adding 3rd function to John Deere 5200 front loader
/ adding 3rd function to John Deere 5200 front loader #1
papdaddy
Defuniak Springs, Florida
John Deere 5200
I have a JD 5200 with added 521 front loader. I want to add a 3rd function to the loader to operate a hydraulic rotary cutter. Can someone help me find the parts I need to make this happen. The JD dealer nearest me doesn't know what I need.
/ adding 3rd function to John Deere 5200 front loader #2
What you need is kit LV100117. I have attached some information from JDparts
If you PM (private message) me with your email address, I will email you the instruction for the kit, if you would like.
  • lv100117.pdf
Will do. Thanks!
/ adding 3rd function to John Deere 5200 front loader #4
It is on its way.
/ adding 3rd function to John Deere 5200 front loader #6
/ adding 3rd function to John Deere 5200 front loader #8
Not sure what cutter you want to use but most front mount hydraulic rotary cutters require lots of flow to operate in the range of 15-20gpm. Your tractor only outputs around 11max probably more like 8-9 once it was piped up to the loader so don't think you would be able to do it. Only other option would be a pto pump and a tank mounted to the 3pt hitch.
2016 Ford F-150 Ext. Cab Pickup Truck (A61573)
2016 Ford F-150...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
2020 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
