The WICKED Root & Debris GRAPPLE!!!!!!!
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,541
The other name being "the almost 300lb overweight (=300 lb lower net lift capacity) and nearly twice as expensive grapple that should only be mounted on utility tractors with more than 3000lb lift capacity model". Unfortunately if you want more than 37" jaw opening that's the only choice from EA.
Seriously though, EA needs a simple grapple with >40" jaw opening for true compact tractors with loader capacity up to 3000lbs. Millonzi made one twelve years ago so it ain't rocket science.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,542
Ohh, so you're just a troll.
Got it.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,543
Ohh, so you're just a troll. Got it.
Hardly. TBN is a discussion forum and this thread seems limited to advertising and "look at my new grapple" photos. I figure it's appropriate to broaden the discussion a bit. That is especially the case as new potential grapple buyers are likely to read the thread and should see more honest discussion.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,544
So you know the title, you know what grapple I had, you feel it's a biased discussion and need to interject you opinion. Trolling.
My last response as I'd rather see the thread stay on topic, you know how to PM if your ego is that fragile.
Our Wicked Grapple lineup has been broadening and improving. Our AWESOME customers are more than pleased. We have the best reviewed and most photographed grapple in existence.
The feedback speaks for itself. We can recommend the PERFECT grapple for your tractor!
Travis
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,546
Eh. Island may be a little opinionated but he has offered much to our grapple discussions, based on seat time and mechanical intuition. He's definitely not a troll.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,547
Agree. Even to the extent that I believe that EA mentioned that IT's posts were part of why they expanded their grapple lineup to taller openings.
I also agree with Travis that EA is expanding and improving their line of grapples tremendously. If someone wants a light and narrow grapple, they have them, heavy and wide, they have those too. And nearly everything in between.
Sea2summit looks like he selected the one that is best for him. Cool!
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,548
Travis
I think EA knows that I have been very supportive of their efforts to expand grapple options for CUT owners. Indeed, I'd go so far as to say that EA is the only grapple manufacturing company out there besides WRLong that really focuses on the CUT market and they have been far more responsive than other companies. EA has done a LOT to bring appropriately sized grapples to the CUT market and currently produces the best quality and best designed grapples aimed at CUT use. My prodding for lighter, narrower grapples with larger jaw openings is, as EA knows, a long standing and sometimes quixotic effort of mine to educate potential grapple buyers but is also to encourage EA not to sit on its laurels but to continue to make even better grapples for the CUT market.
Case in point. We have a happy customer who has put a 600lb+ grapple on to a CUT with less than 2500lbs of lift capacity. That is a waste of both lift capacity and money unless someone can prove otherwise. It is the proverbial 1 ton truck purchase to collect groceries at the supermarket or take flower arrangements to church once a week. There is simply no way that any L series or even M series Kubota needs a 600lb grapple. 600lb grapples are for true full sized utility tractors with loaders capable of lifting 3000lbs at a minimum.
I am well aware that EA doesn't push such oversized grapples but they certainly do "bend in the wind" willingly when the customer wants one. Hard to argue against that as a business, after all the customer is always right and besides they have much higher profit margins on the Mega grapple than on the smaller ones. If Granny wants an F350 to drive to church on Sundays why can't I sell her one? Right? But I think we all can agree that what is best for Granny is not always what is best for Ford. It may not be the Ford salesman's fault when Granny rolls out of the dealership in a one ton but that still doesn't make such a purchase reasonable.
The point of my original post criticizing the mega grapple choice in this case is to prod EA to continue to IMPROVE their offerings. The only legitimate argument, IMO, for the mega grapple choice on a CUT is that only the mega grapple line has a jaw opening of 40+ inches. There are lots of times when a 30" or even 37" jaw opening might be less useful than 42 inches. No one should be forced to buy an overbuilt heavy and expensive grapple simply because they want a large jaw opening. Granny shouldn't be forced into purchasing a one ton simply because she has a legitimate need for a six foot bed to transport flowers to church. Ford makes a number of options to allow Granny to get the functionality she needs without purchasing a heavy duty truck. EA needs to redesign some of their excellent grapples to further improve them so wider openings are available. 30 inches is totally reasonable for a SCUT. 37 is probably OK for most uses on 30hp machines. 37 becomes a limiting factor on CUTs with lift capacities over 1500lbs. I have a traditional narrow light duty grapple (see my avatar photo) with a jaw opening of 42 inches. That grapple was initially mounted on a 20hp tractor with lift capacity of just over 1000lbs. It is now on a 40hp tractor with lift of 2700+lbs. It has served well in both. I have NEVER wished for a smaller jaw opening. The geometry is not rocket science. EA makes much better grapples than my twelve year old 300lb grapple so why can they not improve the jaw opening dimensions??? Where is the Mark 2 version of their very successful sub compact grapple? Why can't the current compact grapple jaw open a few more inches?
I guess there will always be folks who just have to have the biggest possible truck even if a salesman points out that a smaller truck will be more cost efficient and that the larger truck is literally always excessive for the intended work but I also think that there is a responsibility for the salesman to make the pitch vigorously if they really have the customer's best interest in mind. Can the salesman really be considered to have done his/her job if Granny rolls out of the dealership in a F350 when her only need is to transport flower arrangements once a week to church?? Did the grapple salesman make perfectly clear that by selecting a mega grapple that the customer would actually be able to lift LESS material than with the perfectly adequate compact grapple???
I believe it is the role of a discussion forum like this to help educate both the manufacturer and the potential customer how to offer and select the appropriately sized implement for intended uses. We need to keep pushing EA to expand and improve their already best in class grapples. EA needs to do a better job with their marketing materials on the interweb too. Their grapple chart Untitled Document and descriptions simply don't educate grapple naive customers about how to make a choice very well at all. We also need to continue to help educate other CUT owners making their first and usually only grapple purchase. Just posting nice photos and keeping this thread going as a thinly disguised classified ad doesn't do it.
Here's a review i received yesterday from Bryan in PA, who has had our 50" Single Lid Wicked Grapple since 8/2015.
"As a little testimony, I had a lot of doubters when I debuted the Compact Wicked Root Grapple. We were clearing a building lot of some pretty big oaks. My brother in law was cutting logs pretty long, I think trying to prove the grapple couldn't handle the job. I'm sure some of the logs were well above the FEL lift capacity, but you shoulda seen the looks on the guys' eyes! This grapple is AWESOME!! Wish I could find some pics I took of the logs I was moving."
Here's my grocery getter. The kids LOVE it when we take it to church! Yea, there's a subcompact tractor behind it. We know what the'll do!!
Travis
This video is about our newest version of the Wicked Grapple with the protective bars.
Watch it and you'll discover why the Wicked Grapple has been so successful.
We pay so much attention to detail. This is what separates us from the competition.
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,553
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,555
The term "pipe fittings" sounds a little scary. Maybe "NPT hydraulic fittings" instead?
We're simple folk. Ted describes it for like minded people!! :laughing:
Travis
/ The WICKED Root & Debris GRAPPLE!!!!!!! #1,557
Looks good, Ted. Relentless innovation driven by listening to the market.
The bit about a large grapple that could pick up round bales hit home for me. We've tried to do it with our 72" single lid on 5' round bales. Close but no cigar.
Thanks Mac! Our new subcompact Wicked Grapple rake for the Kubota BX is pretty special too.
Travis
Check out the 50" Wicked Grapple on a Vermeer S800TX Mini Skid Steer!
Travis
