Compact Tractors are Designed All Wrong
/ Compact Tractors are Designed All Wrong #122
Those are pretty cool.
/ Compact Tractors are Designed All Wrong #123
I have seen some of those big red tractors in the central valley pulling huge implements. Did not know what they were until now. Very interesting. Up to 575hp.
/ Compact Tractors are Designed All Wrong #124
Mossroad - I figured you would like it. It is very similar to a PowerTrac just a little larger framed! I can't wait to get a few more toys for her to play with!
/ Compact Tractors are Designed All Wrong #127
Interesting read. Have you ever looked at the Merlo Multifarmer? Addresses a lot of the problems while still offering the option of pulling with a 3 point & PTO if you want to.
/ Compact Tractors are Designed All Wrong #128
As you guessed, I have no need for a 3pt hitch. Been there, done that, not going back in the foreseeable future. :laughing:
Now if I had to plow a field often, or had large acreage to mow, I might consider 3pt. But for the most part, I can accomplish all my tasks with implements mounted up front.
/ Compact Tractors are Designed All Wrong #129
/ Compact Tractors are Designed All Wrong #130
Kind of reminds me of the Unisystem - you always have to reconfigure it for what you want to do. Plus these are big - not a compact or lightweight, i.e. on your lawn type of machine.
True, even the lower end is 110hp - solidly into utility tractor range. Interestingly, they make a 74 hp machine about 6 ft wide, but it isn't available with a 3pt hitch. I think that size machine would be very useful.
/ Compact Tractors are Designed All Wrong #131
/ Compact Tractors are Designed All Wrong #132
The Yukon is an interesting tractor but limited to 12° slope with the wheels set wide.
Ken
/ Compact Tractors are Designed All Wrong #133
I t doers have some really nice wheel options including extra wide and duals.
Ken
/ Compact Tractors are Designed All Wrong #134
Very very cool concept! I love the idea of something like a telehandler, but none of them that I knew of are available with a 3 point hitch and PTO.
Although the 3 point hitch is outdated technology and a pain in the rear at times, many of us have numerous 3 point implements already and it would be too costly to switch to all hydraulic.
It’s nice to see other options and advancements in technology out there.
/ Compact Tractors are Designed All Wrong #135
Ground impact is basically weight of the tractor divided by the contact area. I am not talking about the damage caused by turning, etc. where the type of steering (articulated, skid steer, conventional) makes a large difference. So for the same style tire, twice the weight needs twice the ground surface area. For the same diameter tires, twice the width would be a reasonably close approximation.
Ken
There's a lot more to be said than just "contact area". Load distribution across the contact area varies widely for different tread patterns. Needless to say, R4 and ag tread have vastly different properties. Ag treads have deceivingly different footprints. While the R4 read has more contact area, the side bite is horrible for tearing up turf.
On a smaller scale, this is like comparing the difference between Kenda brand chevron tread tires on my ZTR mower, to Carlisle's version of the same chevron tread. The rounded edges of the Carlisle tires aren't nearly as prone to turf damage as the Kenda... but at a quick glance, they look virtually identical.
/ Compact Tractors are Designed All Wrong #136
I said for the same style of tire and same diameter of tire. In other words, all things being equal, twice the width has 1/2 the ground contact pressure.
Ken
/ Compact Tractors are Designed All Wrong #138
I haven’t read the whole thread and only the first post. The 3 point hitch doesn’t suck that bad. Especially the more operator friendly versions. I don’t see it going away any time soon due to the amount of already existing implements. Hydraulics drive attachment are expensive. Forward facing mowers are better unless it’s a big one. 15 foot bat wings aren’t a very good candidate to be pushed. Tractor loaders are definitely on the wrong end. And if you haven’t figured it out Americans like doing a lot of things like grandpa. Even if it’s wrong or not the most efficient way. Foreign equipment is much more intuitive than ours.
/ Compact Tractors are Designed All Wrong #139
Tractor loaders are definitely on the wrong end? What is your reasoning for that? I can not imagine wanting it on the back even if I had a swivel seat.
Ken
/ Compact Tractors are Designed All Wrong #140
Read the whole thing as time permits. There's a lot of good advice, comments, and exchange of ideas in there from a lot of member starting about 17 years ago. It's some of the conversations in there that turned me towards the machine I have, instead of a conventional tractor.
Analyze your tasks, start looking for the machine(s) that'll accomplish those tasks, in the time you're willing to devote to those tasks, yet staying within your budget. That's the hard part.
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
Caterpillar Traxcavator service manuals (A63117)
Caterpillar...
UNUSED SWICT 78" BUCKET (A64280)
UNUSED SWICT 78"...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
JCB 92" Clamshell Bucket (A64119)
JCB 92" Clamshell...
2025 Auger Drill Bit Skid Steer Attachment (A61572)
2025 Auger Drill...
