Tow chain anchor points
/ Tow chain anchor points #1
GSP652
New Member
Milledgeville
2017 Mahindra 2538 HST
Has anyone added clevis hitches to the front axle to help with attaching tow chains instead of wrapping them around the axle and scratching the paint to pieces? I bought a 1/2" (too big) and 3/8" (too small). I'm thinking about ordering some 7/16" for the front axle. They are rated 3000lbs each. If I'm using 2 of them, would that be ok just to secure the front of the tractor? I would be using 4 anchor points total.
/ Tow chain anchor points #2
I don't think that small hole on the axle would have enough strength for use as a tie down point. Putting a clevis in there then tightening a chain through it on a 45* angle would probably snap those cast holes right off.
I had room toward the front of my frame to bolt on D-rings for tie down points like these.
1/2" Bolt-On D Ring Anchor | Zinc-plated Steel
Or I have short straps I could put around the axles and hook them to the chains. Something like these.
Axle Straps - Car Hauler Axle Straps & Ratchet Tie Downs
/ Tow chain anchor points #3
I would use axle straps to D rings on trailer with shackles to hold. Then back tractor up. And secure rear end with come a longs.
Have any pictures? I'd like to see that setup. Thanks!
/ Tow chain anchor points #5
The straps I use around car/truck rear axles then connect my chains. That way the chains don't crush the brake lines when tightened. I have the D-rings on my tractor front frame and a twisted clevis on the drawbar. What did you want pics of? I also have an assortment of small j-hooks that hook into slots in car/truck frames. I tow quite an assortment of vehicles on my trailer and need to be prepared by having a way to secure them.
/ Tow chain anchor points #6
I wouldn't do this,your asking for big trouble. With that setup there's a very good chance of breaking the axle housing.
The d-rings on the front frame.
/ Tow chain anchor points #8
I originally had them bolted to the brush guard but after seeing a few bent and broken guards I moved them to the frame. Each ring is rated for 5K lbs. Bolts and nuts are metric equivalent of grade 8.
/ Tow chain anchor points #9
I used some discharge hose to cover the first 2' of each end of my chain.
/ Tow chain anchor points #11
I don't think I'd add clevis points to the front axle at all. The frame would be a much better choice and likely easier and more appropriate material for welding into the bargain.
/ Tow chain anchor points #12
I typically use the axle straps also, they work great. I've used them on anything from atv's, lawn mowers, my tractor, vechicles, etc. They are pretty handy to have when there isn't a good point to secure to.
/ Tow chain anchor points #13
Axel Straps
I've also found that 24" is best for my application. Yours may be different but be sure to get them long enough.
I think those are lift points for the axle assembly in the factory or replacing, not tie down points.
-R
/ Tow chain anchor points #14
Why risk damage to axle weld something to tractor frame
