If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #461
Question for you? Do you have a keyless start or key? Have you entered the control panel configuration to see if maintenance reminders can be enabled / disabled there? Like you can with 2 speed, tire size, etc?
Do you have the key sequence to go into control panel configuration mode? I can send it is you need it
   / If you have Toolcat questions, ask them here... #462
I have the key start. I have tried every combination I can on the control panel. The only thing the manual gives instructions for is reset password. Yes, please send the key sequence.
   / If you have Toolcat questions, ask them here... #463
Here is the key sequence to enter the control panel setup. It does not say anything about controlling the service hours display so if you cannot change it here then it must be an internal parameter that can only be controlled by service with their PC software.
Let us know if this has any impact...
   / If you have Toolcat questions, ask them here... #464
No impact. I have the manual this page is from. I'm beginning to think I'm beat. Looks like I have to go to a dealer with the PC interface to have it reset. Thanks everybody for all your help.
   / If you have Toolcat questions, ask them here... #465
No problem and let us know what you find out
   / If you have Toolcat questions, ask them here... #466
I can give you all the info.
UFM82
I have a 5600 the left front tire is wobbly. It appears that a bearing is out. When I look at the schematic on line it looks like the bearing comes with the hub. Do you have to order the entire hun or is there just a bearing to replace.
Mike
   / If you have Toolcat questions, ask them here... #467
The first Toolcat came out in 2003, the A Series. They are now selling the G Series. Many differences between the Series.
If we new what Series you have, someone might be able to help.
   / If you have Toolcat questions, ask them here... #468
Agree with Xfaxman. Send us your serial number here and we can see what series machine you have and go from there...
   / If you have Toolcat questions, ask them here... #469
I have an "A" series Toolcat, it has about 700 hrs on it. I recently purchased and during trials did not notice how sensitive the hydraulic controls are especially the down boom valve. My brother has a "G" series and its night and day. I have attempted to adjust the joystick stubs over the valves, but to no avail. I had the float valve replaced as it did not work when purchased. When I call the dealer they did not know of anyway to fix the problem and said just replacing the valve should not have had any effect on the control.
Any ideas?
Thanks,
   / If you have Toolcat questions, ask them here... #470
What model is my 2012 Toolcat?? Can't seem to find it anywhere on line. Is it stamped on my VIN plate?
   / If you have Toolcat questions, ask them here... #473
i am considering purchasing or leasing a Toolcat for my ranch. i need to know your experience and advice as to which model i should try. the 5600 or 5610? i have tractors with PTO and FEL also. the Toolcat would be used as an all around chore machine moving hay into feeders repairing the ground around tanks,pulling a cuber for feeding during the winter. fixing fence mowing brush,spraying weeds and fly in the summer months and more if i can think of it.
   / If you have Toolcat questions, ask them here... #474
If you are going to do a lot of mowing, get the 5610. The radiator is up out of the dust.
The PTO on the 5610 is a hydraulic motor, so if you already have a small brush hog it should handle it, but keep an eye on the hydraulic temperature.
If you are doing a lot of mowing, get an out front mower, so much better.
You can see our experiences here: http://www.tractorbynet.com/forums/toolcat/270965-toolcat-5610-f-5610-g.html?highlight=
   / If you have Toolcat questions, ask them here... #475
I talked with Ray at Bobcat OKC. he is working me up a quote on a 5600 now. they sold the one you traded in he said.
   / If you have Toolcat questions, ask them here... #476
I wondered if they had sold it.
Tell Ray I said hello.
Start a new thread when you get it. :thumbsup:
   / If you have Toolcat questions, ask them here... #477
i asked him to figure a rental for 6 months on the 5600 first to see if i like that model. i could sure use the bed for a lot of stuff but that three point and PTO on the back has me thinking. i use a herd seeder for grass seeding my pastures and it requires a PTO,but i have been looking at hydraulic motors 540 rpm with the pto shaft and think i could convert it to a front mount on the 5600. just thinkin!
   / If you have Toolcat questions, ask them here... #478
Yep, copy this type: HLA Attachments - PTO Adapter 3 Point Hitch
Or: Skid Steer Quick Attach Adapter | Skid Steer Solutions
Be sure you use a cushion valve to slow and stop the motor.
   / If you have Toolcat questions, ask them here... #479
Yes Exactly !! Thank You... i guess i need to think of the high flow as a remote PTO. i can always put a farmboy on the back if i really need a three point. has Bobcat fixed the overheating problem on the 5600 radiator plugging issues. all of my acres are grass native grass pastures so i don't need to blow out the radiator several times a day.
   / If you have Toolcat questions, ask them here... #480
ok i am going to demo a 2018 5600. need to know more about the doosan engine. does it require def fluid? or does it have to regenerate the exhaust every so often? any comments on the 2018 mdels????
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
