Fuel issue or something else?
/ Fuel issue or something else? #1
Jamoose
West Newbury, ma
New Holland tc33d
New to the forum here and hoping that someone has some thoughts on what's up with my New Holland TC33 D.
Running perfectly yesterday and filled the tank with fresh diesel from the local station in preparation for today's big storm on the east coast. Just started an hour ago and after 30 or so seconds of use it struggled to maintain rpms and stalled under minor load of snow in the bucket. After that it would barely stay running and stalled going into gear.
I had this problem last summer and had to call a mobile repair service that reported the issue was the tank was full of gas. I was positive then that I had filled it with diesel and I am doubly positive that I did so now. I'm scratching my head on this one. The fuel is #2 diesel. What am I missing? Any thoughts?
Thanks!
/ Fuel issue or something else? #2
When it starts to stall, lose RPMs, leave it running and get off and look at the glass/plastic fuel bowl. Can you see air in there....bowl not 100% full of fuel ? Your problem is from there back, likely a tank or line obstruction.
Bowl is full and tractor is still spit/sputtering ? Your main fuel filter needs replacing or you have air getting in the lines someplace forward of the fuel bowl.
/ Fuel issue or something else? #3
Its possible the fuel gelled.. Change the fuel filter first..Take the fuel filter out & have a look.. IF its jelled you'll see it.
Get yourself some cold weather additive while your out..
& MAKE SURE its diesel.. regardless of which nozzle you used at the station.. THEY make mistakes too..
Pour some in a cup from the filter.. if its gas it'll lite w/ a lighter.. if its diesel, it wont..
If the fuel is gelled, DO NOT reuse the filter..
/ Fuel issue or something else? #4
Since when will diesel not light with a lighter?
/ Fuel issue or something else? #5
Well what's your temps been lately??? If it has been pretty cold, that may be your culprit. Diesel fuel contains a waxy substance. When it is say 70 degrees everything is fine. When it is say 10 degrees you get into trouble. The fuel gells and the waxy substance plugs up the fuel filter. My guess is that is where I'd start with trying to figure out the problem. You probably going to have to use a winter blend diesel fuel. Most service station have that now cause it is cold. You are probably going to need to use a fuel supplement. Howes and power service are two pretty good ones. The fuel supplement will help keep you from gelling up in the cold. You will probably need a new fuel filter. Very very rarely can you gell up and not need a new fuel filter. That waxy stuff just plugs it up. If you can get the tractor into a building and try to warm things up. I have used a heat lamp on the fuel lines, fuel filter and injector pump to warm things up. I have used a tarp over the tractor to form a "homemade tent" over the tractor to trap the heat and keep the heat where it is needed. Fuel gelling in cold weather is a very common issue. Hope this helps.
/ Fuel issue or something else? #6
If it's gas, you may be shopping for new lips, eyebrows, etc........ahahaaaaa
/ Fuel issue or something else? #7
Diesel takes a little more to get it going than gas. Diesel burns hotter and longer than gas. That is why we use diesel to start a brush fire. And we usually need some paper, say a feed sack to light the diesel.
/ Fuel issue or something else? #8
Thanks!
I sure hope your issue isn't what happened to me, I buy my fuel in 20 litre containers which allow me to keep 8 containers in reserve and my tank of 200 litres full, I have been doing this for more years than I like to remember, and that was my mistake number 1, I lost track of fuel that was purchased in summer and by chance one cold day, around -20 degrees C or -4 degrees F I started my tractor and began to back out of my garage (not heated) and the tractor just stopped running right under the O/H door, I had been using a block heater and a magnetic oil pan heater, so after a while I tried to start again and when it started I drove back in the garage, I reved up the engine to 1500 rpm and within 30 seconds the tractor stopped again, thinking it was a frozen fuel line I put some Isopropyl alcohol in the fuel, mistake number 2, waiting most of the day for the alcohol to melt ice in the fuel got me no where, next day I went to a diesel repair shop and asked for de-icer for my fuel, the mechanic asked a few questions and told me the alcohol was the worst thing I could have done, he said alcohol separates the wax in the fuel and clogs the filter and strainer on the fuel line, He recommended a product they use, Howes diesel conditioner, as he said it does not thaw ice but it simply keeps the fuel from gelling, he recommended about a quart for my 200 litre tank which was full. So home I went and poured in about half the 2 litre can of conditioner, I waited about 5 hours and tried the tractor, same result, it would start and run about 30 seconds then stop, hoping time would get the anti gelling fluid to work I tried this for a few hours, still the same. I knew my only alternative was to drain the tank and add new winter fuel, but taking 200 litres out of a tractor tank in not easy or fast, but it seemed like I had no choice, my next test was to remove the filter and strainer to see what was there, not having a replacement for the strainer I had to drive a 100 k (60 miles) to purchase from my Kubota dealer, which I did the next day, in the mean time I had to find a drum to hold the fuel, 200 litres, and a pump, which I never was able to find, so actually siphoned the fuel into 20 litre cans and dumped them into the clean drum my son got for me, before I drained the tank or filter and strainer I disassembled them to check what I could find, when I removed the filter it seemed clean but the strainer, which has a clear plastic bowl and I thought it seemed quite bright white, when disablement the white was an almost solid junk of was, almost as if you had melted a candle in it, I cleaned it with the Howes diesel conditioner and reassembled it, after priming, which on this tractor is a starter function, explained in the manual, it started and after sputtering revved up but within 30 sec or so it stopped, checking the strainer I could see the white wax was back filling it, I repeated the cleaning and starting several times only to realize that the problem was a tank full of fuel with the wax in suspension and the only solution was to drain the tank and add new winter fuel, this reminds me that I still have to replace the strainer screen, it is a tube like screen made of brass and has almost completely collapsed due to the pressure of trying to force fuel and wax through it, when I went to my dealer I got a two new filters and what I thought was a spare screen strainer, I have been only cleaning the old one since I didn't have a spare on hand, this little screed cost $40.00, but it must be worth in, I must remember to put the new one in my tractor and keep the old one for a spare, I am afraid the old one was too deformed and may have small cracks, or part of the screen may actually let go and get into my injectors, to finish my story, it took me til 9:00pm and again about 4 more hours the next day siphoning the fuel from the tractor, then I had to buy more cans simply to transfer from the tractor to the drum, later make two trips to buy diesel fuel, I didn't have enough empty cans to fill it in one trip and I didn't want to take a chance driving the tractor to the fuel station, I didn't know if I could trust it, but since I have changed fuel, and cleaned the strainer everything seems to run fine, but as a precaution I must install the new strainer, just to be on the safe side. As I write this we are having a major winter blizzard, very high winds, snowing so hard I can't hardly see my garage, think I'll change the strainer before I start clearing snow with my blower, yesterday I got a call from my son, he was feeding hay in the pasture with his tractor using a spear, as he tried to maneuver to place the bale in the holder he upset his tractor, we worked for
hours and could not right the tractor, today we got a huge loader that was able to right it, now he has to wait a day before trying to start it. Never a dull moment, but he didn't get hurt, Thank God.
Hope I didn't discourage you, if you have questions I will try to help if I can.
God bless
Jim
/ Fuel issue or something else? #9
God bless
Jim
Im glad your son didn't get hurt. I like your style, willingness to try and help and your acknowledgement of almighty God. Keep up the good work.
Phil in kansas
/ Fuel issue or something else? #10
Diesel most certainly will light with a lighter. Besides that gas is yellow and diesel is blue or dyed red. No lighter required.
/ Fuel issue or something else? #11
Yellow? Blue? RED? .... How strange..... Perhaps it varies with the region. Around here, gasoline can be almost as clear as water. Diesel is also clear, but with an more amber hue. There is enough variation in the clarity of either one that I can never count on vision alone to decide which is which.
Please be very careful when lighting either one with a lighter. I confess to having done it myself to test what it is that I have in a 5 gallon jug. But think it through.
What I do is to take a paper towel and twist it into a long wick. Then I wet about half an inch of the end with the suspected fuel. Let it dry for few seconds while walking away from the container to an open area. Then I hold it well away from my face horizontally out at arm's length and try to light the wetted end of the twist. Gasoline lights with a Whoosh! and burns rapidly with a clear flame. Diesel lights more slowly and burns with smoky flame.
Hopefully someone else has a better test than mine. If so, I'd sure like to learn it.
rScotty
/ Fuel issue or something else? #12
Thanks for the fine words, you can't go wrong with the Almighty helping you, and all you have to do is ask Him.
God bless all
Jim
/ Fuel issue or something else? #13
I start w/draining fuel all the way to fuel filter,new fuel filter and fuel maybe find another place to purchase fuel.
/ Fuel issue or something else? #14
If you using winter blended diesel( which should be the norm for MA) and the temperature were just below freezing, ice could be the problem either at the tank outlet strainer, in the lines, or on the fuel filter.
If you have summer diesel both wax and ice are a possibility.
/ Fuel issue or something else? #18
One should use #1 fuel in temperatures below 40F. It reads to me like gelled fuel. Cold hydraulics may be compounding the engine load. I was operating my TC29DA yesterday in 0F - 4F temperatures removing "Grayson's" gift of snow (9"). For a lot of reasons (and a sad story) I have had a recent fuel/water challenge. In warmer weather I use PowerService White Bottle year round as recommended. Recently I have been using PowerService 911 as recommended. I suspected my last diesel fill up was #2 (source of challenge). Prior to this storm I refilled the jerrycan with 4.5G of #1 plus a double load of the PowerService additives. The tractor took almost the full 4.5G's. I used the engine block heater and a fuel/hydraulic filter heater and preheated both for 3 hours. Tractor started perfectly and then as the old fuel mix/fuel filter gelling gave me the same "fits" as yours. After 10 - 15 minutes of lugging and rough idling everything went operational. I checked the remaining fuel in the jerrycan this PM, the temperature was 0F/1F, and the fuel was liquid.
I generally go to the high volume stations where I see school buses and commercial vehicles getting their diesel fuel. My primary fuel source will be adding more kerosene with her next diesel fuel delivery. The stations around here "doctor" the fuel mix supplied from the distributor.
I started using a "Mister Filter" again as well.
2012 KENWORTH T800 (INOPERABLE) (A63569)
2012 KENWORTH T800...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2018 Hustler Super 104 Zero Turn Mower (A63116)
2018 Hustler Super...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
