Oil & Fuel Crap in fuel tank. Help!
/ Crap in fuel tank. Help! #21
Amazon.com: Biobor JF - Diesel Fuel Biocide - 16 oz: Sports & Outdoors
This plus the new filters as mentioned. Everything will die and migrate to the filters so buy 3. One for now to get it running, one for when it's clogged with all the dead material and one to keep on the shelf.
You will want a little of the Biobor in the tank at all times if you plan to store it for long periods. This stuff will also help once things are cleaned up.
Amazon.com: Biobor MD - Diesel Performance & Efficiency Enhancer - 16 oz: Sports & Outdoors
Note the JF treats over 1000gals and the MD treats 60gals
Well I tried the first fill up with vinegar and wasn't very impressed. Did the second one today and will let it sit for 48 hours this time. If that doesn't work then?
/ Crap in fuel tank. Help! #23
If you are combating rust it works best to use half vinegar and half water mixed.
So mixing it makes it stronger? Less acidic seems less effective to me but maybe I'm missing something. Many report using it full strength which seems to make sense to me but I'm open to suggestions.
/ Crap in fuel tank. Help! #25
I dunno the chemical reason for it but I found out about it on a You Tube video and the person that posted it said it was more effective at 50%. I mixed mine at 50% and you can see the results in my photos. The photo showing the rust was after I pressure washed the inside of the tank and before I soaked with vinegar/water.
Here is one of the videos I saw on using it.
VINEGAR Cleans Heavily Rusted Metal FAST - YouTube
/ Crap in fuel tank. Help! #26
Try something with phosphoric acid in it.
Dairy farmers use a mixture to clean out the milking lines. Some will contain phosphoric acid. It works for me.
/ Crap in fuel tank. Help! #27
Phosphoric acid is a great rust converter. I was concerned with being able to get it all out and didn't know how it might react with deisel fuel and components if I didn't.
Ok just flushed 2nd vinegar soaking. Also was able to fish out a piece of black PVC pipe. No idea how that got in their along with a broken spark plug. Anyway the gunk in their looks like brown greasy mud which is why I think the vinegar is not working. How do I remove the greasy stuff without taking off fuel tank? IMG_2219.JPG
/ Crap in fuel tank. Help! #30
At this point I think you're beyond not removing the tank. If mysterious items are appearing it's time to get to the bottom of it, so to speak. Is the tank metal? An old motorcycle trick is to burn out the tank on a campfire, then coat with sealant and repaint. This is a drastic step, and should only be done as a last resort.
/ Crap in fuel tank. Help! #31
Yeah it is probably time to pull the tank and have it soaked at a radiator shop.
Thought about pouring some clean diesel in the tank just to see what happens.
/ Crap in fuel tank. Help! #33
I just went through this process last month... fortunately I didn't have to remove the tank to clean out the gunk. That brown greasy stuff is the biological crap that's been slowly growing in your tank. If you were to have looked in there with an inspection camera at the beginning of your investigation, the gunk would've looked like fairy-floss (cotton candy?) mixed with phlegm. :thumbdown:
I didn't remove the tank. I pumped & drained it out, then used a long, mechanical, grabber with CHUX cloths (J-cloth?) to wipe out as much of the dead brown stuff as possible.
My tank isn't metal so I put a litre of that (previously mentioned) Fuel Doctors treatment in and then filled the tank up with fresh diesel. The Fuel Doctors breaks down and suspends the biological stuff in the fuel itself. My tractor runs great now and I didn't have to even change out my fuel filter! :eek:ath: I'll do a couple more 1 litre full tank treatments just to get any residual crap that may be hiding within the fuel system, then I'll reduce the treatment to 50ml when I fill up.
There has to be something similar to "Fuel Doctors" in N.A.
Yeah that sounds exactly like what I see. It's a greasy / muddy looking gunky mess. You know gasoline breaks up oil and grease. I just wonder what that would do?
/ Crap in fuel tank. Help! #35
Fill the tank with hot water, add some bleach and dish soap and stir up with mixer on the drill. After setting??? Hr. Flush out the tank with clean water. Overflow all the gunk out and then dry the tank with air.
Bleach may kill the bacteria. The dish soap will form an emulsion that can carry out the gunk.
/ Crap in fuel tank. Help! #36
WOW! The fitting you hold in your hand in the pic sorta' tells all. YOU GOT RUST! And rust can easily destroy anything like your injection pump if it gets past your filter(s).
If it were me I'd pull the tank and burn it out, possibly by using gasoline, CAREFULLY! or diesel fuel or a combo of both until there is no evidence of anything but clean bare metal in your tank.
If you can't get it damnn near perfectly clean yourself, including trying the sharp rocks trick, it maybe time to hire a pro who has the tools/experience to do it right. Think about it - without correct clean fuel you have no tractor to use. What is it worth to you to have a reliable tractor?
I had an '87 Izuzu Pup truck which I owned since new. At one point it started running weird. Turned out the fuel tank was rusted. I took it to a guy who had the tank lined and guaranteed it would NEVER rust again. Way less $$$ than a new tank. Never had any more problems with it after that. Rust, combined with biological agents can drive one nutz!
I agree but am determined now to not pull the tank. I know probably stupid but I have 3-4K in the paint job and figure something will get damaged in the tear down. On a positive note I looked the tank over again today and I'm seeing improvement. Then I bought a bottle of clean diesel to try. It says us 32oz per 50 gallons but I went stronger. More like 32oz to 10 gallons. Lol. It almost instantly starting attacking the gunk and I could see some bare metal. Put a small grill brush in the tank and started moving around and scrubbing what I could and diesel fluid turned instantly dark brown. May eat a hole in tank but guess we will see. Lol. Definitely starting doing more than anything else I tried to date.
Well it got about 1/2 more of what was left in dissolved it out. Changed fuel filters and ran it all day with no issues. I have dual filters so will just keep using it for a bit then change out the filters again to see what I have going. Definitely way better than it was and hope it keeps improving.
2008 Kubota RTV 900 4x4 Fire Rescue Diesel Utility Cart (A61572)
2008 Kubota RTV...
Toro Z Master Commercial 72in Zero Turn Mower (A61572)
Toro Z Master...
HARDEE DITCH BANK MOWER PARTS (A63291)
HARDEE DITCH BANK...
WESTENDORF 12' LANDSCAPER BOX GRADER (A63291)
WESTENDORF 12'...
2016 Ford Escape SUV (A61569)
2016 Ford Escape...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
