Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed
/ Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed
Further thoughts that is*
Fish head how well does your provonost inverted scrape?? The hydraulic edge looks like it glazes over the snow leaving some behind? We have to clear dang near to the pavement even if the snow has been driven on. Also being in a warmer climate with more moisture in the snow is an inverted the way to go or would the snow pack too much when driving over it toward the garage?
/ Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed #23
I think that most of the modern tractors are pretty darn nice and reliable, just have to figure out which combination works for you. With regard to my blower i think it does a pretty good job of scraping, i don't have the hydraulic rear blade as i don't do commercial work. Just tonight i was looking at the cutting edge on the bottom of the blower and it is not perfectly straight as it is a relatively thin section flat to the surface rather than perpendicular like the hydraulic edge would be , am thinking about a double thickness edge to replace it. the blower is about 900 pound so it scrapes pretty well, i am sure the rear edge would be even better. On mine it may leave 1/4 to 3/8 of an inch of snow depending on the surface.
The snow you drive over does not seem to be the issue, its the snow that got driven on earlier and froze. I think that they must do an acceptable job as most of the purchasers of rear pulls are commercial and they sell their product as higher quality than plowing.
If you want ,check out plow site and in the heavy equipment section check out a thread titled:" switching to a blowing service". These are commercial guys using rear pulls because they can generate more income.
Fish head I appreciate your feedback. I have been following the thread on plows it and reading up on things for awhile now. The plows it thread is very informative.
/ Kubota L4060 or L4760 narrow setup for sidewalks front attachment info needed #25
I know that there have been some sidewalk specific threads there as well, might be worth posting your requirements over there as they seem to have members familiar with a lot of non tractor options as well.
2004 Bulter Pole Trailer (A60352)
2004 Bulter Pole...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
Schulte SBW800 Rock Windrower (A61307)
Schulte SBW800...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
