4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,128
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
If you were paying attention, I was correcting the guy that thought "more clamping force, per lid" up in post 2293. A lid doesn't put out more pressure by adding a second lid. You are simply putting pressure in two places instead of one, but the amount of pressure remains the same for each.
If you were paying attention, I was correcting Mopardude318 up in post 2293 that said "more clamping force, per lid". A lid doesn't put out more pressure by adding a second lid. You are simply putting pressure in two places instead of one, but the amount of pressure remains the same for each.
Over kill on the grapple to machine ratio is definitely possible. I'm not sure at what point bite force would be overkill. I wouldn't complain if I could split logs with the grapple teeth. I'm not much of a fan of so called charities. A donation of that scale will never happen from me. Pretty much the only thing the tractor grapple does better is not destroy grass.More is only better to the point of being sufficient. Overkill can have drawbacks as well. Why haven't you given your tractor and tractor grapple to some sorta charity if there is no longer a need for it?
So many fleas to circumcise.................so little time.![]()
Who ever complained about inadequate bite force?? The biggest rock I ever pulled out of the ground and could barely lift to transport was clamped by a single tine! And, with this style of grapple the lids main job is simply to keep the load from falling forward, gravity and the bottom tines do the serious work for the vast majority of loads.
Had this story been true it might have made your hobby a little easier to grapple with
UK.Mirror.co.uk
05:38, 22 SEP 2016
Billions of super-fleas with huge penises are set to invade British bedrooms this autumn.
Far bigger than 'normal' fleas, a new breed has emerged which has a ***** two and a half times the length of its body - the largest genitalia relative to size of any bug on the planet.
Now, with autumn approaching and the nights drawing in, they are about to hop indoors to relax in our centrally-heated homes.
Conditions for flea breeding have been ideal with a warm summer and the right amount of rain and damp.
The new flea breed is believed to have emerged come from Europe over th past three years.
. Where is a middle finger emoji when you need one?Yeah what's 200+lbs of lift and a paltry $500 to a real man. Might as well get the 84" custom triple lid so everyone appreciates the size of your cojones.
My hobby? I'm not the one drawn to articles about bugs with oversized male parts?. Where is a middle finger emoji when you need one?
That is a personal problem that you don't need to shareIt's gettin kinda stupid around here.
