Bought a new F150 yesterday to haul my tractor
   / Bought a new F150 yesterday to haul my tractor #11
Seems like I have some turbo lag. Tuner should take care of that
Does your shifter show an 'S' mode? That will liven things up. But tuner or not, you have to spool up the turbines, and that takes time. There will always be lag until you get 'em spinning.
   / Bought a new F150 yesterday to haul my tractor #12
I towed a 8200# gooseneck horse trailer with a 2014 F150 crew with 3.5 ecoboost with no problems at all. You can expect about 16.5 MPG for all around mileage. On the highway, you can get 19-20 MPG, but you have to really work at it and stay at 65 MPH. Putting it on cruise control makes the mileage worse. Towing will be about 7- 9 MPG.
   / Bought a new F150 yesterday to haul my tractor #13
When I test drove a 3.5 ecoboost F150 it felt like the lag was in the 10 speed transmission. It holds too high a gear and is a bit slow to downshift to a useful gear. Turbos don't always have lag. It depends on how they are set up, size of the turbine etc. I've had turbo cars that had instant torque. I wanted to like the F150 because I do like turbos but my wife and I both liked the Tundra a bit better.
Keep in mind that most company's towing capacity numbers don't include driver, passenger or a full tank of fuel.
   / Bought a new F150 yesterday to haul my tractor #14
The new 8 or 10 speed transmission uses electronics in change gears. It will take 500-1000 miles before it will adjust to your driving style. Be patient.
   / Bought a new F150 yesterday to haul my tractor #15
The other thing to consider is using an overdrive gear substantially reduces engine braking which, with a load close to maximum rating, is essential
   / Bought a new F150 yesterday to haul my tractor #16
... I've had turbo cars that had instant torque...
Yep, if the turbo is spinning when you nail it. But from idle, you have what the unboosted engine puts out, and I'll bet I could feel the lag. (Can feel it in my EB Flex, in a new Porsche Cayman, definitely in my brother's GN, etc.) It's better in newer vehicles than older, but it's there (unless you have electric motors for "torque fill".)
   / Bought a new F150 yesterday to haul my tractor #17
Goggle pedal commander.Installed one on my 2016 Ram 2500.No more gas pedal lag.
I do love my turbos and my tuners over the years. I am not going to go crazy just a little bump. So far truck is pretty sweet. Time will tell.
   / Bought a new F150 yesterday to haul my tractor #19
I recently bought a 2017 3.5 ecoboost, super crew, 6.5' bed. Will tow with it Monday when I haul my L3400 w/loader & rear blade. About 6K lbs. total. Should be a good test. BTW, my first 1000 miles I'm averaging just over 20 mpg in mixed highway/secondary roads. Very happy with that.
That sounds good. I traded in a little toyota tundra that only got 16-17 mpg so this is a big step up. I ended up leasing mine so in 3 years I am done with it.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2011 Atlas Copco XAS 375JD6 Towable Air Compressor (A55973)
2011 Atlas Copco...
2015 Chevrolet Equinox SUV (A56859)
2015 Chevrolet...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
2018 John Deere 1653 (A56436)
2018 John Deere...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
