Ricn
- Joined
- Sep 18, 2015
- Messages
- 580
- Location
- WA
- Tractor
- Kubota U-35, kx-040, Ford 8n, JD-280, JD380, JD1020, JD40C, Satoh Bull, Kubota L2501,
Tommott - I have the same mower, it is new, less than two months old. I do like it but having few hours on it time will tell. Mine does have NSK bearings and new scraper idea as well. I had my Kubota dealer put rear hydraulics on to run the side to side option plus top and tilt for other things I use. Had some issues with the tilt bleeding off to fast due to the mowers weight almost matching the valves bleed down pressure? so they put a locking valve recommended here on TBN for the tilt connection that works well. I too thought of running mine off the loader control but wanting top and tilt as well, decided to go ahead and get all three remotes...I had to make some adjustments to the mower because, the cylinder hose fittings were hitting against the protective cover over the shaft connection on the mower end when sliding the mower L and R; no biggie but still required some mods there.. Mine came with the roller in the center so wanting the highest cut possible I lowered to the third hole or, the bottom. Also raised the side slider shoes up all the way due to scalping of my grass when turning and this helped a lot to prevent it. Still wishing it cut higher, I tilted the mowers front up using my top cylinder control but not that much to be gained in cut grass height, Now, and having the mower adjusted where I think it needs to be, everything works with ease so far....
Ricn
Ricn
