If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #461
Question for you? Do you have a keyless start or key? Have you entered the control panel configuration to see if maintenance reminders can be enabled / disabled there? Like you can with 2 speed, tire size, etc?
Do you have the key sequence to go into control panel configuration mode? I can send it is you need it
   / If you have Toolcat questions, ask them here... #462
I have the key start. I have tried every combination I can on the control panel. The only thing the manual gives instructions for is reset password. Yes, please send the key sequence.
   / If you have Toolcat questions, ask them here... #463
Here is the key sequence to enter the control panel setup. It does not say anything about controlling the service hours display so if you cannot change it here then it must be an internal parameter that can only be controlled by service with their PC software.
Let us know if this has any impact...
   / If you have Toolcat questions, ask them here... #464
No impact. I have the manual this page is from. I'm beginning to think I'm beat. Looks like I have to go to a dealer with the PC interface to have it reset. Thanks everybody for all your help.
   / If you have Toolcat questions, ask them here... #465
No problem and let us know what you find out
   / If you have Toolcat questions, ask them here... #466
I can give you all the info.
UFM82
I have a 5600 the left front tire is wobbly. It appears that a bearing is out. When I look at the schematic on line it looks like the bearing comes with the hub. Do you have to order the entire hun or is there just a bearing to replace.
Thanks
Mike
   / If you have Toolcat questions, ask them here... #467
The first Toolcat came out in 2003, the A Series. They are now selling the G Series. Many differences between the Series.
If we new what Series you have, someone might be able to help.
   / If you have Toolcat questions, ask them here... #468
Agree with Xfaxman. Send us your serial number here and we can see what series machine you have and go from there...
   / If you have Toolcat questions, ask them here... #469
I have an "A" series Toolcat, it has about 700 hrs on it. I recently purchased and during trials did not notice how sensitive the hydraulic controls are especially the down boom valve. My brother has a "G" series and its night and day. I have attempted to adjust the joystick stubs over the valves, but to no avail. I had the float valve replaced as it did not work when purchased. When I call the dealer they did not know of anyway to fix the problem and said just replacing the valve should not have had any effect on the control.
Any ideas?
Thanks,
   / If you have Toolcat questions, ask them here... #470
What model is my 2012 Toolcat?? Can't seem to find it anywhere on line. Is it stamped on my VIN plate?
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
2018 Peterbilt 567 T/A Day Cab Truck Tractor (A60460)
2018 Peterbilt 567...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
Abaco Machines DVL500 Vacuum Lifter (A59230)
Abaco Machines...
Case skid steer wheels and tires (A56438)
Case skid steer...
1995 John Deere 7400 (A60462)
1995 John Deere...
