Shipping container for tractor storage
/ Shipping container for tractor storage #22
Can a shipping container be partially buried along its side on a steep/stepped hill to make a flat above it? Maybe even a carport? Maybe will some kind of drainage or will that just be a corrosion disaster at a later date?
/ Shipping container for tractor storage #24
From what I understand the side walls are not able to handle the pressure of dirt pushing in if you bury it. As such if you do would you will likely lose the side walls sooner or later unless you build a retaining wall first. The strength of the containers is all in the corners where they latch together.
Aaron Z
/ Shipping container for tractor storage #25
Yeah ^^^^, it's going to rust and with too much dirt against one side, you would need to anchor it to some concrete.
/ Shipping container for tractor storage #26
Got to be a way though. A retaining wall will cost more than than the dang container. I’ve built several. Hoping the creative juices flow here.
Spoke to someone today with the same tractor ls xu5065 with r4s. Max height with r4s is 98 in to top of cab. Is 3in enough clearance? Am i going to be happy with r4s cutting pasture?
/ Shipping container for tractor storage #28
3 inches is close you will be ducking going in and out:D
Just trying to find a way to secure my investment 2 hours from where i live now
/ Shipping container for tractor storage #30
I hear you its going to be tight. Its a high cube container correct ?
/ Shipping container for tractor storage #32
Shipping containers are very secure, as well as being weather tight and rodent proof, BUT
they do get very hot inside. Hot enough to turn fuel into varnish.
You may want to consider putting the container under a car port.
Im considering the multibox that someone posted earlier. Spoke with the owner earlier today and am awaiting pictures and specs. It would require a bit of modification but will work i believe. Not as secure but i think itll do
/ Shipping container for tractor storage #34
I store fuel in my 8x8 shed. It has lots of ventilation (because I'm a sh!tty carpenter and never built a shed before) and doesn't get nearly as hot as the shipping container in sun. Regardless of temp, I wouldn't want fuel cans in the closed up shipping container...all those fumes with little to no ventilation.... Mine has the very tiny condensation or pressure vent, but it's not enough to really do anything for fumes or heat buildup.
Plan this spring is to paint mine a lighter color. Something like coyote tan. Light enough to help cool it off some but not white so it stands out real bad. Mine is placed in a spot that isn't isn't highly visible from outside my property, but white would stand out. Might cut in some actual container vents if I see one that looks wasp proof
/ Shipping container for tractor storage #35
I keep looking at them on Craigslist. Only problem is I don't know about county regs, like if I can call it temp or portable and not get permit. Since we just pulled permits to build the house we'll have inspectors around too much to "just forget to ask".
No worries where i am in regards to permits. Only thing I'm worried about is clearance in the dumb container.
/ Shipping container for tractor storage #37
Oh I just noticed you're right down 85 from me. I'm in Jackson county. Guessing you're not in Gwinnett if no worries about permits.
/ Shipping container for tractor storage #38
I see these advertised on CL all the time.. Some in the 3K range. My question is why so many and so cheap?
Are they not usable again ? ... 1 trip across the Atlantic and it's done ?
One trippers are designed to be built overseas, loaded with freight, then sold into the storage/rental business upon arrival in the western hemisphere. You'll note the door handles are set a comfortable waist height versus very low handles on cans used repeatedly for shipping. Those cans are loaded/unloaded while on special trailers so handles are placed where you can reach them from the ground.
/ Shipping container for tractor storage #39
Protecting your tractor is indeed smart.
I use two containers.
One on the left side & one on the right.
Built a roof over the open span. Very simple & it works.
Sure the ends are open but it stays in Florida. We could always use that thick ''see through'' hanging plastic but our tractor is just short of 20 ft long when the back hoe is locked to one side. It is out of the wet part of weather there.
Keep in mind there are 20 ft length & 40 ft nearly all steel shipping containers.
Some have barn doors on both ends.
Usually there are only one set of barn doors on one end.
The refrigerator units have the barn doors on one end & a removable compressor w/ its fans etc on the other end.
I have seen these as drive through shelters for other equipment, such as lawn service equipment.
These containers are also made of a lot of stainless steel & aluminum so there is usually less rusting.
Would suggest, to reduce the floor from rusting out (very common when set on the bear ground for long periods of time), use cinder blocks to elevate the container to better permit dry air circulation.
It will def be on something as well as over gravel
JMR 8ft Man Basket Skid Steer Attachment (A64553)
JMR 8ft Man Basket...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
LOFLIN GRAPPLE RAKE (A64278)
LOFLIN GRAPPLE...
(2) STAINLESS STEEL HOG FEEDERS (A64278)
(2) STAINLESS...
