New To Using MIG
/ New To Using MIG
Thanks guys.
I was gonna get a stick welder, as that was all I knew and an older friend that worked at TSC said to go MIG instead. No school either cause I work nights and I don't wanna eat up Saturdays. Besides $$$$ My hat is a $108 Hobart hat. I'm happy with it.
I'm using the Hobart E71T11 .030 flux core wire. I have decided to get the gas hooked up. Just need a bottle full of 75/25 and a spool of solid wire ER70S6. The side panel on the 210 MVP states this will make a smoother weld. I do need brighter light. I am hesitant on adjusting the hat for a lower shade. But will look into it. I never was able to write stright across a pae without lines. So this is showing up in dragging left or to the right.
hugs, Brandi
/ New To Using MIG #23
Thanks guys.
hugs, Brandi
The cheap Chinese auto darkening helmets the Reaction time 0.25
Miller auto Reaction Time 1/20,000
Hobart Reaction Time, 1/12,000, 1/25,000, 1/30,000.
Lincoln Reaction Time: 40 microseconds
3M Speedglas Reaction Time: 0.1 milliseconds
Try a gold plated lens, never need batteys
/ New To Using MIG
/ New To Using MIG #25
Brandi when you switch to Mig, I really like Lincoln's Superarc L-56 wire.
SuperArc(R) L-56(R)
/ New To Using MIG #30
I just bought the same hobart 210 welder last week. I'm enjoying playing with it. I have a 60 cu ft bottle with c25. You will like the clean welds it makes over the Flux core wire. Much less smoke as well. Shielding gas welding is best indoors without wind. I'd leave the fan off unless you are out of the direct draft.
2020 VOLVO VNL760 6X4 T/ A SLEEPER TRUCK TRACTOR (A59906)
2020 VOLVO VNL760...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
1965 Fontaine PS2824SP 28FT 15 Ton S/A Flatbed Trailer (A59230)
1965 Fontaine...
