JD 1020 power steering
/ JD 1020 power steering #121
According to label oil in can in photo should be fine as it's meets spec's J20C
Hi,
I got the O-rings for the oil flow control valve.... So if I remove the three screews (8,15 and 16 from the photo), and I change the O-rings, replace the screews and the job is made with it_?! Is there any possibility to fall of any other pieces as the 3,4 from the photo?!
/ JD 1020 power steering #123
Any place there's an o-ring there's a n opportunity for an oil leak.
/ JD 1020 power steering #124
Hi,
If you are asking if 3 & 4 could FALL during removal of the valve, no, they are screwed into the transmission case.
Thanks for your advice....
So I remove the three screws.......... I put the new O-rings to their places, screw in the screewa and I hove the oil leaking will stop....
/ JD 1020 power steering #126
YES! New o rings should fix the leak. If not, look for something like a crack or pin hole in the valve body.
/ JD 1020 power steering #127
Blowing seal in power steering pump location on timing chain cover three times? After 15 minutes of run time. What is plugged?
Hello, TXJim... I have not been hearing about You long time.... Are you still active - I would like to ask something from You?!!
Sincerelly, J. Benedek
/ JD 1020 power steering #129
Benedek
At this moment I'm still alive but who knows what God has in store for me!!! What's your question??
Sincerely,Jim
Hello, Jim, thanks for your answer...
My problem is that there is a hydraulic oil leak... in the back downstairs at the suspension of the 3-point... as you can see on the attached photos...
More exactly - at the joint of the shafts.... One of the axle is to blab out...
What could be done? How could I sealed and stop the leaking of the oil? I dont really understand how the shafts are inserted in???!! I cant see nothing from outside / screws or others....
Lot of thanks, J. Benedek, JD 1020 owner
/ JD 1020 power steering #131
You tractors oil leak is a common problem. The leak is at the load/depth control shaft. One needs to drain the hyd oil,then remove both 3 pt hitch draft arms,place L/D selector lever under seat into "D" then slide shaft out either side,inspect shaft for wear,R&R seals,lube shaft then reinstall it,install 3 pt arms & shim out any side to side to side motion of the shaft. Install hyd oil.
Seal part # is T22098 & o-ring part # is A4730R
Hello, Jim, Happy NewYear!
I read your last post, I understood it, but I would like to ask something.... First - why is it a connection between the simple shaft and the L/D selelector level... What is the relationship between... Secondly - could You explain me the L/D selector importance and how does it work.... I know it has to be selected - but what is its function...
One side of teh shaft is moving/sliding a litle bit... the other side is not moving - how is this possible - may be is it broken?
Thanks,
Benedek J.
/ JD 1020 power steering #133
Happy New Year to you also.
L=load
D=depth
When lever under seat is set in D the tractor operator controls depth with 3 pt control lever,when lever under seat is set in L the mechanism inside tractor controls the depth or load to a degree by flexing(bending) the round shaft which moves cam follower in 3 pt control linkage which raises or lowers 3 pt & plow. L/D setting is less sensitive than L
If 1 end of L/D shaft moves but not the other end of the shaft it must be broken. I've never witnessed a L/D shaft that has been broken.
Hello, TxJim....
Soon is spring, and as we have a good weather. I would like to fix the hyd oil leak problems, to buy the pieces and I would to ask you : the Seal part # is T22098 & o-ring part # is A4730R is enough for the repairs or I need more other pieces / O/rings or any other?
And, as there are two sides, I suppose I need a pair of each pieces....Am I right?
Thanks,
J. Benedek
/ JD 1020 power steering #135
Yes you need a pair of seals. Inspect shaft for wear. Place L/D under seat in D before removing shaft.
Hello, Jim.
I started to fix the oil leakage problem... as you can see on the attached photos. I bought original pieces, O-rings and teflon washers, but I would like to ask something..
1. I desassambled everything, but there is a piece - which is marked with red arrow on the photos - is like a ring, bushing T22097 or something... If I dont take that out, I cant change the seal components... How can I remove this piece? On the diagram you sent me / I thing this could be piece nr. 19... am I right?
2. I have now one pair of O/rings A4730R and a pair of teflon washers T22098. But the O/rings have bigger diameters than the teflon washers and the shaft diameter? Is this normal, it has to be like this?
/ JD 1020 power steering #137
From viewing your photo's shaft appears to have sufficient wear to need replacing. Yes o-ring fits inside groove in bushing then insert Teflon washer inside of o-ring. One needs to utilize a pick similar to dental pick to remove old seals. Bushing with red arrow aimed at it is T22097
Thanks, Jim for your advice. I already ordered the new load shaft (L26932, T26598). So I dont have to take out at all the T22097 bushing, I only have to pull out the old - wear shaft, remove old seals, put it back to its place the new shaft... and that should be ready...
Sincerelly,
J. Benedek
/ JD 1020 power steering #139
John Deere advises not to remove T22097 unless damaged.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64276)
KNOW BEFORE YOU...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
3147 (A63117)
3147 (A63117)
