Snow Equipment Buying/Pricing snow chains
/ snow chains #1
gravelman
NH
Kubota 2650
hi folks...gravelman here where can i find snow chains for my Kubota 2650 tire size is 23 x 8.50 -14 These are the front obviously. im looking for 2 link for a smoother ride also..im out on pavement alot. thanks for any recommendation.
/ snow chains
THANK YOU
/ snow chains #6
Cheap ones will kind of work, the Aquiline Talon Tractor Tire style will work 10 fold better, ride much smoother, last longer, and do less damage on pavement because they don't slip and are simply the best style of chains I have ever used and I believe I have tried just about every style made for ag and industrial use up to and including the tire protective ones for mining equipment.
Four link street style are the least usefull.
/ snow chains
aquiline... never heard of them...can i google it up or do you know where i can find them????
/ snow chains #8
Look at automobile snow chains. If you are on pavement stay away from v-bar. Think of hundreds of steel chisels pounding on your pavement. On the front tires you are not looking for pulling power but steering and to prevent sliding. Auto chains typically have more surface contact, smoother ride, are easier to get on and off, and cheaper. You can find an same size auto tire for fit. Chains do make a great difference and well worth the investment. During the winter I use front only on my tractor. John Deere 3038E. I use the FEL to lift front wheels and fit them on easily.
/ snow chains #9
Another place to look is tirechainsrequired.com I bought mine from them and just ordered some for the front. I need them because of all the ice on my drive. P1060005.JPG
/ snow chains
got it...thanks
/ snow chains #11
Reed Supply in VT handles OFA tire chains and may carry other brands. They deliver to parts of NH also. Nice people to deal with.
/ snow chains
ok, got that...and thanks alot..
/ snow chains
ok i will do that...thanks
/ snow chains #16
Did you try the kubota dealer up there, r n johnson would of had them
/ snow chains #17
Yes, there are many suppliers of them googling aquiline talon, or talon , or studded tractor chains.
Your tire are small and you may not find a lot of options, you might consider the diamond patterned automobile style or atv chains.
4 link spacing street chains are not a very effective chain, especially for a front axle.
/ snow chains
ok on all that...thanks guys.. very much by the way RN Johnson has been closed for years... i guess they did not sell enough of those expensive green things.. i would not get chains thru the tractor dealer... Pinnacleview...wayyyyy too much $$$$$$$$$$
/ snow chains #19
I know that r n johnson is closed I used to go up that way all the time back in the 90's When there was walpole iga and hubbard farms
/ snow chains
the good old days
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2007 JCB 3CX 4x4 Extendahoe Loader Backhoe (A61567)
2007 JCB 3CX 4x4...
211298 (A62131)
211298 (A62131)
2023 John Deere Z930M Zero Turn (A63116)
2023 John Deere...
2001 Eagle 24ft Equipment Trailer (A61165)
2001 Eagle 24ft...
2012 Freightliner Cascadia (A63118)
2012 Freightliner...
