Show us your front end weights and brackets.
/ Show us your front end weights and brackets. #21
Not a clue my friend, not a clue!!!!
Anxious to find out though. :D
/ Show us your front end weights and brackets. #22
My trailer required that I get off and lift the bed to dump.
The 3 point hitch did not lift high enough to dump the trailer,,,
This devise makes the trailer go high enough to dump,,,
Here is a 1:23 minute video that quickly explains it.
That is pretty clever.
/ Show us your front end weights and brackets. #24
Very, very cool. I was sure that's what it did, but with the pic I couldn't quite visualize it. Not bad for a cobbler. :D ;)
/ Show us your front end weights and brackets. #25
That is incredibly clever!
Here is a front weight bracket and weights I bought used for a good price. The bracket is for an M5460 Kubota or something like that but through judicious cross-searching I learned it would fit my M7040 Kubota as well about 30 other Kubotas. I wonder if kubota doesn't like to fool with part numbers and applications. Anyway, it fits so I bought the bracket and 7 weights for a total, I think, of 800 lbs. I'm good with that.
Ignore photo below. It's for a different tractor and I can't figure out how to delete it. Just ignore.
/ Show us your front end weights and brackets. #27
I just looked at a similar bracket on a M6 yesterday.
FYI, to secure the weights, an angle iron goes through the hole in the weights. The angle iron then bolts to the bracket on each end.
Thanks. I've got the angle iron but it's bent in the middle. I tried to heat it and pound straight but no dice. Any idea how to in-bend 2" x 2" x 1/4" angle iron? I could heat it more as well or just make another. Any thoughts?
In actual use, I've left the angle iron bracket, or retainer, off for years on several bigger tractors and never had a weight come off or even shift on me.
/ Show us your front end weights and brackets. #29
I'd probably just make another angle iron fastener.
I don't fasten the weights on my 9540. If I bounce the tractor hard I'll hear them bang around a little but have never lost one.
/ Show us your front end weights and brackets. #30
You could pm shieldarc for how to heat bend. (I'd probably do like Richard suggested and make a new one.
When I lived in rural Maine with fields, woods, swamps and severe hills and rocks, I had a Kubota M8950 with --I think-12 or so weights on the front. I severely bounced around, nearly rolled it and never had one move.
/ Show us your front end weights and brackets. #32
I built my rack and intentionally made it a bit long. So the weights can side shift a little. I think that's the banging around I hear occasionally.
Of course someone will read our posts and decide to not fasten their weights and bounce one off. We'll hear about that!!!!! :D
/ Show us your front end weights and brackets. #33
Seems like they COULD also bounce around enough to break?
/ Show us your front end weights and brackets. #35
I'd like to see a 100# weight break. Maybe when I was younger....:D
You stud you. ;)
Not saying you can't break them, but it's going to take more impact than a 1/4" of slack will create. I'm always gentle with them thinking I might break one if I drop it too hard or something. But I can't say I've ever saw one broken.
/ Show us your front end weights and brackets. #36
This started out as a weight bracket for an old L series. I made it work with the grill guard. It sits high enough for me to get up and down the hills I mow.
How did you mount that with the grill guard? Do you have a closer photo?
/ Show us your front end weights and brackets. #38
I was going to post more pictures last night but Photobucket would not cooperate.
Then I can put 4 weights on the grill guard on the L4240.
94BULLITT--that is a beautiful installation with what is probably Kubota's best looking weight on Kubota's fine BX. Plus the dual use is icing on the cake. We sure are fortunate to own these beautiful tractors and be capable of doing such quality mods.
/ Show us your front end weights and brackets. #40
Thanks about the installation. I feel very fortunate to have these tractors. The weights are actually a copy of Kubotas weight. They say NS5011 on them. They were a good bit less since they don't say Kubota. I was looking at weights the other night and came across this website with aftermarket weights.
Wheel Weights - Lonestar Weights
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
Covington TP-66 Planter (A64127)
Covington TP-66...
2015 PETERBILT 567 6X4 T/A DAY CAB TRUCK TRACTOR (A66091)
2015 PETERBILT 567...
John Deere 7000 2R Planter (A66285)
John Deere 7000 2R...
