Just had a sickening thought
   / Just had a sickening thought #31
putting jack stands under vehicles is good but what if....the sliding adjustment gave away? got to keep all the what ifs in the back of your mind and try to be as safe as possible when doing any kind of work. one of my what ifs is...a lug nut falling of a airplane flying overhead..
   / Just had a sickening thought #32
Don't forget about the possibility of a sink hole opening up while you're under the tractor and getting crushed or buried.
   / Just had a sickening thought #33
I have had my hydro tractor creep a little bit when I had my foot close to the front of the tire. I caught it in time but I would hate to be stuck with my foot jammed under a tire and all I have with me is a rusty jackknife.
Why is your Jacknife rusty? Keep it sharp and keep it clean.
   / Just had a sickening thought #34
If the OP's tires are loaded and he had a blowout while under the tractor, he is as likely to be drowned as to be crushed. As for lug nuts falling from airplanes...I think the more common falling object risk from commercial aircraft is blue ice blocks... a pisser for sure to have the bad luck to be hit by one of those.
   / Just had a sickening thought #35
Ah the infamous blue ice bombings of old but I think they all have to use holding tanks these days. Part of servicing aircraft between flights is to pump out the holding tanks. Yeah it's probably a pretty ****** job. Kinda like getting the greenhorns to blow out the relief tubes on aircraft back when.
   / Just had a sickening thought #36
Yeah, like that guy on the news couple years ago. Sinkhole opened under the house and the bedroom floor caved in, he was sleeping in the bed, went in the hole, never recovered the body!!!
I'm not neurotic about things like this, but will admit that one kinda got to me. I can't live like that.....
   / Just had a sickening thought #37
They were referred to as... Icy-BMs.
:eek:ath:
   / Just had a sickening thought #38
Even worse, your driving down hill and the steering wheel stays in your hands.:eek:
   / Just had a sickening thought #39
What if your driving down a hill and the steering wheel comes off in your hand and THEN a tire blows out at the same time?
   / Just had a sickening thought #40
Then you'll need the other 2 Stooges, or W. C. Fields - they'd know what to do!
Jim
NEW Landhonor 9200LB Ratchet Binders & G70 Chains (A59000)
NEW Landhonor...
2017 Ford Transit 250 Cargo Van with Lift (A56858)
2017 Ford Transit...
KMC 4R STRIP TILL (A52708)
KMC 4R STRIP TILL...
NEW Fork Extensions (A59000)
NEW Fork...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2005 Freightliner M2 106 Ambulance (A56858)
2005 Freightliner...
