adding 3rd function to John Deere 5200 front loader
/ adding 3rd function to John Deere 5200 front loader #1
papdaddy
Defuniak Springs, Florida
John Deere 5200
I have a JD 5200 with added 521 front loader. I want to add a 3rd function to the loader to operate a hydraulic rotary cutter. Can someone help me find the parts I need to make this happen. The JD dealer nearest me doesn't know what I need.
/ adding 3rd function to John Deere 5200 front loader #2
What you need is kit LV100117. I have attached some information from JDparts
If you PM (private message) me with your email address, I will email you the instruction for the kit, if you would like.
  • lv100117.pdf
Will do. Thanks!
/ adding 3rd function to John Deere 5200 front loader #4
It is on its way.
/ adding 3rd function to John Deere 5200 front loader #6
/ adding 3rd function to John Deere 5200 front loader #8
Not sure what cutter you want to use but most front mount hydraulic rotary cutters require lots of flow to operate in the range of 15-20gpm. Your tractor only outputs around 11max probably more like 8-9 once it was piped up to the loader so don't think you would be able to do it. Only other option would be a pto pump and a tank mounted to the 3pt hitch.
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
Land Pride 80in Rotary Brush Cutter Tractor Attachment (A61572)
Land Pride 80in...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
