Posted signs on lug "T" posts
/ Posted signs on lug "T" posts #1
stillok
Charlton new york
none
Lug "T"posts present a sort of unique problem when you wish to add a sign to them--NO HOLES. I recently acquired 50 lug posts which I plan to use to post my property. "U" posts would have been a much better choice, but the lug posts cost me almost nothing and the prior owner left the " "T" post wrap around insulators" on the posts. To attach the posted sign, I cut the fence holding nubs off each insulator with a hack saw, drilled the appropriate sized hole through the center of each insulator, and attached the sign using two backers (one front/one back) and a pop rivet through the drilled hole after attaching the insulators in the appropriate location on the fence.
/ Posted signs on lug "T" posts #2
Welcome to TBN, and thanks for the tip.
Bruce
/ Posted signs on lug "T" posts #3
Awesome tip. I once drilled a T post to hang a sign on it. I will never do that again. I don't know what type of metal they are made of, but it is really tough stuff and will dull a bit very quickly.
/ Posted signs on lug "T" posts #4
Welcome to TBN.
What are you posting your property from that requires 50 signs?
/ Posted signs on lug "T" posts #6
I once saw a segment on "How's it Made" that showed that t posts are made out of old railroad rails. Explains why they are so hard.
/ Posted signs on lug "T" posts #7
Here's my method.
I mount metal "NO Trespassing" signs on 3/4" cedar boards with screws and attach two eye screws to the back of each board. I then run wire through the eye screws and mount the signs on plastic insulators attached to T-posts.
Steve
/ Posted signs on lug "T" posts #8
/ Posted signs on lug "T" posts #9
I learned the same lesson. :D
But I did find better quality sharp bits worked ok in the end.
/ Posted signs on lug "T" posts #10
There is a steel "mini-mill" about 3 miles from my house. They take in scrap metal and make angle and channel iron, rebar, and t-posts. When I toured the place a number of years ago I saw the melt furnace in action and saw where they make the finished products. The melt shop pours molten steel into forms that make a billet about 24' in diameter and maybe 20 feet long. They take these and squeeze them down thru successive rollers into the other products including t-post blanks. The t-post blanks are sent to another shop that cuts them to length, puts on the plate and paints them. The finished posts are stored in a shed. I drove by the shed today and they had about 10,000 t-posts ready to ship.
I dont know that all t-posts are made from recycled rail because this mill takes in all kinds of scrap metal, including car bodies and rail.
Watching the melt operation was very impressive. IIRC, four large carbon rods carrying 3000 volts at 55,000 amps contacting a kettle of scrap iron makes for a lot of noise and sparks and smoke.
sorry to hijack the thread, but the mention of t-posts got me started.:dance1:
/ Posted signs on lug "T" posts #11
Burma Shave?
I have vivid memories as a kid, riding along in the back seat, Missouri to Northern Iowa on 2 lane hiways. Primarily Hiway 69. I stayed awake and paid attention out the window looking for those ads. They were spaced just right so you were anticipating the next message. Those were the days!!!! :)
/ Posted signs on lug "T" posts #12
Highways are
No place to sleep
Park your car
To count your sheep
Burma Shave
/ Posted signs on lug "T" posts #13
/ Posted signs on lug "T" posts #14
i just take a scrap piece of 2x4 and cut a groove down the center, then wire it to the post letting the nubs ride inthe groove. now I have a wood block to nail/screw stuff to.
/ Posted signs on lug "T" posts #15
I do the same thing except I use 2x8or 2x10 treated and U-bolts, then screw the AL signs to the 2x. Makes it a little harder for the trespassers to tear down.
/ Posted signs on lug "T" posts #16
On the T post thing...at an auction once, I bought 75 of them that were bent and cheap. I can vouch for the steel because it took two anvils, two sledge hammers and all day to straighten them. One or two, yes but never again and more than that. I think that's why most of the older ones only surface rust.
/ Posted signs on lug "T" posts #17
T posts are like angle iron bed frames. There is no telling what they might be made out of. All kinds of low-grade crap put together. I wouldn't plan on easily cutting, welding, or drilling them. Some will. Some won't.
U-bolts/etc. seems like a good plan.
/ Posted signs on lug "T" posts #18
From Wikipedia:
"A steel fence post, also called (depending on design or country) a T-post, a Y-post, or variants on star post, is a type of fence post or picket. They are made of steel and are sometimes manufactured using durable rail steel. They can be used to support various types of wire or wire mesh".
/ Posted signs on lug "T" posts #19
"Posted signs"?
I hope you mean signs that have been posted (i.e., put on a post where they are visible) and not those "Celebrate ignorance!" signs that actually has the word "Posted" on them.
/ Posted signs on lug "T" posts #20
"Posted signs"?
The ignorance is actually on those that don't understand what the sign means.
Google 'posted land'
'posted' itself has a meaning. ;)
Ignorance can be bliss.. till someone calls you on it. ;)
John Deere 544H Articulated Wheel Loader (A61567)
John Deere 544H...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A61307)
Midwestern...
2006 International 7400 SFA Terex Hi-Ranger 6TC-65 65ft. Insulated Bucket Truck (A60352)
2006 International...
2024 MAC TNAR39FR540 40FT T/A  FRAMELESS END DUMP TRAILER (A59906)
2024 MAC...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2016 KOMATSU PC138USLC-10 EXCAVATOR (A62129)
2016 KOMATSU...
