L5740 Cab -- clearance for rear chains?
/ L5740 Cab -- clearance for rear chains? #31
I finally remembered to get photos and measurements tonight. The tape measure isn't the easiest thing to see, but it was a little over 3" from the chains to the metal piece that protects the wire running down the inside of the fender. That would be the closest point where a chain could contact, as best I could tell. I didn't take photos of the wheel/hub setting as it is exactly the same as TripleR's
/ L5740 Cab -- clearance for rear chains? #32
Thought I'd share what the dealer sales person relayed from Kubota Technical concerning repositioning 17L-24 R4's.
They claimed the tires/wheels are already at their widest position and can NOT be made wider. I've included a picture, so you can see first hand what they are "claiming" is the widest setting. I didn't say anything, as I believe others on this forum who present solid evidence their rims/hubs are repositioned for greater clearance.
Picture 1: Measurement of tire/inner fender clearance
Picture 2: Orientation of rim and hub disk. You'll have to zoom in to see the hub disk is positioned outside the rim.
It is hard to tell from the photo, but the hub disc appears to be inside the wheel rim mounting points. Still there may be one wider setting by flipping the tire around on the hub (and you would have to swap sides too). The mounting points on the wheel rim are not centered on the rim, so for the widest setting you want them positioned so they are in the closer position to the tractor. Then position the hub behind them so the hub is closer to the tractor than the rim attachment points. Here is the diagram from the manual that shows it (albeit, not the best graphic, IMO). They go from narrow to wide, left to right.
/ L5740 Cab -- clearance for rear chains? #33
FatTire,
Did you ever flip your wheels around to gain extra chain clearance? If so, how much clearance did you gain and did the extra tire width exceed the width of your snowblower?
Few months back I purchased a used L4740 with R4's. The tires are very close to inner fender as you described. It looks like my hub and rim can be flipped around to gain more clearance. I'm hoping to learn from your experience before going through the labor of doing so. The downside of doing so for me is this will likely exceed my front snowblower width...
Thanks in advance for sharing your experience.
I held out some hope that I'd have enough clearance with a careful chain installation. So tried it, and if every single link was perfect I still only had about 0.1" clearance on certain links. No way would the chains stay that way during actual use.
My local dealer (farmer's CO-OP) said they did the thing with turning the tires/hubs around and swapping sides frequently, so I looked into that. After measuring and talking to them again, it looked like that was going to give me TOO MUCH clearance. I've forgotten what we determined, but I'm thinking it was an extra 3.5" per side. That would be too wide for my blower and even for my 84" rear blade when angled. In the end I decided on 2" wheel spacers from BORA (Motorsports-tech of Reno, NV). Those spacers are nicely made, I had the dealer install them and load the tires at the same time. BUT, even with only 2" per side my blower is now a bit beyond my rears (looks like about an inch per side) and the 4" total extra tire width is a lot more noticeable when grading with the rear blade than I expected.
Unfortunately we have had very little snow here (southern Rockies) and I have not been able to test the blower to see if I care about the width or not. If it seems to matter I'm thinking I could either add some wings to the blower or I could sell it and go up to 7 ft. I didn't pay too much for the 6ft blower, but finding a 7ft 3-point blower in good condition around here may take quite a while. I regret buying a 6ft anyways, it wouldn't cover the tracks either way in a bend. Don't know what I was thinking...
I want to suggest that you could take some measurements from your own machine and see what you think you'll get by reversing the tires. The mechanic at our dealer said something about "not all these wheel assemblies were the same". I couldn't pin down if he meant not all the wheels were the same across the different models, or across the range of years. I'm not even sure if he knew --- they just don't seem to pay that much attention to it. BTW, I never measured my old MX5100 hubs during the 3 months that I owned both machines, but they sure looked the same as my L5740's and I was pretty sure at the time there was no difference. Only later when I got into it did I wonder if they were exactly the same or not.
Hope this helps.
EDIT: The reason I wondered if the MX5100 might be a tiny bit different is that when I measured my 5740 hubs I convinced my self that I was going to get more clearance than shown in dstig1's photo above. Why would that be, other than some difference in the wheels? There is no difference in the frame of a 5240 and 5740.
One more thing. 2 inches is not very much extra width, but the combination of loading the rears and adding that extra bit of width makes the L5740 feel a heck of a lot better. I had the rears loaded on the MX5100 from the beginning so I didn't even realize how critical it is on these Kubotas. Night and day.
/ L5740 Cab -- clearance for rear chains? #37
FatTire,
Thank you for taking the time and sharing your experience with detail and clarity. It's exactly what I was looking for. Your "too much tire clearance..." is exactly what concerned me about flipping the rim/hub orientation when using blower and/or blade. You've saved me a lot of time!!!!
For what it's worth I'm planning on making wings for the blower, just because I prefer the blower to clean wider than tractor tire width.
gaproperty,
Can you post a close up picture of your hub/rim orientation where they bolt together. I believe yours are set the same as mine are currently, but would like to verify. The chains are way more aggressive than what I could use, but it's nice to see the design works in our situation. Can you provide a website? The chains I've found for R4's typically relatively large link diameters which reduces clearance, I'd be ok with smaller diameter (weaker or less robust) chains, if they would fit as well as yours do. Thanks for your contribution!
FatTire,
This is true. My rear chains are Duo's and the links are quite a bit larger than gaproperty's nice chains, and they don't lay out as cleanly so you can't have as tight a fit as gaproperty's. I like the stability that the 2 inch spacers provide, but watching the video above I started wondering if I could have skipped the wheel spacers and purchased chains like that. But I don't how much a pair of those chains cost, so maybe I should just put my brain back in sleep mode.
/ L5740 Cab -- clearance for rear chains? #39
Hi Moshap. I will try to get some pictures today but my rims are set to narrow width. My snow blower is 74 inch and it clears the outside of the tires by a bit.
As for a web-site I ordered mine through a local dealership in Nova Scotia Canada namely Nova International so I don't know the web-site of the chain manufacturer. In the video I posted, there are close ups of the box the chains came in with a part number and name displayed on the side. I suspect if you search the web for that part number or name you would get the web-site. You can also google Nova International, the dealership I bought them from and they may be able to help you out. I too will try doing a search as time allows. As for the chain design they seems to have a slightly smaller side link or at least narrower in design thus requiring less clearance. They main chain is a 5/16 chain or 8 mm but the side chain I believe is 7mm. Whoever made these chains put some thought into it because they got the lever type closures so you can tighten them up and side chain adjusters to shorten the side link. They say in place on the tire and they were the same price as the lighter duty l ones, at least from this dealership. Around $1000 Canadian.
As for going with a smaller less robust chain, The ones I had prior were less robust and slightly different design and a different brand name. They were Aquiline. Although good for there intended purpose they were to light for my tractor and I had hard time keeping them from moving around on the tire. I am not sure if the reason they moved around on the tire was because of the design or the light duty no weight to them. These light duty ones I had prior stayed in place better if I didn't have them on really tight. At least after getting them twisted out of position from making turns and spinning in the driveway when I got back out on the pavement most times the centralfugicial force from the fast turning of the tire seem to adjust them back where they should be. But my new heavier chains in the video stay in place perfectly. When I bought them I asked the dealership for some spring load fasteners to hold these chains in place. He said I could sell you some but you don't need it with these chains. Tighten them down and they will stay in place. As it turns out he was right. Nova International is the name of the dealership. They are huge here and many contractors swear by them and with the little experience I had with them I must agree and will be getting my business from now on.
On of my main reasons for writing this is to help you out. I am not associated with Nova International or the chain manufactures. I hate buying junk and dealing with problem dealerships so I like to give credit where credit is do and both these chains and the dealership is deserving of credit. Hope this helps. Thanks Ray
FatTire,
gaproperty,
/ L5740 Cab -- clearance for rear chains? #40
Gaproperty,
Thank you being so kind to articulate the detail with clarity. It is very helpful and I知 certain others will benefit from it.
My traction needs are not as great as these chains will provide but I値l research the company in the near future.
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 Ford E-150 Passenger Van (A59230)
2013 Ford E-150...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
1996 Lincoln Town Car Sedan (A59231)
1996 Lincoln Town...
2014 Dodge Journey Van (A59231)
2014 Dodge Journey...
