your dash OEM?
My SWMBO has some problems getting up onto the driving deck because of her [handi-capable] disabilities, and something like that would be a Godsend for her in both mounting and dismounting...
I'm saving a copy of your picture so I can try and replicate it.
Thanks and stay warm!,
PA
/ How do you carry your chainsaw ? #80
Hey Gordo,
PA
Thanks and yes it is. And you are right - between that and the hand grip on the fender there is plenty to grab both mounting and dismounting.
gg
2022 EZ-GO ELITE...
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2022 EZ-GO ELITE...
