How do you carry your chainsaw ?
/ How do you carry your chainsaw ? #61
Made a scabbard for the saw screwed a couple brackets on the back of it to hang on the piece I welded together and bolted on the tractor where there was already accommodation on the loader post.
/ How do you carry your chainsaw ? #62
How do i carry my chainsaw?
With confidence.
/ How do you carry your chainsaw ? #64
Built this the other day. Got the idea from Billrug a couple posts back. Thanks
/ How do you carry your chainsaw ? #66
Nice job Amvcane even improved it I still haven't got my park brake remodeled but I will thank you for the idea.
/ How do you carry your chainsaw ? #69
Gordon I like the idea of being able to pull the saw out to use much easier than mine where I have to lift it out. That's how I did it on my last tractor.
/ How do you carry your chainsaw ? #70
If anyone else is interested when I used my saw long hrs. everyday my hands would get cramped so I slid the foam made for bicycle handles over mine and it certainly has helped.
/ How do you carry your chainsaw ? #71
Gordon,
That looks very functional. How is the box attached to the large plywood base? Also the large plywood looks attached to 2 plywood "feet" that sit on the tractor sheet metal.
How are those attachments made, and do you have any rust at the metal to plywood interface?
/ How do you carry your chainsaw ? #72
"Functional" is a good way to describe it.
I put a cross support between the rops. Couple pieces of light angle with a PresureTreated wood spacer.
Then I have a plywood shelf that just lays in there. The rops locks it in place in a dado cut on the bottom of the plywood. There is no rust on the fenders because I use it every day but the paint is wearing off a little. You could glue a piece of indoor/outdoor carpet on the plywood to slow down the ware.
Then the box just sits on top also locked in place between the rops with a couple wood cleats on the side of the box. There are no fasteners so I can take it all off except the cross support w/o any tools.
gg
/ How do you carry your chainsaw ? #73
/ How do you carry your chainsaw ? #74
I was inspired by seeing all of these ideas. I ended up using composite decking board for mine, attaching it to a Mahindra ML-130 loader on a 5035 tractor. I used a dado blade to hollow out the inside of the sheath to 1/2" total DSC_0069.jpgDSC_0070.jpgDSC_0071.jpgDSC_0072.jpgDSC_0073.jpgDSC_0074.jpgDSC_0075.jpgDSC_0076.jpg
/ How do you carry your chainsaw ? #75
Nice sheath using composite decking was a heck of a good idea for durability !!!
/ How do you carry your chainsaw ? #76
I finally got around to painting my carry all and took some pictures. I've been using it all summer and it works well. Surprisingly strong - I stood on it as a test. One downside is it obstructs the rear view some.
View attachment 291812View attachment 291813View attachment 291814
I know this user doesn't seem to be active anymore, but this looks like a really good setup. I was just about to order a Kolpin chainsaw mount, but I think I am going to skip it for something much more versatile like this item.
I love the ideas I can get from this forum!
/ How do you carry your chainsaw ? #77
I make cheap wooden carriers for my chainsaws. They are quick and easy to make.
/ How do you carry your chainsaw ? #78
It is nice to have a thread with all these good saw carrying ideas in one place. Something for everybody.
Here are the two saws on my M5640. One on the loader post - pretty common. The other in back with a tool box.
gg
/ How do you carry your chainsaw ? #79
gg
Hey Gordo,
Those look too nice to beat up in the woods!
I like the welded on mounts on your FEL tower, but don't have enough skill to do it myself yet- AND on our little tractor, there wouldn't be room for my @rse between the saw and the fender anyway- as it it is, I have to be real slow and careful not to catch the PTO or speed range levers with said posterior projection, or overhanging coattails, especially when dismounting.
I have to ask though- is that crossover hand grip across your dash OEM?
My SWMBO has some problems getting up onto the driving deck because of her [handi-capable] disabilities, and something like that would be a Godsend for her in both mounting and dismounting...
I'm saving a copy of your picture so I can try and replicate it.
Thanks and stay warm!,
PA
/ How do you carry your chainsaw ? #80
Hey Gordo,
PA
Thanks and yes it is. And you are right - between that and the hand grip on the fender there is plenty to grab both mounting and dismounting.
gg
Ditch Witch Mixing System FM13V (A65579)
Ditch Witch Mixing...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A64553)
2018 Roadtec...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
New 1.5x27 Ratchet Strap (A65579)
New 1.5x27 Ratchet...
NEW Wolverine DB-15-84W Snow Blade (A62679)
NEW Wolverine...
2015 Jeep Renegade Latitude SUV (A64557)
2015 Jeep Renegade...
