Buying Advice Need Second Stihl Commercial Chainsaw, Larger Than MS261
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
I have worked a Stihl MS261 chainsaw since November 2012. Wonderful saw from my local "full service" Stihl dealer, in an area where there is considerable forestry employment.
The MS261 has an 18" bar, which give an overall length of 33". The depth of the bed on my Kubota RTV500 is 33-1/4" so MS261 is a perfect fit. Fit is why the MS 261 was chosen as my primary saw from the Stihl commercial stable.
Since Hurricane Irma I have been cutting up more grounded large trees, 90% Water Oaks and Live Oaks, than in the past. I need a second Stihl, with a longer bar than MS261's 18" bar. It will take me at least a year to transport all the Irma casualty trees to our community burn pit for incineration. I use Stihl 'RS' saw chains.
Should I buy 50% more horsepower with the new saw? Will an 'RS' saw chain be 'wild' on a 50% more powerful saw? I need a 24" bar on my second saw.
At age 70 years will I have the strength required to pull-start a larger saw? I have no problem starting or controlling my carefully maintained MS 261 but what about a more powerful chainsaw? I am in north Florida, so cold weather is not a concern.
I will NOT be dropping trees with the new saw. At age 70 years, if I do not feel comfortable dropping a tree with the MS 261 I defer to a Tree Service.
I am only interested in the Stihl brand, new, in commercial grade, as my local dealer is excellent with service. I use chainsaws enough so purchase price is mostly irrelevant. I have other Stihl gas powered tools.
I have been using chainsaws for 30 years without injury, a record I wish to maintain.
Recommendations?
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #2
I wouldn't bother with the 362, its too close in power to what you have. Moving up, I believe the 441 and 461 are the same weight, so I'd go with the slightly larger displacement on the 461 for cutting through big hardwoods. I haven't used to many saws in my lifetime, but didn't really notice much of a difference in starting them. Working long hours with a heavier saw has a much bigger impact on your body!
Even on the largest tree trunks I have to deal with, I should not have to make more than six cuts with the new saw, before reaching a reduced trunk diameter where I can use the MS261.
At age 70, retired, when I get tired, I stop. I know I am a little fragile and it takes soooooo long to recover from strains and injuries these days. I avoid over-doing it.
Thank you for the recommendations. :)
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #4
I believe Stihl will be releasing the MS 462 to the U.S. market soon. It’s already out in Europe (go figure)
That will be my next saw. I’m currently cutting with a MS361 and an FS560 brush cutter. The 462 is supposed to be very lightweight for its size and more powerful that the current 461.
I do not have the facts on hand however, but worth looking into.
I personally like the new technology with electronic control.
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #5
Husqvarna 372XP or if you insist on the Stihl I believe a 660 is comparable.
I believe Stihl will be releasing the MS 462 to the U.S. market soon. Itç—´ already out in Europe.
PISTON you are The Man.
MS 462 is a new model revelation to me.
LINK: stihl ms 462 chainsaw - Google Search
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #7
All things considered the 362 is an awsome saw and lighter weight then the big boys! It will take up to a 24" bar so the larger trees will not be to much trouble! The 261 you have I like with a 16" bar and on the 362 I normally run a 18" bar myself. The larger says I still like the 18 to 20" bar normally.
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #8
i like having companion saws, smaller one for bulk of limbing, etc, and a larger one for the occasional big stuff. have a ms 260 (similar to yours), great saw, and a ms 460 for larger stuff. having 2 helps w/distributing the workload. the ms 461 series is an awesome saw and earns it's keep too. you already have a pro smaller saw, the ms 461 would be my recommendation though pricey. i've always gone w/the pro models. and tried to keep the bar length on each saw @ the minimum length of what i need. personally, i'd steer clear of going 24" on a larger saw as that exposes more cutting teeth for possible injury. but that's only my application.
@ 70 myself, feel fortunate working the farm w/tractor & saws with no physical limitations. but then again, i'm always aware of what work would put me @ risk. being retired, have the time to do it safely & get the job done. best of luck on your decision
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #9
I have a 362C and recently got a used 460, which is very similar to the 461. The 362 starts very easily with the compression release. It's easier to start than my 025, which does not have a compression release. The 460 is significantly harder to start- takes much more of a pull. And the m-tronic on the 362 makes it start easier than the carbed 460. I often shut off saws when I'm moving wood or lining up the next cut; with the 460 I'll be letting it idle more. The 460 is a lot heavier than the 362 also. I'm 6' and 150 lbs with not a lot of upper body strength. I can do some limbing above my shoulders with the 362 but not the 460. I got it for big wood only. The 362 and 025 get used for smaller trees and limbing. I've used a 24" bar on the 362 but it's kind of slow on wood with the bar fully buried. That's the largest bar Stihl recommends for that saw. I also have an 18" for it. 20" would be perfect.
What'd I'd recommend to you is a 462C but they're not in the US yet. The 441C has m-tronic and spring anti-vibe, the 461 old school carb and rubber dampers. The 462 weighs significantly less than either and makes the same HP as the 461. If I like the 460 and use it a fair amount I may buy a 462 when it's available.
I use both regular and "safety" low kickback chain. Either one will kick back if you make a mistake... the low kickback chain just kicks a bit easier. Either way you have to be paying attention. The more powerful the saw the faster things can get out of hand if you make a mistake.
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #10
The 372 is about equivalent to the Stihl 441, about 70cc saws. The 660 is a 91CC, right between the 390 and 395XPs for displacement. These are getting awfully heavy....
I'll agree with that. If you can get the new model, do it!
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #11
I have several Stihls including a 362 with a 20" bar, and while I agree with above, my concern would be the larger powerhead with a 24"-25" bar being more strenuos and maybe unnecessary. Would a 20" bar work, as you can work a pretty large trunk with that size bar.
I think best thing to do is go and check out saws at your dealer for comparison with bar size you prefer. I wouldn't go larger than the 441 size saw. As far as starting force, the decompression valve takes care of that for you.
Good luck and post what you decide.
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #12
A 90 cc saw is pretty big. A 70 cc saw is what I’d want. Otherwise you wouldn’t notice much improvement. Your saw is 11.6 pounds and 3.5 hp. A 372 is 14.4 pounds and 5.5 hp.
I always advise those considering a second, larger tractor, increase at least 50% in bare tractor weight or you will not really notice a difference.
In saws, I suppose: Increase at least 50% in POWER or you will not notice a difference.
Right?
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #14
70cc or a little more is what I'd want to accompany your 261. That size saw will be perfect with a 25" bar in oak. I wouldn't consider a 362.
So, your options are 441, 461, or wait for the 462. The 441 and 461 are pretty much the same weight. Either will do what you want, but the 461 does have a little more per. The other differences are that the 441 is m-tronic (computer sets the fuel/air mixture), and the anti vibration system consists of springs. The 461 relies on your skills with a screwdriver to set the tune, and uses rubber mounts to reduce vibrations. There's pros and cons to each setup. The 462 is m-tronic, spring mounted, lighter, and more powerful than either of the other two. BUT, we don't know exactly when they'll be available. Probably 2018, but who knows when. Also, we can cross our fingers that they've got the bugs worked out prior to the US release, but it's not uncommon for new models to have some problems early on. FWIW, the reviews from Germany have been really good.
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #15
good info there. agree that the op would do well to look @ ms 46x series. given the 461 @ slightly less than $1k currently plus tax, wonder what the price tag will be on the 462 series. believe i'll stick w/my 460 albeit it's heavier than the upcoming model. thankfully, don't make my living w/the saws
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #16
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #17
Sorry I missed.
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #18
Right?
I’ve never had a 50 percent more powerful saw than my 50cc saw. My 5.5hp over my 3.5hp ( my Husqvarna 353 and the OPs 261 are pretty close) is more than a 50 percent improvement. I know the 372 over the 353 is a BIG difference.
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #19
Supposedly the 462's list price is slightly less than the 461's in the markets that it is available in. Who knows if that will be true when it's available in the US. Stihl is marketing it as the replacement for both the 461 and the 441, and at 72ccs it's displacement is closer to the 441's 71 than the 461's 76. It would be logical to price it between the 441 and 461 but pricing is not always logical. People who have talked to Stihl reps seem to think it'll be the middle of the year before it's available here.
/ Need Second Stihl Commercial Chainsaw, Larger Than MS261 #20
It's not a great indicator, but in Germany the 462 is priced just a little BELOW the 461.
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2013 INTERNATIONAL MA035 VACUUM TRUCK (A59905)
2013 INTERNATIONAL...
2015 GMC Sierra 1500 SLT Crew Cab Pickup Truck (A59230)
2015 GMC Sierra...
2013 GREAT DANE 53FT REEFER TRAILER (A59905)
2013 GREAT DANE...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
More info coming soon! (A56859)
More info coming...
