New To Using MIG
/ New To Using MIG
Yesterday I couldn't spell welder. Today I are one. Yesterday, I played around with beads and different setting and bead techniques. Last night I was watching training videos from the link posted above. Today I welded my first project. 1-29-17 Water Gate Frame Welded.jpg An inlet watergate for my pond. I tried the video guys "church steeple" technique and the weave. I do better with the weave. My first decent weld on the 2 inch tubing happened on the inside corner weld. 1-29-17 First Decent Looking MIG Weld.jpg Go figure. Also, I seem to weld better dragging the puddle away from me, then to the left or to the right. I did better on my first vertical welds then the flat position welds. Go figure again.
It will have 1/4" plate U bolted to the pipe hinges. The two inch gap at the bottom will be for normal water flow. 1-29-17 Water Gate Gap Welded In Place.jpg I gave it a two inch gap to keep out larger logger head snappin' turtles. Logger heads are open season in my ponds. Red Ear Sliders are no shooting for all. The frame will be bolted 3 places per side with all 1/2 bolts or all thread. The cedar posts will be cemented in 24 inch long x 12 inch wide trenches with rebar in the concrete and through the post. We will see next flood how it does.
hugs, Brandi
/ New To Using MIG #12
With Mig welding you want to run as hot as you can handle it. Also, if you are right handed. Hold the Mig gun in your right hand. Start on the right side, and travel to your left. That is called pushing.
With welds looking like that you've earned bragging rights, I'm still trying to master Mig.
/ New To Using MIG
Thanks! It is black pipe. I did have the fan going blowing the smell and grinding dust out the door. I don't weld galvanized. That stuff is bad, even grinding.
hugs, Brandi
/ New To Using MIG
I usually wipe my metal with acetone, then spray on two or three coats of spray bomb rustoleum.
What do Y'all use.
/ New To Using MIG #16
For personal use when I paint something like a truck or tractor thats going to be exposed to the elements I sand blast to white metal the use Endura polyurethane primer and top coats. These are a two part paint and have a limited pot life.
Endura from the same can maybe used for Marine and Aviation.
It's wicked paint breathing gear is required to apply.
Endura Paint - Industrial Coatings
/ New To Using MIG
Understand. At work, we have to be respirator fitted each and every year................even if we don't use one.
hugs, Brandi
/ New To Using MIG #19
Once you get the hang of it, you'll be reaching for the MIG gun allot more than the stick weldor. Keep looking over the videos and the rest really is staying behind the shield! The more practice, the better you get once you have the basics.....I have a Miller 250 and run a gas mix instead of fluxcore. I seem to get less splatter that way, but really don't have much shield time with fluxcore.
Sometimes you can grab a night course through your local tech school that can help. Two other things that have helped me is make sure you buy good wire (the price difference IS worth it!) and save your pennies for a good helmet. I have two guns; One set up for .030 wire and one for .023 for the light stuff, and found a nice used Speedglas helmet on e-bay for $250 that I love. Just like anything you get what you pay for!
WELD ON!!
LOOSENUTS
/ New To Using MIG #20
A big part of welding well is being able to see what you're doing through the lens, and the new electronic ones can be turned up or down depending on how much current you're using. It also helps to have strong light where you're welding as that will also help you see. I'm also a big fan of gas shielding 75% argon/25% CO2 for steel, straight argon for stainless steel and aluminum, which I do very little of. Much easier to see what you're doin' without all that flux in the way...
16001 (A55853)
16001 (A55853)
Giyi 2WD Mini QA Excavator Arm (A60463)
Giyi 2WD Mini QA...
CAT Chassis Only (A59076)
CAT Chassis Only...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
Striker TNB-4M Hydraulic Breaker (A60462)
Striker TNB-4M...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
