If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #441
   / If you have Toolcat questions, ask them here... #442
I have been looking at Toolcats and have drove them too...nice. I'm thinking of getting one to take the place of my Boomer tractor that is mostly used for field mowing, snow removal, tilling, and loader work. I have 3-point equipment but also have a RTV900 I use to haul firewood. I'm tore between the 5600 or 5610 and what would be the best tool for the job. It would be nice to get rid of 2 items, blue and orange, to only have a white one!
   / If you have Toolcat questions, ask them here... #443
I'd recommend the 5610. Put a dump box on the three point:
Or use a dump trailer:
The out front finish mower:
The out front flail mower:
The out front Brushcat brush hog:
   / If you have Toolcat questions, ask them here... #444
I never knew they had dump boxes for the 3-point...thanks. I have watched the videos on the Brushcat and it looks nice!
   / If you have Toolcat questions, ask them here... #445
You can also rig up a box for the front. This one is setting on the forks:
I just use the 1 cubic yard bucket from the V417 Versahandler, loaded by hand:
   / If you have Toolcat questions, ask them here... #446
There is also a motorized 3pt adaptor that allows you to put/run many pieces of equipment on the front of the toolcat. They are turned around but does not affect use. Ie: cone spreader, bushhog, posthole digger, finish mower, etc. If you have several pieces of 3pt equipment then it may be the cheapest route to go.
   / If you have Toolcat questions, ask them here... #447
The radiator location of the 5610 (above the engine behind the cab) makes it less of problem of grass clippings clogging the radiator screen if you are going to be doing a lot of mowing. Having the 3 point plus a hydraulic PTO would allow use of any tractor attachments you already have.
   / If you have Toolcat questions, ask them here... #448
Can you tell me how to reset the 240 hour warning on my Toolcat 5600?
   / If you have Toolcat questions, ask them here... #449
I am not sure about this as my 2013 toolcat does not show me service reminders?
Have you tried pressing the light switch (the one you use to show codes)? That shows codes and may clear them?
   / If you have Toolcat questions, ask them here... #450
What Series is it?
I never saw any on our 5610 series F.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A59230)
2001 Pierce...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
