L3200 3rd function - WR Long or Land Pride
/ L3200 3rd function - WR Long or Land Pride #1
roaf3x
My dealer wants 1K for a Wr long valve install plus 300 for delivery/ (9Miles)
I have identified the power beyond and dont really see it as difficult ?
Has anybody faced this recently ?
I am adding a hydraulic angle kit (worksaver) with a crossover valve kit as well. It seems pretty straight forward as well but Ive never really worked with hydro ?
Thoughts from the group??
Thanks
Roaf3x
/ L3200 3rd function - WR Long or Land Pride #2
/ L3200 3rd function - WR Long or Land Pride #3
It's not to hard if you understand power beyond & open center. If you search for it I documented my custom rear 3 spool install in my former L3200. Good learning experience if you are handy.
$1k is about average for a dealer install 3rd function from what I've seen.
/ L3200 3rd function - WR Long or Land Pride #4
I paid $850 for the dealer to install the W&R Long valve as part of the build on my new L6060. Probably would have been more for an older machine retrofit though. The dealer recommended the W&R Long over the LandPride due to price and some alleged problems. He didn't elaborate and I didn't ask.
So far, the W&R Long has worked ok except during the recent cold weather. I use it to control plow angle and one spool sticks open occasionally until the oil warms up.
/ L3200 3rd function - WR Long or Land Pride #5
I'll say W.R. Long if you only want ONE thing controlled. Like Fallon, for less money, I installed 3 spool valve to control a grapple and top and side hydraulic links.
/ L3200 3rd function - WR Long or Land Pride #6
The Kubota dealer installed a W R Long unit along with my Land Pride grapple. Install of hydraulic third function plus grapple was $1000.
/ L3200 3rd function - WR Long or Land Pride #7
I wouldn't say less money. I think I was around $2500 for my 3 spools & TnT cylinders along with all the plumbing. I got a nice valve setup though. You could definitely do a much more economical build than I did however. I think you'd be hard pressed to make it under 4 figures for 3 spools even with free labor.
/ L3200 3rd function - WR Long or Land Pride #9
I got the Land Pride 3rd function from Messick's. The L3200 kit is currently listed for $698 + shipping. The install on my MX5200 was quite easy. I assume the L3200 would be as well, looking at the instruction sheet.
/ L3200 3rd function - WR Long or Land Pride #10
WR Long kit, dealer installed, for $1000 is market price. I’ve bought three WR Long kits and wouldn’t do it any other way. Adding rear remotes is a whole different way.
/ L3200 3rd function - WR Long or Land Pride #11
I think the dealer charged me $1200.00 to install the land pride 3rd function on my MX5100.
Guess I got screwed..
I should have researched this better and bought and installed myself
/ L3200 3rd function - WR Long or Land Pride #12
Sorry to bring up a dead thread but mine just quoted me the same. Plus $75 for PU/Delivery of 25 total road miles.
/ L3200 3rd function - WR Long or Land Pride #13
I started down the road to building my own and finally decided it's not worth it to ME...I actually ordered a valve but it was the wrong one because I based my purchase on a picture of one for sale on E-bay that the seller just used as a representative photo...so I did figure out which one I needed and still after piecing together all the necessary parts its around $500+- and you have to be sure you make all the Hydraulic connections correctly without leaking, etc. One thing I could not determine is if you need the "Power Beyond Plug" don't think so, but? It was going to take me a lot of time and trial and error to figure out. you could build for around $350 if you use a simple momentary rocker switch which you have to figure out where to mount it. I ended up putting an alert on E-bay for a Land Pride and purchased one for $590...just luck. I have a spreadsheet of all the parts you need and I AM NOT A CERTIFIED MECHANIC OR HAVE ANY EXTENSIVE KNOWLEDGE OF THIS...SO USE YOUR OWN JUDGEMENT IF YOU USE MY LIST AND VERIFY YOURSELF.View attachment 586671 email if you want the excel spreadsheet.
/ L3200 3rd function - WR Long or Land Pride #14
UNUSED IRMC HIGH-END ELECTRIC MASSAGE CHAIR (A62131)
UNUSED IRMC...
2020 Kubota KX057-4 Mini Skid Steer (A61166)
2020 Kubota...
New/Unused Wolverine 72in Quick Attach Tiller (A61166)
New/Unused...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61567)
2025 JMR 72in...
2018 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F70JUB03642 (A61165)
2018 Ford Escape...
Year: 2002 Make: Dodge Model: Ram Pickup Vehicle Type: Pickup Truck Mileage: 102,827 Plate: Body (A61568)
Year: 2002 Make...
