2x72 belt grinder build
/ 2x72 belt grinder build #1
dzljon
Advertiser
Jacksonville florida
none
We came across jeremy Schmidt's belt grinder build on YouTube and loved it so we are attempting to build our own. This is what we have so far. Started by machining .500 flat bar to fit properly then drill and tap to bolt it together instead of welding. Then we went to work drawing and cutting all the bracket and tabs, next is to fit it all up and tack it together 20171219_163606.jpgIMG_20171220_180056_001.jpgIMG_20171224_204510_570.jpg20171225_141542.jpg20171225_170515.jpg20171227_144228.jpg20171227_171235.jpg20171227_172151.jpg20171227_172643.jpg20171227_180611.jpg
/ 2x72 belt grinder build #2
Excellent! I also saw his video and was impressed. I bought the plans but haven’t got started yet.
/ 2x72 belt grinder build #3
/ 2x72 belt grinder build #10
I like your idea of machining the bar stock to fit and using bolts instead of welding.
/ 2x72 belt grinder build #12
Man that thing looks BURLY!!! Is there a reason you are going with such heavy duty materials?
Made the spring for the tensioner today, not very exciting IMG_20180104_181300_289.jpg
/ 2x72 belt grinder build #15
I saw his video and I was really impressed. Its on my 'to do' list, that is for sure.
Do you store your motor in the same place as Jeremy or are you storing it elsewhere at the moment?
I don't have the motor right now, for mock up I am using a burned up compressor motor
Today's progress on the 2x72 grinder, we re-cut the motor mount plate to make it one piece and cut star wheels for the bolts and tracking adjustment.
I received an email from jeremy authorizing me to reproduce the pieces if you need them for your project, the only stipulation is you have to buy the plans from him 20180107_145019.jpg20180107_154703.jpg20180107_160048.jpg
/ 2x72 belt grinder build #18
Interesting about selling parts. It would of course deprive me of the infinite pleasure of buying a plasma table, a major loss. When you have time can you put a parts and price list together? I already purchased Jeremy’s plans and I ‘m sure we can find away to confirm that.
Thanks,
Bob
Thanks,
Bob
Yep I will get that put that together, I cut mine from .250 steel and Jeremy's plans call for .375, do you have a preference, it will effect the cost
/ 2x72 belt grinder build #20
Seems like 3/8” is overkill? I’ll have to watch his video again and look over the plans but if you decided to go with 1/4” it’s probably fine. Will 3/8” add about a third to the price, or is it not that simple?
2016 Ford F250 Crew Cab Service Truck (A64194)
2016 Ford F250...
John Deere 8245R (A64119)
John Deere 8245R...
BUNDLE OF R19 INSOLATION & RD DUCT INSULATION (A64281)
BUNDLE OF R19...
1997 FORD F-350XL TRUCK (A64276)
1997 FORD F-350XL...
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
