The WICKED Root & Debris GRAPPLE!!!!!!!
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,361
I just bought the L45 and grapple was sitting there calling my name but I don't know if it has ever been used the board that is stuck in it looks like it could be part of the shipping crate but I'm not sure about that and it is 66"
You can still get a lot of use out of it. Brush doesn't weigh much and that grapple will grab a big chunk of it. My wide dual lid is beefy like that and one tractor has about the same lift as your L45. There are A LOT of piles of debris you can move with it. Weight is not your friend on heavy loads is all, for those you need a small light well built grapple.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,362
my goodness I have read this thread for hours. I made a deal last Sunday on a grapple and I know very little about it but it has a new home and I will be using it. Bring it on what have I done?
If you decide you want a lighter grapple and want this one gone send me a PM.
I have an ideal timeline, scheme of events, for woody if I had the ability to lay it all out like a fairy tale(I don't, but can't we dream a bit?)....
To start...
Use the grapple for a while. You're obviously going to LOVE having a grapple! We can all wholeheartedly agree on this without a doubt.
I mean, it sounds like you got a good deal on this beastly chunk of steel, which shares the same basic geometry as our Wicked. For those who don't know, Ted's brother owns CA so we know those grapples VERY well.
You can throw it on the L45 and take out any frustrations on it imaginable. The grapple will remain in it's current state of condition.
Hook it up and simply ride around with it installed, noting the difference in having the grapple installed vs. the regular GP bucket. It will be noticeable and i'm not talking about the Big Man ego kick you'll experience right off the bat! :laughing:
Travis
Here's a pic I took on our dock a while back.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,364
I have an addendum to Travis's suggestion. Use it but list it at a fairly high price in CL while you use it and just leave the listing active until someone bites. That's an excellent skidsteer grapple and some contractor is going to want one in a hurry some day. When you sell it give Travis a call and he'll set you up with a more appropriate grapple that weighs half as much and work just as well.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,365
Thanks for all the replies I did get a deal I could not pass up and since I have never had a grapple or the lifting capacity of an L45 I will not miss 400 ibs of lift. My L45 with the grapple on it will still lift more than my B26 if I am hearing everyone right. Thanks again and now I will have to watch some videos on the uses of the mighty grapple.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,366
Don't worry about the weight of that grapple, it is probably similar to mine. That Wicked grapple would have carried the rock I pulled easier than my grapple, as it is designed better to grip & clamp stuff. Want to trade?
I have my L39 hydraulics modified a bit for about 20% capacity, wheel weights, thumb, and reinforcement for extra ballast, but that was about a 3,000 rock. I could not drive my excavator on the lawn. Attached is a photo next to my little tractor for comparison.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,367
What have you done, you ask? You've acquired a 956 pound grapple. :shocked: Hope you have one heck of a tractor to put it on....like at least 75+ horsepower!!
Travis
FYI My grapple is a bit over 700 Lbs, so you will notice the extra weight a bit. L45 is tough on grapples, expecialy on rocks, so it you trade you want a Wicked grapple in the 600 Lb range.
It has the capacity of some 75 HP tractors. Load the tires, and add wheel spacers/ weights.
Yes, they're very impressive machines, but I have complete confidence in the Compact, ~400 pound range Wicked Grapple on an L45.
Travis
I mean, it has been field tested by Eric for years on his famous NX6010. :eek:
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,369
I'm looking into buying a Grapple myself and was wondering what grapple would you recommend for my tractor? There are so many grapple's are the market at the moment but really like the wicked grapple..
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,370
Travis
You know Ted, I could use some toothed backward serrated 1/4" AR400 plates to weld on to the tips of my Grapples splines. I can do a CAD dwg for you, do the product testing and now you have an accessory line to sell?
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,371
Just see post #2368 L45 has over 2,800 lbs lift full height at pins, more than the LA1055. And Eric has not broke it.
Compact Wicked Grapple for sure! Width and lid configuration is really up to you and the TBN peanut gallery. :laughing:
Single Lid Compact Wicked Grapple
Dual Lid Compact Wicked Grapple
Seriously, I'll be glad to discuss size and lid configuration if you give me a call sometime!
Travis
From the EARLY days wayyyy back in this thread....
Roger has had a 72" Compact Wicked on his L 40 series Kubota for years! His is a 4240.
Here's a 4240 with a 60" dual lid.
A recent L6060 with a 60" single lid.
I knew I had an L5740 pic somewhere. This one is wearing a 72" dual lid.
Man, we are so far behind, so if I even hinted the idea towards Ted, engineering or our plant mgr, they'd throw multiple things at me until I disappeared. :laughing:
Nice thought though!
Travis
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,375
20 yrs ago who'd a thought that photo of the 60" dual lid grapple would "turn me on"?
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,376
Thanks for the pictures.. Im leaning towards the 66" Dual lid version. Do they only come in black or can you get them in Kubota Orange also?
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,377
Hey Travis, how about checking and correcting some of the grapple weight numbers in your marketing material. Just how much more do dual lid grapples weigh? Cannot be zero pounds different from single. And how can a 72" grapple weigh only 38lbs more than a 55" of the same type??
As you acknowledged weight is a factor in selecting the right grapple so why not give your customers accurate data??
You're pretty persistent, ya know. We have beefed up some things like the cylinder mounts and added the protective bars on the back, so the slight weight increase does need to be updated.
Yes, you've harped on the dual vs. single negligible weight difference, i think, since we first made the single lid. This is also something that needs to be weighed, but the difference will be slight.
Travis
Thanks for the pictures.. I'm leaning towards the 66" Dual lid version. Do they only come in black or can you get them in Kubota Orange also?
The traditional Wicked Grapple is really only available in black, but we may be talked into an orange one for $50 more.
One unattractive stipulation is that it could complicate an already complicated lead time, which most would like to stay away from! :eek:
Travis
/ The WICKED Root & Debris GRAPPLE!!!!!!! #2,380
You're pretty persistent, ya know. We have beefed up some things like the cylinder mounts and added the protective bars on the back, so the slight weight increase does need to be updated. Yes, you've harped on the dual vs. single negligible weight difference, i think, since we first made the single lid. This is also something that needs to be weighed, but the difference will be slight. Travis
If I'm persistent then you are equally evasive. Your sales literature is wrong. People make decisions based on it. We have a weight of 90+ lbs for one lid from a customer. If two weigh 70+ lbs more than a single that might be a consideration for someone with a medium size CUT. You guys cut out discs from your tines to save a few pounds and brag about it. Why not give accurate weights in your sales literature??
(10) New CATERPILLAR Keys (A65579)
(10) New...
John Deere 5525 (A60462)
John Deere 5525...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
2021 Bobcat T770 (A64126)
2021 Bobcat T770...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
