Just had a sickening thought
/ Just had a sickening thought #21
A friend of mine works for OSHA in California (Occupational Safety Health.) I asked him about your question.
First, he asked if the hitch ball for your trailer properly placarded? It should have a placard notifying any user that the ball includes metal that could possibly cause cancer if touched. (California prop 65.) If it does not, immediately discard and get an OSHA-approved ball. Same for the drawbar, which also requires a second placard notifying the user that anything attached to the drawbar, if it also connected to a tractor, could result in injury, dismemberment, or death.
The loaded tires are a violation. Unless you have a certificate from the manufacturer, this is an unapproved tractor, wheel, and tire modification possibly hazardous to people, barn animals, and more. He also asked if you have a spill containment system to catch the fluid in case of puncture. The containment system is required by statute when parked and also when operating.
OK, enough poking fun. I want to express appreciation for the OP's focus on safety. Tractors are great tools but are also hazardous. Sometimes a new perspective brings a safety awareness none of us thought about. His post might just save a life or someone's limbs in the future. Good job. Sometimes the little things can sneak up and bite!
/ Just had a sickening thought #22
Didn't watch the video... but semi truck tires (100+ psi) blowing out vs tractor tires (10 - 20 psi) is a huge difference in velocity and stored energy. Highly unlikely that a tire at 15 psi in reasonably good condition will just "blow out"....
/ Just had a sickening thought #23
...OK, enough poking fun...
OK, You got me... :D you had my blood boiling over. I just filled out a required safety plan at work... You can not fix stupid with a "plan".
/ Just had a sickening thought #24
One never knows freaky things do happen,todays tractors are heck lot safer than most 50's -60's.
Just good w/your gut feelings at the time.
/ Just had a sickening thought #25
Woke up early this morning pondering whether I should get out of bed or not. Finally took my chances and made my way to the coffee pot. Managed to make a cup of coffee and get to my desk without scalding myself. Every day seems to start by taking chances. You also have to worry about waking up too and some day it won't happen.
/ Just had a sickening thought #26
A guy was working on his car and the jack gave out. The frame came down on him and his wife called 911. One of my buddies responds and lifts the car off him and the wife pulls him free. Accidents can happen. The car should have been blocked instead of relying on the jack alone.
The deputy was disciplined for lifting the car as he could have injured himself. Yes seriously.
/ Just had a sickening thought #27
I did have a tire spontaneously explode once or twice (sort of).
The first was a bicycle tire I'd inflated outdoors and brought inside.
The 2nd was
I once loaded a wagon running gear up with some big cherry logs and parked it at a neighbors saw mill. I think I had extra pressure in the tires as the load was heavy, I had a few miles to go at road speeds and I knew it might sit at his place for awhile until he got around to making lumber and I didn't want them going soft.
Well it sat there for close to a year. But one day he heard what sounded like a cannon going off next to his mill.
They were very old tires. Probably many decades.
It was also "sap" weather . Cool nights, sunny warm days. I suspect the repeated wide variation of pressure through the day, day after day, snapped the last belt holding the tire together. So yes, there are 31.5million seconds in a year, if you,d been under that wagon during the one it blew out you'd be saying "What, I can't hear anymore."
/ Just had a sickening thought #28
Poop Happens !
Stay safe.
When ever I have ignored that little voice in my head about safety , it didnt end well.
/ Just had a sickening thought #29
I've had 2 tires blow out in a shed. 1 on a skidsteer and 1 on an air compressor. Both looked visibly fine before hand. I figure if I'm under something or beside something and the tire blows out and kills me then that is just my time to go. We will all go one day, we just need to know where it is we're going!
/ Just had a sickening thought #30
I've had cars, trucks, tractors and trailers for over 50 years. In that time I've had one blow-out. That was a 20 year old trailer tire that I had retired and it was sitting in the shed. So I would say that chance of a tire blowing out while you are under a vehicle is incredibly small.
/ Just had a sickening thought #31
putting jack stands under vehicles is good but what if....the sliding adjustment gave away? got to keep all the what ifs in the back of your mind and try to be as safe as possible when doing any kind of work. one of my what ifs is...a lug nut falling of a airplane flying overhead..
/ Just had a sickening thought #32
Don't forget about the possibility of a sink hole opening up while you're under the tractor and getting crushed or buried.
/ Just had a sickening thought #33
I have had my hydro tractor creep a little bit when I had my foot close to the front of the tire. I caught it in time but I would hate to be stuck with my foot jammed under a tire and all I have with me is a rusty jackknife.
Why is your Jacknife rusty? Keep it sharp and keep it clean.
/ Just had a sickening thought #34
If the OP's tires are loaded and he had a blowout while under the tractor, he is as likely to be drowned as to be crushed. As for lug nuts falling from airplanes...I think the more common falling object risk from commercial aircraft is blue ice blocks... a pisser for sure to have the bad luck to be hit by one of those.
/ Just had a sickening thought #35
Ah the infamous blue ice bombings of old but I think they all have to use holding tanks these days. Part of servicing aircraft between flights is to pump out the holding tanks. Yeah it's probably a pretty ****** job. Kinda like getting the greenhorns to blow out the relief tubes on aircraft back when.
/ Just had a sickening thought #36
Yeah, like that guy on the news couple years ago. Sinkhole opened under the house and the bedroom floor caved in, he was sleeping in the bed, went in the hole, never recovered the body!!!
I'm not neurotic about things like this, but will admit that one kinda got to me. I can't live like that.....
/ Just had a sickening thought #37
They were referred to as... Icy-BMs.
:eek:ath:
/ Just had a sickening thought #38
Even worse, your driving down hill and the steering wheel stays in your hands.:eek:
/ Just had a sickening thought #39
What if your driving down a hill and the steering wheel comes off in your hand and THEN a tire blows out at the same time?
/ Just had a sickening thought #40
Then you'll need the other 2 Stooges, or W. C. Fields - they'd know what to do!
Jim
2018 Chevy Traverse 3rd Row Seating (A61307)
2018 Chevy...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2016 Chevrolet...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
