If you have Toolcat questions, ask them here...
/ If you have Toolcat questions, ask them here... #441
/ If you have Toolcat questions, ask them here... #442
I have been looking at Toolcats and have drove them too...nice. I'm thinking of getting one to take the place of my Boomer tractor that is mostly used for field mowing, snow removal, tilling, and loader work. I have 3-point equipment but also have a RTV900 I use to haul firewood. I'm tore between the 5600 or 5610 and what would be the best tool for the job. It would be nice to get rid of 2 items, blue and orange, to only have a white one!
/ If you have Toolcat questions, ask them here... #443
I'd recommend the 5610. Put a dump box on the three point:
Or use a dump trailer:
The out front finish mower:
The out front flail mower:
The out front Brushcat brush hog:
/ If you have Toolcat questions, ask them here... #444
I never knew they had dump boxes for the 3-point...thanks. I have watched the videos on the Brushcat and it looks nice!
/ If you have Toolcat questions, ask them here... #445
You can also rig up a box for the front. This one is setting on the forks:
I just use the 1 cubic yard bucket from the V417 Versahandler, loaded by hand:
/ If you have Toolcat questions, ask them here... #446
There is also a motorized 3pt adaptor that allows you to put/run many pieces of equipment on the front of the toolcat. They are turned around but does not affect use. Ie: cone spreader, bushhog, posthole digger, finish mower, etc. If you have several pieces of 3pt equipment then it may be the cheapest route to go.
/ If you have Toolcat questions, ask them here... #447
The radiator location of the 5610 (above the engine behind the cab) makes it less of problem of grass clippings clogging the radiator screen if you are going to be doing a lot of mowing. Having the 3 point plus a hydraulic PTO would allow use of any tractor attachments you already have.
/ If you have Toolcat questions, ask them here... #448
Can you tell me how to reset the 240 hour warning on my Toolcat 5600?
/ If you have Toolcat questions, ask them here... #449
I am not sure about this as my 2013 toolcat does not show me service reminders?
Have you tried pressing the light switch (the one you use to show codes)? That shows codes and may clear them?
/ If you have Toolcat questions, ask them here... #450
What Series is it?
I never saw any on our 5610 series F.
/ If you have Toolcat questions, ask them here... #451
That didn't work, thanks anyway.
/ If you have Toolcat questions, ask them here... #452
What Series is it?
I don't see anything about series on the machine or the manual. Where would I find that?
/ If you have Toolcat questions, ask them here... #453
I saved this from SSdoxie in a post from 2014:
/ If you have Toolcat questions, ask them here... #454
Nice work Xfaxman. I'm a D series on the 5600.
/ If you have Toolcat questions, ask them here... #456
I have that manual and nothing. I have talked to the Bobcat dealer in my area as well as Bobcat central where ever they may be and no one has the answer.
/ If you have Toolcat questions, ask them here... #457
The service reminder clock is a feature built into the Deluxe (keyless) panel. That is where it started but now may be in all, I do not know for sure. This is an option that can be turned on and time intervals can be set to owners preference. It is not turned on or times set from the factory. Turning it on and setting use hour preference can only be done with the dealer's PC and software. Instructions to reset the timer should be found in the Operator Manual in setup and use of the Deluxe Panel, towards the back of the book.
I can't remember the exact sequence to reset it, but do recall it was holding down 2 buttons. With the panel on and code displayed try holding down the push for code and work mode button at same time and hold them down for 10 - 15 seconds.
/ If you have Toolcat questions, ask them here... #458
Thanks again, but still no luck.
2012 John Deere 6170R (A57148)
2012 John Deere...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2018 FORD F-250 XL TRUCK (A59823)
2018 FORD F-250 XL...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2014 Mazda 2 Hatchback (A59231)
2014 Mazda 2...
