Price Check L6060 or L47
/ L6060 or L47 #1
fydollaho
Round Hill, VA
Kubota B2650
Was quoted a L6060HST with 3rd function valve, LA1055 with QA 72" Round Bucket, BH92 with QA 18" bucket for $44,985.00 from another dealer. Reasonable?
My current dealer just dropped an L47 off for the weekend as he thinks it’s better for the land clearing work I️ have on my list and he can get the pricing close. Possible?
I’m also looking at the Kioti NX. Lift capacity, features, and price motivating me.
Trading up from my B2650 which is great machine but I️ need stump pulling power and the ability to do more faster.
/ L6060 or L47 #2
/ L6060 or L47 #3
I'd absolutely go for the L47. I'd like to have one, but wonder how the OEM 3 point rear handle a box scraper...
/ L6060 or L47 #5
L47 for sure if you need to do excavation work.
/ L6060 or L47 #6
L47 is a lot more bullet proof than the 6060. Not saying anything bad about the L6060 just the L47 is a purpose built wrecking machine. Should last forever if you keep it lubed.
A TBL is an industrial machine, the Lxx60 is an ag machine. The industrial machine will be beefier in general with a stronger loader. The hoe will be a lot beefier. An ag machine will have bigger tires & be more focused on traction.
That's a good price on the L6060. My fully loaded L4060hstc was about that.
I'd have thought about a TBL over my L4060 if it could have been got with a cab.
/ L6060 or L47
I’m worried that the woods and a cab just won’t get along. Kubota offers a heated cab on the L47.
/ L6060 or L47 #8
Simple
Do you Need a small commercial TLB or is an Ag. type tractor going to suit you better in the long run. TLB is not a great Ag tractor, Ag tractor not a good TLB.
/ L6060 or L47 #9
There have been a few good threads lately about decisions on cabs. I’m debating the same, cab or no cab, on an L6060HST. I am wanting to trade my current tractor to get a backhoe for land clearing and a grappler for debris removal. I am strongly leaning towards a cab and being more careful. Someone in one of the other threads pointed out that if you get hit with the debris that could break the glass it could injure you anyway. I think my biggest fear is getting up against a tree with the cab but long term once I get things cleared up the cab would definitely be an asset.
I’ve definitely been in some thick stuff I shouldn’t have been in before when clearing with my current tractor and have to admit been whacked a few times for that stupidity. :)
I’m haven’t looked at the L47. My neighbor from a couple years back before I moved always told me he wanted one of the more commercial machines like that. He always said they beat them up on job sites and they would last forever as others have said.
Matt
/ L6060 or L47 #10
Do you need a small commercial TLB or is an Ag. type tractor going to suit you better in the long run?
TLB is not a great Ag tractor.
~ ~ X 2 ~ ~
/ L6060 or L47 #11
If you want to pull a bunch of stumps get a mini ex. Good to have a separate tractor and mini ex.
/ L6060 or L47
An excavator would be awesome. Honestly, the L47 weight and lift capacity over my B2650 makes a ton of difference.
/ L6060 or L47 #13
Question for you... What makes a mini ex better for stump removal versus a backhoe on a tractor? Is it the motion of the machine itself whereas a tractor doesn’t move around as easily?
/ L6060 or L47
Weight and digging force. And the ex has the blade that you drop that acts like a brake against the digging arm.
/ L6060 or L47 #15
Ah good to know, thanks! I wouldn’t have thought about the blade helping with it.
/ L6060 or L47 #17
There is an advertisement on the local TV
station for L47’s. PARC equipment is selling
L47’s for $5,000 off and $499.00 a month.
Sounds real good, but what’s in the fine print?
The op might check with them to get a better
idea of what the offer actually is.
They have about 4 locations in WV.
/ L6060 or L47 #18
There are tradeoffs with anything, even a mini-ex. One of its strengths is easy maneuvering around the jobsite - very handy for grubbing stumps. But one of its weaknesses is getting to and from the jobsite. You either go slowly on its tracks or have to trailer it, and a mini-ex that outdigs an L47 will weigh 10,000 lbs. And the mini-ex won't bush hog your place when you're done digging. If you've got the resources and the space for multiple machines, by all means go for it. But lots of us - me included - cleared a lot of stumps with our CUT backhoe attachments over the years.
/ L6060 or L47 #19
Likely that is 84 month financing with 20% down. My quick math sees that about 50k right? Seems right.
/ L6060 or L47
I’ll give them a call. I’m in Western Loudoun County VA so PARCS is relatively close.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A59908)
2005 MACK CXN613...
New/Unused Landhonor Air Impact Wrench (A61166)
New/Unused...
