What welder will do this
/ What welder will do this #21
take the plate and receiver hitches to a shop and pay to have it welded properly, (this is not a time/place to learn to weld)
I thought he was welding recievers to mount something to a table. That sounds like the perfect learning project to me. If I missed it & a road going vehicle is involved, ya leave that to a professional to avoid killing people. If it's for a tractor impliments, I'd go for it myself & wouldn't work much about a novice welding that unless it would be used on roads or any potentially dangerous situations.
Ok talked with the electrician and he recommended using aluminum wire I think 2/0 with conduit and putting a sub panel in. I do the trenching and he will wire it all up. TKS Ricky
/ What welder will do this #23
That's is what I used.............2/0 aluminum to the barn's sub panel.
hugs, Brandi
/ What welder will do this #24
When I put solar on my barn/shop I did the trenching & got the solar guys to drop in 125@ service out there to replace the 50@ of cable (and 100@ of circuit breaker :-o). So worth it. They only put a 12 breaker box on the barn side, but I found a 40 breaker box full of breakers on Craigslist for $50. It's now a sub panel on the shop side. So nice being able to trivially hook up any additional 110 or 220 circuits I want or need.
In the long term you won't regret running big wire out to your shop. Just get a big breaker box for your sub pannel. Go bigger than you think you need so you can do it right & not worry when adding stuff later.
1995 6ft. Wee Willie S/A Utility Trailer (A59231)
1995 6ft. Wee...
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
2018 New Holland C227 Compact Track Loader (A61307)
2018 New Holland...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
