2x72 belt grinder build
   / 2x72 belt grinder build #12
Man that thing looks BURLY!!! Is there a reason you are going with such heavy duty materials?
The heavy material is to help keep vibration to a minimum and it made in the USA:)
Made the spring for the tensioner today, not very exciting IMG_20180104_181300_289.jpg
   / 2x72 belt grinder build #15
I saw his video and I was really impressed. Its on my 'to do' list, that is for sure.
Do you store your motor in the same place as Jeremy or are you storing it elsewhere at the moment?
I don't have the motor right now, for mock up I am using a burned up compressor motor
Today's progress on the 2x72 grinder, we re-cut the motor mount plate to make it one piece and cut star wheels for the bolts and tracking adjustment.
I received an email from jeremy authorizing me to reproduce the pieces if you need them for your project, the only stipulation is you have to buy the plans from him 20180107_145019.jpg20180107_154703.jpg20180107_160048.jpg
   / 2x72 belt grinder build #18
Interesting about selling parts. It would of course deprive me of the infinite pleasure of buying a plasma table, a major loss. When you have time can you put a parts and price list together? I already purchased Jeremy’s plans and I ‘m sure we can find away to confirm that.
Thanks,
Bob
Thanks,
Bob
Yep I will get that put that together, I cut mine from .250 steel and Jeremy's plans call for .375, do you have a preference, it will effect the cost
   / 2x72 belt grinder build #20
Seems like 3/8” is overkill? I’ll have to watch his video again and look over the plans but if you decided to go with 1/4” it’s probably fine. Will 3/8” add about a third to the price, or is it not that simple?
2004 KENWORTH T800 HOT OIL UNIT (A58214)
2004 KENWORTH T800...
2327 (A58376)
2327 (A58376)
Self Leveling Rotary Laser (Survey Equipment & Grade Control) (New/Unused) (A59225)
Self Leveling...
Giyi Mini Auger (A57149)
Giyi Mini Auger...
16ft Enclosed Trailer (A57453)
16ft Enclosed...
Giyi Mini 32' Mixing Bucket (A57149)
Giyi Mini 32'...
