BX25 FUSE BOX Wire Connectors ???
/ BX25 FUSE BOX Wire Connectors ??? #1
Artisan
Monrovia, California
Kubota BX25
So I see there are 3 unused holes for mini fuses in my fuse box
on my BX25.
I want to add circuits utilizing these future holes.
Can someone clue me in as to exactly what kind of connector
I need to buy (and where*) and once I have it w/ a wire attached, how do
I install it, will I simply push it in from the back till it clicks in?
Also how to remove them?
Here are links to large format pics of the front and back of the fuse box.
Maybe it is a common box ?
FRONT PIC
REAR PIC
* I went to the parts area at Kubota's website and I will be
dipped in it if I can find a part number for the fuse box and
those connector ends. I dare ya to try to find a P/N for the
fuse box! The box "might" come w/ connectors. (?)
NOTE:
OK I figured out the P/N for the fuse box. K2581-63224
It is attached to the whole darn wire harness.
NOT Good for me.
BUT! I just bought THIS on Ebay. It looks like the same company
made this box. I am gambling the terminals are the same. If so
I can play w/ it and figure things out and have some ends to
splice into my box.
/ BX25 FUSE BOX Wire Connectors ??? #3
Please let us know if it works
/ BX25 FUSE BOX Wire Connectors ??? #4
There is a tool for installing/removing the pins in the fuse box. You can get new pins and the tool at Auto Zone or other auto stores.
...and I wish I had the EXACT part number to do this.
Indeed AZ has lots of tools in this area but unless I can
ID the exact Part Numbers and or types I an dealing with
I am can not proceed.
Here is a picture of the fuse block I bought that is SIMILAR
to what I have on my BX25 davesi708. What is the AZ tool
needed to remove the pins from this fuse block and what
is the part number for the pins. ?
/ BX25 FUSE BOX Wire Connectors ??? #8
Not quite the OEM answer you are looking for, but I'm copying this guide for my auxilary fuse & relay box on my L4060. Wiring up 2 alledgedly 300 watt (more like 150-175 when I checked) LED light bars & a few other accesories. DIY Bussmann RTMR Fuse Block, Part 2 – Parts | Bodenzord
That picture above looks like the fuse box from my old L3200 as well. Never did figure out what connectors to use on that one to use the extra slots in the OEM box.
Looking at my L4060 Kubota Doesn't use Deutsch connectors or anthing from the Weatherpack family tree. The connectors actually don't look weatherproof at all for the most part. Some like ones on the hazard lights on the cab outside are just bullet connectors with soft heatshrink boots on them.
I expect to find some answers when I receive the fuse
block I bought on Ebay I referenced in post #6 but I kept
looking tonight and looks like ALL KUBOTA TRACTORS
have fuse boxes made from unobtainium. I looked at
L and M tractors, went to parts for them under ELECTRICAL
expand the tree, then around Engine#4 or so you will
see fuse boxes, all like 010 / A P/N's that all refer to
the main wiring harness. You HAVE to buy a complete
harness to get fuse boxes and terminals. One harness
was almost $1400.00
There has to be a way...I await my Ebay fuse box, hopefully
I can disassemble and ID the terminals.
/ BX25 FUSE BOX Wire Connectors ??? #10
moship,
That is looking very close my friend. In my first post I have
links to 2 large format pictures. When you click on the pic, if
you are using Internet Explorer, it will probably size DOWN
the picture so once the picture loads, if you click on the picture
itself it should blow up to huge so you can see things a little bigger.
But what you posted up moship looks real close. As soon as I get
that "like" fuse box I bought on Ebay (see post #6 here) I will be able to determine
exactly how it works and what tool and procedure will remove
those fuse terminals and go from there. This will be very good
intel for others in the future if I can nail down the exact terminals
used and the tool to release them and the procedure for the tool.
PS, I have NO DOUBT that some of the terminals are MULTI TERMINALS.
I can see one feed wire going in to both the 10A fuses but each
of the two outlet wires from each fuse has it's own wire.
Here is an example of a MULTI TERMINAL as I call them.
a 4-way Fuse Block Terminal they call this.
You only need one feed wire for this...well,
I believe you can use these multi terminals two ways.
You can feed it with one big wire or you can use it
on the outlet side and feed 4 small wires.
These come in 2- way, 3- way, 4- way etc.
OK, I received the donor fuse box I bought on EBAY.
The process to remove these lil buggers is simple, a tiny
flathead screwdriver will work nicely. More on that later.
Right now here is 3 views of the same terminal I pulled
out of the donor fuse box.
Granted, I could attach wires to these terminals I am removing
from the donor box and I just might do that but for those in
the future who can not get there hands on a donor fuse box
like I was lucky enough to find, here is a picture of what
I believe is needed. I am 99% sure on this, of course I
will need to plug a terminal into my fuse box to be 100% sure.
If anyone finds these terminals for sale before me please post up
where and a P/N please. There are 4 different terminals.
Small Medium Large and Triple
Here is how to release / remove the terminals.
They pull OUT from the back.
With lust a LITTLE bit of pull, pulling on the wire from behind
use a tiny flathead jewelers type screwdriver and simply push the
spring loaded tabs in the appropriate direction and they come out
with ease.
I the triple terminal, well I was able to apply a little bit of pull
from behind and I kept going from one to the next to the next and
all of a sudden it popped out.
Patience, if you break a tab you are toast.
/ BX25 FUSE BOX Wire Connectors ??? #14
You might take that box down to your local auto parts store & see if Metripack connectors fit. They come in weather proof & open versions. Connectors are common & avaliable in most auto parts stores (may carry over to the panel parts). See my link above about the auxilary fuse box I'm copying/building. There are some good photos of the Metripack connectors there.
/ BX25 FUSE BOX Wire Connectors ??? #15
I think I found them! At least they look very similar.
Fuse Block Terminals
Let me know if you think they will work.
No Bueno moship,
What you found has little spikes that stick out that
hold the terminal in the fuse block. Here is another
picture and explaination as to how the Kubota
terminal works.
/ BX25 FUSE BOX Wire Connectors ??? #17
Darn! Thought that was it and feeling really good I helped a fellow member here. Oh well...
One would think these would be standard terminals. I know the automotive world sets up standards for wiring and termination to reduce cost and complexity across manufactures.
It would really be nice if they just provided wire pigtails for the unused fuses, so users could splice into them. Some pickup trucks will do this for up-fitters.
Another thought in the event you can't find the exact termination. Perhaps use the one I posted or similar and use epoxy or hot melt glue to retain the wire in the fuse block. I've done this on some unique automotive connectors that couldn't be replaced and it worked. Not ideal, but will work in a pinch.
I found something VERY VERY CLOSE, if not it.
Looks like a Honda Fury motorcycle might have the
same terminals. This picture is in some guys forum
album at furyforums.com This looks like what I see so far.
Moship I am quit sure I will be able to use one of the pigtails
from the fuse box I scored on Ebay, now I want to ID the
terminal so others in the future will know what to get.
THIS is VERY close
That sideways "D" shaped hole if where the tab in the fuse
block holds the terminal end.
/ BX25 FUSE BOX Wire Connectors ??? #20
So I get what you are trying to do. You will have a neat installation, but couldn't you have done a quick and easy thing like this?
