L3200 3rd function - WR Long or Land Pride
/ L3200 3rd function - WR Long or Land Pride #1
roaf3x
My dealer wants 1K for a Wr long valve install plus 300 for delivery/ (9Miles)
I have identified the power beyond and dont really see it as difficult ?
Has anybody faced this recently ?
I am adding a hydraulic angle kit (worksaver) with a crossover valve kit as well. It seems pretty straight forward as well but Ive never really worked with hydro ?
Thoughts from the group??
Thanks
Roaf3x
/ L3200 3rd function - WR Long or Land Pride #2
/ L3200 3rd function - WR Long or Land Pride #3
It's not to hard if you understand power beyond & open center. If you search for it I documented my custom rear 3 spool install in my former L3200. Good learning experience if you are handy.
$1k is about average for a dealer install 3rd function from what I've seen.
/ L3200 3rd function - WR Long or Land Pride #4
I paid $850 for the dealer to install the W&R Long valve as part of the build on my new L6060. Probably would have been more for an older machine retrofit though. The dealer recommended the W&R Long over the LandPride due to price and some alleged problems. He didn't elaborate and I didn't ask.
So far, the W&R Long has worked ok except during the recent cold weather. I use it to control plow angle and one spool sticks open occasionally until the oil warms up.
/ L3200 3rd function - WR Long or Land Pride #5
I'll say W.R. Long if you only want ONE thing controlled. Like Fallon, for less money, I installed 3 spool valve to control a grapple and top and side hydraulic links.
/ L3200 3rd function - WR Long or Land Pride #6
The Kubota dealer installed a W R Long unit along with my Land Pride grapple. Install of hydraulic third function plus grapple was $1000.
/ L3200 3rd function - WR Long or Land Pride #7
I wouldn't say less money. I think I was around $2500 for my 3 spools & TnT cylinders along with all the plumbing. I got a nice valve setup though. You could definitely do a much more economical build than I did however. I think you'd be hard pressed to make it under 4 figures for 3 spools even with free labor.
/ L3200 3rd function - WR Long or Land Pride #9
I got the Land Pride 3rd function from Messick's. The L3200 kit is currently listed for $698 + shipping. The install on my MX5200 was quite easy. I assume the L3200 would be as well, looking at the instruction sheet.
/ L3200 3rd function - WR Long or Land Pride #10
WR Long kit, dealer installed, for $1000 is market price. I’ve bought three WR Long kits and wouldn’t do it any other way. Adding rear remotes is a whole different way.
/ L3200 3rd function - WR Long or Land Pride #11
I think the dealer charged me $1200.00 to install the land pride 3rd function on my MX5100.
Guess I got screwed..
I should have researched this better and bought and installed myself
/ L3200 3rd function - WR Long or Land Pride #12
Sorry to bring up a dead thread but mine just quoted me the same. Plus $75 for PU/Delivery of 25 total road miles.
/ L3200 3rd function - WR Long or Land Pride #13
I started down the road to building my own and finally decided it's not worth it to ME...I actually ordered a valve but it was the wrong one because I based my purchase on a picture of one for sale on E-bay that the seller just used as a representative photo...so I did figure out which one I needed and still after piecing together all the necessary parts its around $500+- and you have to be sure you make all the Hydraulic connections correctly without leaking, etc. One thing I could not determine is if you need the "Power Beyond Plug" don't think so, but? It was going to take me a lot of time and trial and error to figure out. you could build for around $350 if you use a simple momentary rocker switch which you have to figure out where to mount it. I ended up putting an alert on E-bay for a Land Pride and purchased one for $590...just luck. I have a spreadsheet of all the parts you need and I AM NOT A CERTIFIED MECHANIC OR HAVE ANY EXTENSIVE KNOWLEDGE OF THIS...SO USE YOUR OWN JUDGEMENT IF YOU USE MY LIST AND VERIFY YOURSELF.View attachment 586671 email if you want the excel spreadsheet.
/ L3200 3rd function - WR Long or Land Pride #14
(2) BUNDLE OF MISC SIZE USED TIN UP TO 31' LONG (A62131)
(2) BUNDLE OF MISC...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2024 John Deere 835M Gator (A63116)
2024 John Deere...
2001 Ford F-150 Ext. Cab Pickup Truck (A61568)
2001 Ford F-150...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
