EverythingAttachments
Elite Member
I must admit it. I've never seen anything quite like this 4052M John Deere, which has our 60" Wicked Grapple up front.
Travis
Travis
Yep, that is a Wicked Horny machine. :laughing:
Travis
What's a good size grapple for kubota L3940?
Or ...... maybe ask what BEF needs a grapple to do? Lightest, narrowest ....... is not always the correct answer. You should already know this?
Your presumption is reasonable but I have never seen a published standard that clearly states that loader capacity is measured with a "standard" bucket attached. Problem is that there are many types of buckets and for bigger equipment there might not be a universal standard bucket. I haven't looked recently but I've never seen a published protocol for doing loader capacity testing.
Hah! Should have bought a Kioti!!! (grin). Loader strength matters more than HP or fancy transmissions for many common CUT tasks.I can lift 1500 with forks on, but can't curl. I usually do 1000 lb.when unloading wood pellets. Should have went up one tractor size to larger loader, same as my L5030, but didn't.
Unless one has a good reason to go wider, my recommendation is the 60" Single Lid.
Some like wide and some like narrow, but the 60" is right in between.
Some like dual lids.
Size and lid configuration are really personal preference IMO. The weight is right on all of them!
Travis
Travis
Thanks for the reply, 60" is what I was figuring on.
