Lawnmower trailer behind ATV
/ Lawnmower trailer behind ATV #1
Michael Aos
Gold Member
Colorado Springs
Kubota BX2370-1 RTV500
I've been looking for a small trailer I can pull behind my RTV500 -- ideally around 48" wide or less.
I'd like a ramp on the back, or a tilt-bed so I can drive my self-propelled lawnmower on it.
Anybody ever seen such a thing? I'm finding that EXTERNAL dimensions are almost never included in trailer specifications.
I'm envisioning something like this:
Here's the lawnmower:
/ Lawnmower trailer behind ATV #2
homedepot and lowes. end up seeing a flyer 3 to 4 times a year. comes in a kit, and normally out in front on a pallet.
grainger.com, harborfreight.com, tractorsupply.com, farmandfleet, farmking, and other farm / agriculture larger stores.
any little 2 wheel single axle trailer. that fits to a truck bumper, to riding lawn mower, to atv, to utv. should be able to easily modified if not already allowed. by leaving off the connector for a ball hitch connection.
do a google search for
walk trailer site:tractorbynet.com
or
walk over trailer site:tractorbynet.com
i remember a handful of the threads, that went into it pretty good. with different trailer types. some diy and possible options, to wanting a trailer. along with dump trailers, trailers that hand a crane like winch setup on it. to other.
sorry not much help beyond above.
/ Lawnmower trailer behind ATV #3
I have a tandem axle lawn trailer from Country Manufacturing that I pull with either my mower or ATV. It has a hydraulic dump bed thats nice for heavy loads, though the actuator could be improved. A little more expensive than some I've seen but I like it quiet a bit. I don't know if they still make the tandem lawn trailer but they do show an ATV model with larger tires
/ Lawnmower trailer behind ATV #4
Unless you want a filing cabinet on wheels, I would avoid box store trailers. Hit your local trailer supplier, they can fix you up.
/ Lawnmower trailer behind ATV #5
My 2 cents; Wife bought a Yutrax Trail Warrior X2 to pull behind her quad. For areas I can't get the tractor into, I've loaded up our little lawnmower in this trailer with ease, it tilts to the ground and is pretty dang rugged. Very happy with it.
/ Lawnmower trailer behind ATV #6
I have a tandem axle lawn trailer from Country Manufacturing that I pull with either my mower or ATV. It has a hydraulic dump bed thats (sic) nice for heavy loads, though the actuator could be improved. A little more expensive than some I've seen but I like it quiet (sic) a bit. I don't know if they still make the tandem lawn trailer but they do show an ATV model with larger tires
That's a nice looking and substantial trailer but "hydraulic dump bed" ?? Where do you connect the hydraulic hoses on your ATV?
I'm guessing it has an electric Linear Actuator? Be careful of overloading weight in the bed.
:wrench:
I looked (online) at those, but it wasn't clear to me whether they tilt to the ground. Any idea what the overall / total width is with the tires?
I was also looking at something like this Wheelchair / scooter carrier from Harbor Freight.
I have the Gorilla Cart GOR6PS from Lowe's. It works, but I want something larger, and hopefully easier to load.
/ Lawnmower trailer behind ATV #11
I had one of those trailers. Below is a video about it. You can buy at Lowes for $380 off season especially if there's a little rust. It was exact width of my midsize Polaris Ranger 400 HO. You could put a ramp on the back to push your mower up into.
Below is trailer I got to replace the small Lowes trailer. But it doesn't fit your needs. Excellent for use behind an ATV!
Wood Wagon; Basic Wood Harvesting Outfit for the Homestead - YouTube
Awesome ATV Trailer, MUTS! Pt1 Intro - YouTube
WinPower PTO Generator (A66408)
WinPower PTO...
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
Jumper Cables (A64127)
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
