Pole building question
/ Pole building question #1
Newtocvt
Menomonie,Wisconsin
New holland 54d
I am thinking of building a pole building for general storage. Mostly for implements I don't want to leave out all winter. I don't need an insulated or heated building and was thinking about just gravel floor. Size wise I was thinking about 24x32 with one 9 foot garage door and a service door. No windows. The area I am thinking about slopes 2-3 feet over the 32' span. My question is can I set the post before the site is leveled and graded. My theory is I can set the post 4 feet deep with my post hole digger than the back full and gravel would essentially make the 6-7 feet deep. Any thoughts?
/ Pole building question #2
I think you will find it to be more than a major nuisance to be grading around posts already set.
/ Pole building question #3
That. Even if it means you build a retaining wall.
Jim
/ Pole building question #4
And do have a bldg code? Around here you'd need to have a footing under each post, inspected before backfill. Not a bad idea, even for storage.
Jim
No building code here. I already checked with the township only thing they care about is the road setbacks. It sounds like I should just get the area prepared first.
/ Pole building question #7
Prior proper preparation prevents poor performance.
/ Pole building question #8
Couple of things we had a high lift level our pad and really compact it so it shouldn't settle. Second if you do metal I highly recommend insulating the roof or it is going to sweat and drop water on your implements, the bumble wrap to do my 30x40 was an extra 300$ well worth it. I would level, compact then set your posts
/ Pole building question #9
I had a couple feet of fill added for my pole shed and had a driveable vibratory roller go aver it a couple times. When I had to dig for some plumbing pipes I had a difficult time shoveling and picking through it. That is a good thing and money well spent.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
STORAGE FEES (A59908)
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
MASSEY FERGUSON 255 TRACTOR (A62130)
MASSEY FERGUSON...
LeeBoy 8510C Leading Asphalt Paving (A61567)
LeeBoy 8510C...
