Quality Electric Lot Splitter?
/ Quality Electric Lot Splitter? #1
ultrarunner
Epic Contributor
SF Bay Area-Ca Olympia WA Salzburg Austria
Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
Looking for a quality electric log splitter in the 20 to 25 ton range... should work on 20 amp 120v but could make 240v if needed.
Had a friend with one years ago with a Baldor commercial motor he used in inside his shop.
Searched and seems the only electric units are cheap 5 ton and less.
His may have come from Northern but search turns up gas only.
/ Quality Electric Lot Splitter? #2
I'm pretty sure swisher makes a quality electric splitter. If you don't find a suitable solution it wouldn't be hard to convert a regular splitter to electric.
/ Quality Electric Lot Splitter? #4
Buy a 3ph splitter and industrial hydraulic motor/pump. There are lots of them surplus around here but most are three phase. It's a great idea. Not having to listen to some horrible little gas engine.
I just helped a friend convert his power pack from gas to electric. 5 HP 230 Single Phase. He uses it for bending and line boring. He may use it on his splitter as well. He was actually surprised how much noise the pump makes.
/ Quality Electric Lot Splitter? #5
WEN makes a good electric splitter but I think 6 ton is the largest I have seen. I have had a wen electric splitter for 4 years and have used the **** out it it with no complaints. I was surprised what it can do.
/ Quality Electric Lot Splitter? #6
SuperSplitter: Order Form
This is the American Made version of what you want. DR and others are importing them as well. The kinetic splitter is what works best on 120v
Great response...
I called Timberwolf yesterday and learned they have a electric in the works for next year.
My 22 ton gas splitter has never failed but with large rounds I find it helps to "Read" the wood for a natural crack... still amazed how it bears down and then powers through... probably 30 years old.
I've been running to empty due to the gas available here and the splitter could easily go a year between a week of splitting.
Converting or using a power pack sounds like an option...
The shed has two 20 amp circuits that could be reconfigured for 240 volt is needed... time to watch Craigslist...
My 22 ton Duer has a small Briggs and Stratton engine that continues to perform well...
/ Quality Electric Lot Splitter? #8
I have the Swisher. Terrific machine. Everything except for the motor is their standard 22 ton. Love the quiet. And no ethanol-fouled carburetor. It comes set up for 120v but can be converted to 220v. Ours works fine on 120v, even with an extension, BUT the extension should be short (<50ft) and HEAVY (12g). For really gnarly pieces, one has to occasionally "feather" the control/ram lest it stall and trip the breaker.
22 Ton Timber Brute Eco Split 12 Volt Electric Full Frame Log Splitter LS22E - Log Splitters
/ Quality Electric Lot Splitter? #9
I'm in the but one and put an electric motor on it camp.
And yeah, the little two stage pumps are quite noisy.
We put a 3 phase motor on a huskee 27 ton powered from a vfd.
It's amazing what going up or down just a few hertz does for the harmonics/noise.
Wonderful to have a report from the trenches...
I'm thinking since they bring the rounds to the wood shed with the tractor and my Sister In Law really isn't one for gas equipment... an electric would be ideal.
She would get frustrated with the gas saws to the point she wanted no part of any of the gas equipment.
She does love the battery Stihl CB200 chainsaw... so another plus there.
Ethanol is a big problem here with small engines...
I had an antique car in the carport... stored with half a tank for a couple of years... it was not the plan but that is how it turned out... the normal temperature variation through the day with humidity accumulated a lot of water... wouldn't have believed it had I not seen it clearly in the glass fuel bowl
/ Quality Electric Lot Splitter? #11
Here's the work of my "37" ton. It's a 5" cylinder so it's probably really around 25 ton. My other splitter had a 4" cylinder which is likely around 15 ton which I found was adequate. IMG_0732.JPG
/ Quality Electric Lot Splitter? #12
My wife is the primary operator (her Dad as helper). Make sure to get the (optional?) "side tables". They make handling pieces much easier and safer.
/ Quality Electric Lot Splitter? #13
My thoughts on them are the opposite. I've yet to find a good use for them except create another pinch point. An out feed table is great though.
/ Quality Electric Lot Splitter? #14
Great response...
A 5 hp electric motor will require a 30 amp 240 volt service. If you buy a 3450 rpm motor, it will run the hydraulic pump at about the same speed as a gasoline motor, and deliver pretty decent performance.
/ Quality Electric Lot Splitter? #15
I had a 3 hp electric motor on an 11 gpm 2 stage pump. That's the same pump used on the average wood splitter with a 5 hp gas motor.
/ Quality Electric Lot Splitter? #16
3HP is borderline.
If its what you have, I wouldnt be afraid of using it. But if you are buying a motor to make the swap, I'd go with a 5HP.
Dads splitter is a huskee 27t and has the 11gpm pump.
Put on a 3HP motor with a SF of 1.15. FLA on the nameplate is 8.8A or something like that.
To make max pump pressure (dead heading by extending cylinder all the way and holding for a moment), it wants to see 11A.
So in theory I "could" burn the motor up.
But leaving the amp clamp on the lead, and through the process of splitting.....never saw a spike over 8A. And if it did, it was so brief that the meter didnt pick up on it.
I would much prefer a 5hp motor. But the drive I am using wont start a 5.
/ Quality Electric Lot Splitter? #18
3HP is borderline. Dads splitter is a huskee 27t and has the 11gpm pump.
8.8 amps on 240V is a pretty weak 3hp, REALLY it's barely a 2hp, no matter what they call it.
11 amps on 240V is a STRONG 2hp motor, 15 amps on 240V would be what a 3hp motor should draw!
SR
/ Quality Electric Lot Splitter? #20
