MT125 Backhoe owners question - Do you have a boom float?
   / MT125 Backhoe owners question - Do you have a boom float? #1
mslisaj
Gold Member
Klamath Falls, Oregon
LS MT125 Loader/Backhoe John Deere Sabre Lawn tractor w/Snow Blade
I was studying the owners manual for the LB1107 backhoe on my MT125 and on page 14 under "Backhoe Operation" and "Boom and Swing Controls" it states that if you "push the lever fully forward into the detent position, allows the boom to float. The boom can drift up and down without pressure". Well I have investigated this on my machine with the engine running and with it off and I DO NOT have a detent position. Does anyone else's LB1107 hoe have a float position? I realize that LS may copy manual sections from various machines but this leads me to ask if any one else's LB1107 has a float position.
Thank you gentlemen for reading and taking your time to respond to my question here.
Regards,
Lisa
   / MT125 Backhoe owners question - Do you have a boom float? #2
Regards,
Lisa
Yes, there is a float position. When I was digging a septic system trench, when I was deep at full extention and pulled back on the dipper arm, it would float back as long as I had the boom stick fully forward.
   / MT125 Backhoe owners question - Do you have a boom float? #3
The loader is also supposed to have float, it should also be when the stick is full forward.
Well "LS mt125 owner" you have me a little confused here. My loader definitely has the usual detent float of the loader bucket. But I have not found a "detent" float for the back hoe. Now the book only mentions float on the "boom". So you're saying if you hold the boom control full forward (there is no detent lock for this position) and pull back on the dipper the boom will float as the dipper comes back??? Is this correct?
But in my original post here I was quoting what was in the book and it mentions a "detent" full forward position on the boom. Do you have that?
   / MT125 Backhoe owners question - Do you have a boom float? #5
I remember putting the backhoe control into the detent position, but it has been a few months. I have not really used it.
   / MT125 Backhoe owners question - Do you have a boom float? #6
I remember when I was shopping for my SCUT, I ran into variations as I actually tried out the MT125 a few times at different dealers while comparing, and I found 3 different versions of the same labeled units, one that had NO float on either the BH or FEL, one that had float on the FEL only, and one that just came off a truck that had the float on both, IIRC, but honestly I looked at so many tractors I may be mistaken - again, but I just thought it strange that there were different variants on different dealers lots. Maybe it's that they used whatever valve body they could get their hands on to get them to market and then fitted with the float version later??
Thanks Frugalangler for your comments. I apparently have the model with the float on the front end loader and NO float on the backhoe. The labels on the backhoe do not indicate a float position like the loader label does. But what caught my attention as I noted above that on page 14 of the backhoe operators manual they definitely talk about a float position for the boom all the way forward into a detent.
Also to "LS mt125 owner" comment about holding the boom control forward. Well all that does for me is raise the tractor if the bucket is on the ground. There is no bypass in the valve body for my machine.
What's truly interesting too is the three men that have responded to my question all say there is a detent position for "floating" the boom. No one has responded that their hoe does NOT float either. Hopefully we'll get some more responses here so we can build a concenses.
Thanks for responding gentlemen.
:confused3:Could this post get any more confusing or mysterious? With the lack of a definitive, overwhelming response here I contacted my dealer today. They are telling me that there is a "detent kit" that I could install in "these models" of back hoes to give them the float. Really was my response? I just don't know what to think now. Some claim they have it and other's don't know. I guess I'm the only one that read the manual that noticed that it said how to use the "float" and my hoe doesn't seem to have that option. Just kind of interesting...............
Still hoping you guys will try your MT125's with the LB1107 hoe's and see if you have a float and let me know. Thanks again for helping me with this mysterious question................. :confused3:
   / MT125 Backhoe owners question - Do you have a boom float? #9
Would you use the float feature with the hoe to worry about it? I'm going to play dumb here as I personally have little back hoe time. My wife has many back hoe hours, dunno if she ever used it. I've had some float time with the loader bucket. Would you use the hoe float to level the trench you dug or?
I'm just asking if other MT125 owners with LB1107 backhoes have a float position? If the main consensus here is "they don't have a float" then my backhoe is working normally. If the majority of the responders say "they do have the float" then I have an issue with my brand new backhoe and I would like to get it fixed. Pretty simple. If I never read the manual for my machine telling me how to use this feature I would have never asked this question.
   / MT125 Backhoe owners question - Do you have a boom float? #11
Can't help on the MT tractors, but what would one use a float position on a backhoe for? I've got a JD backhoe on mine and can't figure out what I'd ever use a float position for.
   / MT125 Backhoe owners question - Do you have a boom float? #12
Same here. My hoe supposedly has the float but I don't know why or how to use it. 'Splain.
   / MT125 Backhoe owners question - Do you have a boom float? #15
   / MT125 Backhoe owners question - Do you have a boom float? #16
Yes, are they just smoothing the bottom of the trench, or what? Not a good video. Guess I will try to figure it out next summer.
   / MT125 Backhoe owners question - Do you have a boom float? #17
To the MT owners, you would feel the detent in the boom lever and you wouldn't have to have the hoe mounted to get Lisa her answer. It will just snap in place like the float in your bucket.
Mr. "tomplum" you get it my friend!! If the detent is there just like the loader you have a float. The hoe does not have to be mounted or the engine running to test this for me. My tractor does not have this feature and I'm curious why, as it's plainly mentioned on page 14 of the LB1107 Backhoe Operators' Manual. If it was not an option on my model or discontinued I'm okay with that. But if there is something wrong with my hoe and the valving I would like to get it fixed while I have warranty.
I'm just really beginning to think this LS MT125 subcompact tractor and backhoe is a rare combination. With all the folks that have looked at this thread I would think most of these responses would be from MT125 owners saying yes or no. The two men that have MT125's here say they have it but one hasn't used it in a while and didn't expand his answer and the other gentleman speaks of having to hold the control in that position.
Also as I have mentioned earlier when I have asked my dealer about it I get a "deer in the headlights response" that "there is a detent kit I can buy". I cant' get a straight answer from the dealer either. So thanks "tomplum" for sensing my frustration here. :thumbsup:
Best regards,
Lisa
   / MT125 Backhoe owners question - Do you have a boom float? #19
I know I "found" the float position when I was digging the septic. The problem is I can't remember exactly what position I actually put the levers in. I cannot "feel" a detent in the boom lever. The sticker does show "float" on the boom side, pushing it forward. I think this is what I did while pulling the dipper back. Gave me a nice clean level bottom on the trench. I just got off duty tonight, I'll see if I can get pics of the sticker, and if I get lucky, a chance to play with it (have to run errands w/ the Mrs tomorrow). If not I'll get them on Mon. Also, I cannot feel a detent on the loader... I Just push it all the way forward.
Thanks "LS mt125 owner", definitely the Mrs. comes first but I'll be interesting to see the picture and hear your report when you get the machine out and try it. If the manuals are handy check out the manual for the LB1107 Backhoe on page 14 and see what that says............
Appreciate your help and I'm anxiously waiting for your report.
Regards,
Lisa
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2013 KOMATSU...
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
500BBL WHEELED...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
