If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #451
I am not sure about this as my 2013 toolcat does not show me service reminders?
Have you tried pressing the light switch (the one you use to show codes)? That shows codes and may clear them?
That didn't work, thanks anyway.
   / If you have Toolcat questions, ask them here... #452
What Series is it?
I never saw any on our 5610 series F.
I don't see anything about series on the machine or the manual. Where would I find that?
   / If you have Toolcat questions, ask them here... #453
I saved this from SSdoxie in a post from 2014:
   / If you have Toolcat questions, ask them here... #454
Nice work Xfaxman. I'm a D series on the 5600.
   / If you have Toolcat questions, ask them here... #455
   / If you have Toolcat questions, ask them here... #456
I have that manual and nothing. I have talked to the Bobcat dealer in my area as well as Bobcat central where ever they may be and no one has the answer.
   / If you have Toolcat questions, ask them here... #457
The service reminder clock is a feature built into the Deluxe (keyless) panel. That is where it started but now may be in all, I do not know for sure. This is an option that can be turned on and time intervals can be set to owners preference. It is not turned on or times set from the factory. Turning it on and setting use hour preference can only be done with the dealer's PC and software. Instructions to reset the timer should be found in the Operator Manual in setup and use of the Deluxe Panel, towards the back of the book.
I can't remember the exact sequence to reset it, but do recall it was holding down 2 buttons. With the panel on and code displayed try holding down the push for code and work mode button at same time and hold them down for 10 - 15 seconds.
   / If you have Toolcat questions, ask them here... #458
Thanks again, but still no luck.
Gravely ZT XL-52 52in Zero Turn Commercial Mower (A59228)
Gravely ZT XL-52...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
New Holland T2420 (A53317)
New Holland T2420...
Case 2390 Tractor (A59814)
Case 2390 Tractor...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2013 CATERPILLAR 950K WHEEL LOADER (A60429)
2013 CATERPILLAR...
